Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 02-01-2009, 06:03 PM   #11236
Syber Serulean's Avatar
Trader Rating: 19 (100%+)
Send a message via AIM to Syber Serulean
yeah switch to 64pitch and you're set. Keeping it 48pitch results in "omg dremel" syndrome.
Appreciations to:
//Team Epic//C.B. Designs Paintjobs//OC Circuit//Hobbytown Corona//
-STUFF FOR SALE!!! http://www.rctech.net/forum/r-c-items-sale-trade/341264-lipos-motors-other-stuff.html#post6555168
-Pegasus Hobbies "The Stadium" (Saturday racing at 5pm)
Syber Serulean is offline   Reply With Quote
Old 02-02-2009, 10:06 AM   #11237
IndyRC_Racer's Avatar
The only reason to dremel the cam if you are running VTA is if you want to run a spur gear larger than 84 and run the max allowed FDR or 4.2 In the case of an 88 tooth 64 pitch spur you can run up to a 52 tooth pinion for a FDR of 4.23.
However as TeamGoodwrench has suggested above run an 84 tooth spur and a 50 tooth pinion to get exactly a 4.2 FDR if you are running the USVTA class. This is assuming that you are using the 21.5/lipo motor option.
The intent of modifying the TC3 chassis, cam, or any other part of the car for many racers is to use what they've got without spending any more money. While I would always recommend to any racer to buy the gears that allow the best fit without any alterations, I also think it is important to let racers know how they can modify their existing components. After all a TC3 cam is around $7-8 new and probably will last the life of the car. On the other hand a 64 pitch spur gear can be just as much and can easily be ruined by debris or poor gear mesh.
I'm currently racing the U.S. Vintage Trans Am series. Check here for rules/info: http://www.usvintagetransam.com/
IndyRC_Racer is offline   Reply With Quote
Old 06-30-2009, 11:16 PM   #11238
rustong's Avatar
Default I'm back from simi retirement
I'm getting my TC3 ready to race again. This time I'll be racing in SoCal the OC Circuit. I havent raced the TC3 in about three years and back then was with a 10 turn motor and 3300 batteries. This time It's a Novak Havoc with a 17.5 SS motor, and a SMS 4500 mah 28C Lipo. I cant imagine what the difference will be but I think I'm going to like it.
Still happy to be part of the TC3 family.
Russ
Russ Glass
OCRC Raceway
Team Associated FT RC10B4 >< Universal City Nissan >< JConcepts >< Novak >< Valley Super Burger.
rustong is offline   Reply With Quote
Old 07-01-2009, 01:28 PM   #11239
I run VTA with 48 pitch gears. 35/60 gives you 4.29 FDR, which is close enough. I had to dremel just a little from the web under the pinion. Other than that, the fit is fine -- no cam work needed.
jhberger is offline   Reply With Quote
Old 07-01-2009, 02:19 PM   #11240
I've run a 84/50 for VTA on a TC3/TC4 which is also a 4.2. If you run that large of a pinion you will have to dremel out the area of the chassis below the pinion.
Old 07-01-2009, 07:08 PM   #11241
rustong's Avatar
I'm planing on running a 75/53 (3.5) 64p. So far it looks like it will work. I don't see any clearance issues. I haven't run it yet I get my battery Friday.
Russ
Russ Glass
OCRC Raceway
Old 07-01-2009, 09:29 PM   #11242
rustong's Avatar
Would you believe that someone on Ebay has a brand new in the box TC3 RTR for sale?
http://cgi.ebay.com/ws/eBayISAPI.dll...m=270416671779
Russ
Russ Glass
OCRC Raceway
Old 07-02-2009, 07:18 PM   #11243
rustong's Avatar
I cant believe I found another one on Ebay. Brand new in the box.
http://cgi.ebay.com/ws/eBayISAPI.dll...m=280366495758
Russ
Russ Glass
OCRC Raceway
Old 07-05-2009, 09:18 PM   #11244
TonyK's Avatar
I am running a 84/50 64 pitch for VTA and it works perfectly. Just wanted to thank Indy RC Racer and Team Goodwrench for their suggestions in this thread.
1/12 scale The Formula 1 of RC
TonyK is offline   Reply With Quote
Old 07-06-2009, 09:06 AM   #11245
rustong's Avatar
You are right I didnt notice it at first but a 53 pinion does hit the chassis just below the pinion. A quick dremel grind like you said did fix this.
Russ Glass
OCRC Raceway
Old 07-25-2009, 05:09 PM   #11246
GRIMREAPER's Avatar
Send a message via AIM to GRIMREAPER
im lookin to buy a brushed or brushless tc3 rtr
paypal ready
TEAM 213 / 5 KILLER CLOD CRAWLERS SUPER CLASS / CUSTOM AX-10
RUSTLER XL-5 WIT A TEKIN RS 8.5
HPI SUPER NITRO RS4 (TRADE FOR ELETRIC PART OR RUSTLER PARTS)
GRIMREAPER is offline   Reply With Quote
Old 07-26-2009, 05:43 PM   #11247
rustong's Avatar
Anybody in SoCal running the OC Circuit parking lot races with a TC3. I did see one guy at the Hobbytown race in Corona last month. I would like to compare some notes and or set-ups if you're interested.
Thanks.
Russ Glass
OCRC Raceway
Old 07-26-2009, 05:49 PM   #11248
rustong's Avatar
paypal ready
Found this one for you on ebay.
http://cgi.ebay.com/RTR-RC10TC3-ELEC...3%3A1|294%3A50
Russ Glass
OCRC Raceway
Old 07-26-2009, 11:01 PM   #11249
Thanks.
if i can get my TC3 back from my friend, maybe you can compare the setups eh? Ive seen him drive it with good success and it looks pretty good on the track.
Appreciations to:
Old 07-27-2009, 11:15 PM   #11250
rustong's Avatar
Sounds great, just let me know when you want to talk. I plan on running at the Fusion Hobbies races for now. I might race at some of the other tacks from time to time.
Or if your friend plans on keeping your car for a while longer I would be more then happy to chat with him too.
Thanks.
Russ Glass
OCRC Raceway
Forum Jump
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Exclusive Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
