I would strongly suggest NOT tu buy or use this trinity part, because it isn't properly machined. My english is not good enough to explain exactly how, but if you try one of these once you'll see that they cannot hold the motor properly, because the outer edge of the cam is not thick enough (hope it makes sense) . So the motor will more or less be hanging out of the chassis hole, scratching the road and being not parallel to the chassis, ruining your spur gear.
The only solution i've found is to dremel the stock part. Never had a single problem with this, the part seems quite strong to me. Just take your time , use the biggest diameter sand drum on the dremel , and it will be easy.
Just by putting it in the chassis, you'll see where to remove material. If the cam doesn't go as far as you've allowed it by grinding, when you install the clamp, then grind the outer edge of the cam where it collides with the clamp. This way you'll be able to rotate the cam even further.
Have fun !
