Old 10-20-2008, 11:32 AM   #11161
CSeils's Avatar
Trader Rating: 48 (100%+)
I'll take some pictures. The only way I think to fix this is if the leads are at 90 from the solder points.
You can never go wrong with a Hooters Mini. But Mini Hooters are bad.
--- USVTA National Points Series Member #122 ---
customracingstickers@gmail.com - http://www.rctech.net/forum/painting-designs-graphics-photography/279695-usvta-trans-am-decals.html
CSeils is offline   Reply With Quote
Old 10-21-2008, 11:06 AM   #11162
Bikerbob's Avatar
Send a message via ICQ to Bikerbob Send a message via MSN to Bikerbob Send a message via Yahoo to Bikerbob
is it the sensor lead you are having issues with or the power leads?
I am using a 4300ss and as stated the sensor leads are hardwired in.
If it looks like the votex linked, then you just need a sensor lead where the wires come out at 90deg from the connector- that should not be TOO hard.
But the pictures should help.
James
Bikerbob is offline   Reply With Quote
Old 10-22-2008, 08:47 AM   #11163
DARKSIDE's Avatar
my TC3's are just as good as most anything in TransAm racing(won plenty this summer), and can win with it in 13.5 TC....my batteries range from Orion 4800-3200 and SMC 4000 and they all fit perfectly...Ive run Novak 17.5 bl and I put the rx on the servo for more space..didnt change the car ride at all....here are some pics of my rides...cya
TC3 Forum-wednesday-night-ta-022.jpg   TC3 Forum-wednesday-night-ta-017.jpg   TC3 Forum-img_6270.jpg   TC3 Forum-music-city-championship-011.jpg   TC3 Forum-wednesday-night-ta-001.jpg
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform/RockStar Paint, LLC
THUNDER JAM IX Snowbirds Warm-up
January 21, 2017 Thunder RC Raceway
http://events.rcsignup.com/events/displayEvent.cfm?id=5313
DARKSIDE is offline   Reply With Quote
Old 10-22-2008, 09:52 AM   #11164
CSeils's Avatar
Okay, here are the pictures of my motor problem.
Just wondering what position other manufactures have for their sensor plugs. Novak is not a problem, looking for other alternatives.
Thanks.
Old 10-22-2008, 11:30 AM   #11165
Syber Serulean's Avatar
Trader Rating: 28 (100%+)
Send a message via AIM to Syber Serulean
ahh now i see. Looks like its time to get the dremel out.
Syber Serulean is offline   Reply With Quote
Old 10-24-2008, 08:57 AM   #11166
Bikerbob's Avatar
Thanks.
Show us the front of the motor - where the shaft is.. is there not multi screw holes so that you could rotate the can 90 and then have the solder tabs and the sensor connector about even with the top of the bulkhead?
Then at worst.. all you would have to do is dremel the bulkhead down a few MM to clear a tab or the connector???
NO?
James
Old 10-24-2008, 11:34 AM   #11167
CSeils's Avatar
Tried that. I'm looking into getting a motor that has the leads 90 from the solder tabs. I have a couple of companies that I'm looking into. Either that or I'll pick up a Novak 17.5.
Old 10-24-2008, 06:12 PM   #11168
heretic's Avatar
i suggest you use a dremel
heretic is offline   Reply With Quote
Old 10-24-2008, 06:15 PM   #11169
heretic's Avatar
OR BUY A GM SPEEDO that runs sensorless !!!
Old 10-25-2008, 01:25 AM   #11170
sensorless + 17.5 = BAD.
high turn brushless motors do not produce enoguh back EMF for sensorless to work correctly, thus you will cog. BAD.
Old 10-26-2008, 07:34 AM   #11171
Bikerbob's Avatar
I just got that Hobbywing 9t 35a combo.. it is sensorless and I am very happy with the smoothness.. they also have a 13t but dont go down to 17.5... if you are running somewhere where its a spec motor.. then you will need something approved anyway.. and there are not many if any approved SL motors.
James
Old 10-26-2008, 09:27 AM   #11172
low turn sensorless is fine, high turn sensorless is bad.
Old 10-28-2008, 07:01 PM   #11173
Hey guys, I just got out my old factory team TC3 I had since I was like, 10 (I am 18 now). The car has no upgrades. I am using a stock motor, forgot how many turns, a Novak Super Rooster speed control, and a fairly nice servo, I remember it being around $150. I am not sure what is in now a days, so I was wondering what would be some good upgrades to do to it. The car has been barely driven and everything is in good condition (except for the servo arm I just broke, lol). While on that topic, what is a decent servo arm I should buy?
Thanks.
Karg is offline   Reply With Quote
Old 10-29-2008, 08:23 AM   #11174
Bikerbob's Avatar
Thanks.
Well what are you doing with it Karg? what is your purpose? TC racing? carpet? outdoor asphalt? Drifiting? its all different.
As far as the arm goes, the kit one is pretty good for 90%.. you say you broke it? maybe that gives an idea of what your doing with it. Places that sell Nitro cars will have aluminum arms. I run hitec servos and they make an kit of arms in hard derilin (plastic) that I like.
All factory parts are still available from AE. Do you have the early version without the droop screws? If so.. then it limits the range the car is "good" for. Foam tire racing on a non-droop car is a nightmare.
James
Old 10-29-2008, 09:21 AM   #11175
DARKSIDE's Avatar
Thanks.
like was said, depends on what you use it for...my TC3 was a rtr(pic above) and its great for Trans-am....Im also using a TC3 BMI car for touring
here is a little help...
U.S. Vintage Trans-Am Racing
New to the forum mig rod Electric Off-Road 1 01-05-2008 05:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 02:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 08:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 09:26 PM
SEO by vBSEO 3.5.0
