Old 09-14-2009, 09:02 PM   #11281
TonyK's Avatar
Its true. I haven't had any problems. I read it in one of the threads here either this thread or the about tuning a VTA car. Give me a little time and I will see if I can find it.
Originally Posted by Foxxrocket View Post
That's hard to belive. I had to dremel out the bottom, just to fit a 45 tooth pinion. So, how were you able to fit a 50t pinion?
A large part of their history is made up of blood and battle. This is not something to shrink away from as a fancier of the breed. Their history should be embraced, understood, and once we have a full understanding, we can control the future.
TonyK is offline   Reply With Quote
Old 09-14-2009, 09:10 PM   #11282
TonyK's Avatar
Just looked at my car and you are right. I did have some rubbing on the webbing but the rubbing was very minimal. Nothing that a little dremel won't fix. Thanks making me check it out a little more.
Old 09-15-2009, 06:10 AM   #11283
Originally Posted by TSR6 View Post
Hey guys, I saw a guy take a TC3 RTR straight from the box, onto the track. The only change he made was his Radio. It seamed to run fairly well considering it was a RTR.
i am getting into the trans am class after i get my racing pit setup conqwerd
racerguy13 is offline   Reply With Quote
Old 09-16-2009, 12:28 PM   #11284
trdsupra88's Avatar
Trader Rating: 25 (100%+)
Send a message via Yahoo to trdsupra88
Ran mine for the first time yesterday. It feels like a good car and tracks straight with alot of power. I was glad to see that a car designed with brushed motors in mind can handle 7700kv and LiPo. I am running on a large 1/8 nitro asphault track that is dusty with rubber tires, 40wt, blue in front and silver in rear. Ran with a diff up front but will upgrade to a steel spool asap.
I cut my own hair ☆
trdsupra88 is offline   Reply With Quote
Old 09-28-2009, 04:21 PM   #11285
terryh1313's Avatar
Hello all, need help on making my tc3 make tighter turns. they changed the layout at the track. so there are alot of turns now
handle the business, before the busines handles you
terryh1313 is offline   Reply With Quote
Old 09-28-2009, 04:31 PM   #11286
Foxxrocket's Avatar
Tell us more about the track, and your car setup. As soon as you give us that, the better we can help you dial in the car.
Tamiya 416X/ Tamiya TA-05 IFS/ Losi XXX-SCT/ HPI Baja 5SC/ Tamiya M05/ Tamiya F103/ Tamiya F104/ Team Associated 10R5O/ Kyosho IGT2/
Foxxrocket is offline   Reply With Quote
Old 09-28-2009, 05:00 PM   #11287
terryh1313's Avatar
the track is 110 x 50,my setup is novak 21,5 an novak speed control. just installed a hitech 645mg servo to replace a futba 3003, stock shocks, running VTA
Old 09-28-2009, 05:17 PM   #11288
Warren Weaver's Avatar
Trader Rating: 46 (100%+)
if anyone is interested i have a bmi tc4 and factory team tc4 with many spares and tons of tc3 parts for sale
R1 WURKS-AWESOMATIX USA-LRP-BITTYDESIGN-TQ WIRE-PROTOTYPE RACING-SWEEP RACING-TXDSKINGRAPHIX-HOBMAX-THE RUG-TEAM EZDUZIT
R.I.P. MY FRIEND JDUB MISSED BUT NEVER FORGOTTEN
Warren Weaver is offline   Reply With Quote
Old 09-28-2009, 05:42 PM   #11289
trdsupra88's Avatar
What tc3 parts do you have and are you interested in any kinds of trades?
I cut my own hair ☆
Old 09-28-2009, 07:02 PM   #11290
Foxxrocket's Avatar
Carpet, or Asphalt? High, Med, or Low grip? Indoor, or Outdoor?
The electronics are not as important as your car's setup. What's your Droop, Camber, Toe, Caster and Ride heigth? What Springs, Shock oil, and Pistons are you running. What's the cars wheelbase, tire componde, and body? How are the shocks layed out? You running Oneway, Spool, or Diff?
Old 09-29-2009, 05:18 PM   #11291
jman's Avatar
I have a TC3 set up for VTA racing,where are you guys mounting a personal transponder?
jman is offline   Reply With Quote
Old 09-29-2009, 06:46 PM   #11292
Trader Rating: 23 (100%+)
Send a message via Yahoo to JATOdriver
i cut out a lil bit of the foam under the bumper and mount it there, very clean cant even see mine
Hi, my name is Daniel and i have a problem, I'm addicted to R/C cars.
***TEAM TERRIBLES***
JATOdriver is offline   Reply With Quote
Old 10-04-2009, 08:04 PM   #11293
RHH
Default TC3
Terry,
If you can find Barry Bakers set ups on the RC10 site, you'll find some great setups that work well for stock to mod. I run a 3.5 brushless and have driven the TC3 for 10 years and it is still competetive with anything in good hands.
I suggest a spool. The car rotates and accelerates off the corners really well.
This means you can slow down enough to take a tight line around the corner and come off hard.
Good Luck.
RHH is offline   Reply With Quote
Old 10-21-2009, 12:45 PM   #11294
t4mania's Avatar
Just getting back into sedan racing with my TC3. What size brushless motors & spur gears are they running in Trans Am class racing. thanks in advance. 1S or 2S lipos.
SC10 4X4 Short Course
SC10 FT 2WD Short Course; FT B4.1 +8mm Buggy
FT T4 Dirt Oval
Silva Concepts R50 Oval
Custom Works Dominator; FT TC3 Trans Am
t4mania is offline   Reply With Quote
Old 10-21-2009, 01:19 PM   #11295
IndyRC_Racer's Avatar
USVTA (Trans AM) rules can be found here (http://www.usvintagetransam.com/rules/index.html)
-The only legal motors for VTA are the NOVAK 21.5 SS or the NOVAK 21.5 Ballistic.
-The easiest spur gear to use is a 84 tooth 64 pitch gear. Combine that with a 50 tooth pinion and you have the fastest/max allowable FDR of 4.2. However, if you are running a newer speed control (SPX/Tekin) your FDR will probably be closer to 5.0 depending on the size of the track.
I recommend starting out with a 84/46 combo for VTA if your are runing on a small track and using a speed control without boost (GTB/Havok)
- Lipo batteries are 2s with a max MAH of 5000.
I'm currently racing VTA. Check here for rules/info: http://www.usvintagetransam.com/
IndyRC_Racer is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
