Old 02-14-2002, 08:38 AM   #1096
Regional Moderator
Send a message via AIM to Mike F
Originally posted by Modena AL
Thanks for everyones response. The TC3 I got from my friend has some really gritty bearings in it.
I tried that on my bearings, removing the teflon seals and my bearings were gone after 2 races. I recommend it for the drive train but not the hubs. I have an ultrasonic cleaner Alan if you want to use it. I use some heavy duty degreaser to get the grit out, then I spray it with some Motor Cleaner, dry them with some compressed air then relube them, just a drop, with TRIBO. I don't reseal the bearings in the drive train.
BTW - whos TC3 did you get? Let me know about the UltraSonic cleaner, I'll be in your shop either tomorrow or Saturday
Mike F is offline   Reply With Quote
Old 02-14-2002, 08:45 AM   #1097
wolfeman09's Avatar
Send a message via AIM to wolfeman09 Send a message via Yahoo to wolfeman09
Red > You only have to remove the shield once, you dont take them off and then put them back on. Just like everyone said, put the bearing without the seal on the inside and the seal on the outside
If the seals are on, the oil wil go through just like the motor spray does. Just let it soak in.
The stuff i use to clean the bearings is Liquid Wrench w/ Teflon. Doesnt smell as bad as Motor Spray and i think does a better job. i use the same techniqe as TP, blast them, make sure they turn, but i do soak them overnight no matter what, dry and re-lube.
TP > I may get brave today and remove the shields
wolfeman09 is offline   Reply With Quote
Old 02-14-2002, 05:39 PM   #1098
redsand's Avatar
Send a message via Yahoo to redsand
Originally posted by OUTofCONTROL
Redsnad--Where in NE are you?
used to live at the lionsgate northside of Lincoln.
are ya from there too ?
anyway, guys are any of you using the bearing spacer inside the front steering knuckle ?
redsand is offline   Reply With Quote
Old 02-14-2002, 09:03 PM   #1099
wolfeman09's Avatar
Default 2 Questions....
For the bearings in the transmission, is their a sheild? I looked but just cant seem to find one. this is the one with the rubber seal.
Also, when you are rebuilding your shocks, do you clean shocks with anything, motor spary? Or just pour out the old oil and add in the new....
thanks....
Old 02-15-2002, 02:44 AM   #1100
Corse-R's Avatar
Are you referring to the shim that comes between the two BB on the steering rack? yep, use it. If you lost them, get a reedy motor shim kit and use some, maybe you need to use the intermediate size, the big ones is too thick.
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 02-15-2002, 02:47 AM   #1101
Corse-R's Avatar
Default Re: 2 Questions....
If you got a racer kit, the bearing shield that comes with the kit are rubber seals, meybe the shields of your bearings are removed previously.
When I rebuild shocks I remove the old oil and put a shot of motor cleaner to remove the possible dirt on the inner chamber and put new oil.
Cheers,
Corse-R
Old 02-15-2002, 02:47 AM   #1102
Airwide's Avatar
Send a message via ICQ to Airwide Send a message via MSN to Airwide
Originally posted by moonman
Airwide
I heard you tested some special wings some time ago. Have you found something?
I'm still testing it.
Airwide is offline   Reply With Quote
Old 02-15-2002, 06:04 AM   #1103
TPhalen's Avatar
R/C Tech Charter Subscriber
Yes. Use it. There should also be one in the rear hub carrier, also. When you tighten down the wheel nut, these prevent the bearings from being compressed against the plastic carriers, causing friction on the bearings.
Tony Phalen
UF1 Team Lotus/Renault
RCDriver.com
CompetitionX.com
R Sector / F1 Paint Labs
TPhalen is offline   Reply With Quote
Old 02-15-2002, 08:43 AM   #1104
wolfeman09's Avatar
Default Re: Re: 2 Questions....
I purchased the orginal team kit when the car was released, i do beleive they are rubber sealed, just cant find the shield to take them off
Can i just pop off the rubber?
Old 02-15-2002, 09:23 AM   #1105
linger's Avatar
Default Re: Re: Re: 2 Questions....
Wolfe - the rubber IS the seal. Just poke it with an X-acto knife and it will pop out. Last I checked, your car was already running extremely free.
linger is offline   Reply With Quote
Old 02-15-2002, 09:31 AM   #1106
Buda's Avatar
Default Spur gear ?
Hey all looking for some help pleas. I need a new spur gear as mine is a bit tatty and will get the Rob. Rac. gear I heard that the trinity gear adapter is a good thing to have is this true? And why
Also does anyone know the part number?
Buda is offline   Reply With Quote
Old 02-15-2002, 09:41 AM   #1107
TPhalen's Avatar
Supposedly the alum. gear adapter keeps the gear running true. But, the stock one does the same, it's the gear to begin with that runs un-true. Just make sure you get gears that are of good quality to begin with....
Tony Phalen
RCDriver.com
CompetitionX.com
Old 02-15-2002, 09:51 AM   #1108
Buda's Avatar
Default Tx TP
OK then stock it is cheaper and lighter, well a big purchase is on the horizon, hope fully they will get the integy 16x5 with P/S soon.
Still unsure on getting the whole graphite component kit or just the chassis. Any inputs?
Also getting threaded shocks.
Also what all do I need to upgrade to the lite diffs I heard not all the parts/kit are needed but I am unsure of the conditions of my diff balls. Part numbers willl help a lot here. And not all parts "need" to be ae I will get what works best.
Also on the list is the irs input shafts.
Any other suggestions to a racer model especially in the way of lightening the drive train
And who knows maybe some eye candy like blue screws and integy drive cups.
Old 02-15-2002, 09:54 AM   #1109
Buda's Avatar
Default Bearings
With all the talk of bearings I have another ?
How much better are the teflon bearings? For just a regular driver is it worth the $120?
I also heard dynamite makes a set that are quite reasonbly priced.
Old 02-15-2002, 10:10 AM   #1110
buda,
regardless of what kind of driver you are, you'll benefit from good bearings and i'm sure you can get 'em for less than $120. i use boca bearings in all of my cars, they are just about 100% maintenance free. for the tc-3, they run about $80-$90 bucks (this also includes the steering rack bearings).
diesel31 is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
