Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 10-31-2006, 05:08 AM   #11086
trackdesigner71's Avatar
Send a message via AIM to trackdesigner71 Send a message via Yahoo to trackdesigner71
Hey Im takin my TC3 down to Orlando for the Birds, any of you guys run the car down there, and could give me a baseline to start from?
trackdesigner71 is offline   Reply With Quote
Old 11-23-2006, 07:06 AM   #11087
rtherbe's Avatar
Default Carpet tire choices
My buddy and I both own Tc3's and are looking to begin racing them, been bashin' around for years.... I have the Integy set up kit, and Associated, posts plenty of past set up sheets. So I believe I can get that stuff down right. My question regards tires on carpet. What is a good starting point in choosing tires I believe foams are the trend at the local tracks... Thanks
rtherbe is offline   Reply With Quote
Old 11-23-2006, 07:43 AM   #11088
Dbl Pnk/Org for the fronts and Dbl Pnk for the rears seem to be the standard for most carpet situations. At least its a good starting point. TRC and Parma you can use Cyan and Magenta...lot of people going with the Indigos up front.
When I had my TC3, it was durable enough on the asphalt but when I ran it on the carpet it became brittle. Good luck to ya.
wcalaker is offline   Reply With Quote
Old 11-23-2006, 11:38 AM   #11089
rtherbe's Avatar
Thanks to ya
Old 12-08-2006, 10:49 AM   #11090
RandyB's Avatar
very nice FTTC3 for sale
Unmolested FTTC3
RandyB is offline   Reply With Quote
Old 12-09-2006, 09:55 PM   #11091
mach51's Avatar
Trader Rating: 28 (100%+)
my tc3
shopping for RC stuff?
try www.bmainhobbies.com for all your RC needs. if Homer doesnt have what you need he can get it fast!
mach51 is offline   Reply With Quote
Old 12-12-2006, 02:39 AM   #11092
Default the ultimate tc3
Hey all im new to the forum and would like to say hi to all of u.
Having two TC3's and a rolling NTC3 chassis with the V2 suspension on my way and a brushless combo laying around I started to think of making the ultimate 190mm! legal TC3 wich I can fit with 6 cells.
First off:
I would like to know if it's possible to either convert the NTC3 to a 190mm legal electro racecar or outfit the normal TC3 with the ball suspension from the NTC3.
I am planning to make a TC3 platform like this http://overrc.com/news/news2004/firerc10/firerc10.htm
So with the batteries mounted underneath the driveshaft. Does anyone know how this has been done or know the owner of this car so I can contact him?
Thanks in advance!
Keep the TC3's alive!
pwnd is offline   Reply With Quote
Old 02-13-2007, 07:03 AM   #11093
CSeils's Avatar
Default Caster blocks
Just curious what people are using for caster with a stock motor, rubber tire, on carpet?
0° - 2° - 4°
You can never go wrong with a Hooters Mini. But Mini Hooters are bad.
2007, 09 TCS @ Trackside GT3 - Best of Show
2007, 08 TCS @ Trackside Mini - Best of Show
2007 TCS Nationals Mini - Best of Show - Hooters Rule! (customracingstickers@gmail.com)
CSeils is offline   Reply With Quote
Old 02-13-2007, 07:09 AM   #11094
tc3team's Avatar
0° - 2° - 4°
I'd try a 2deg to start with, here are a few setups that you might want to try
http://www.teamassociated.com/racerh...lheim_2003.pdf
team tekin / fusion hobbies / TRF415MSXX / TA05 / rc-area.co.uk / www.horshamrc.org
I've spent half my life r/c racing... and the other half wishing I had started it earlier :D
If you're not having fun whilst racing, you're not racing!
tc3team is offline   Reply With Quote
Old 02-13-2007, 07:18 AM   #11095
0° - 2° - 4°
when we ran rubber tires on carpet, that barry baker setup worked great for me.
LJae is offline   Reply With Quote
Old 02-13-2007, 08:34 AM   #11096
Bikerbob's Avatar
Send a message via ICQ to Bikerbob Send a message via MSN to Bikerbob Send a message via Yahoo to Bikerbob
Originally Posted by LJae
when we ran rudder tires on carpet, that barry baker setup worked great for me.
Does a rudder setup have anything to do with a sailboat?
Guess its just me.. I race rc sailboats as well..
Bikerbob is offline   Reply With Quote
Old 02-13-2007, 08:47 AM   #11097
Is that better.
Old 02-13-2007, 08:57 AM   #11098
CSeils's Avatar
Okay, one more question then.
Should I have more droop in the front or the rear?
Old 02-13-2007, 09:26 AM   #11099
SammyXp's Avatar
More droop in the rear. Lower numerically, though. Default setup is 6 in front and 4 in rear.
SammyXp is offline   Reply With Quote
Old 02-13-2007, 10:00 AM   #11100
CSeils's Avatar
So, just to clarify. Sorry, I'm new at this.
If I have a ride height of 5mm, I should have a total of 11mm lift in the front and 9mm in the rear.
Right?
Forum Jump
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Exclusive Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
