Old 09-14-2006, 07:30 AM   #11056
CSeils's Avatar
Trader Rating: 48 (100%+)
Great suggestions.
I'm running on carpet. Yes, I have rear toe in. I was thinking about switching the springs around to see if that would make a difference. Should my set up be neutral (front to rear)?
You can never go wrong with a Hooters Mini. But Mini Hooters are bad.
--- USVTA National Points Series Member #122 ---
customracingstickers@gmail.com - http://www.rctech.net/forum/painting-designs-graphics-photography/279695-usvta-trans-am-decals.html
CSeils is offline   Reply With Quote
Old 09-14-2006, 07:32 AM   #11057
SammyXp's Avatar
Haha, I didn't exactly have the color sequences memorized, either. I'm not *that* big of a nut. I had to check the manual. You're probably right on the shock damping, but I figured it was easier to test the theory with shock tower positions first.
SammyXp is offline   Reply With Quote
Old 09-14-2006, 07:36 AM   #11058
SammyXp's Avatar
Originally Posted by CSeils
Great suggestions.
What about front toe?
Swapping the F/R springs is probably a bit extreme. All other things equal, you may end up with oversteer. But that's not a bad thing on carpet. It's an easy swap, though!
If you're running foams on carpet, I would think you'd be traction rolling with a suspension that soft! What is your ride height?
Old 09-14-2006, 07:37 AM   #11059
santinuchi's Avatar
Default MY CAR
Great suggestions.
I HAVE A TC3 THAT I RUN ON CARPET THATS PRETTY GOOD....
60WT FR SHOCKS WITH #3 PISTONS
PURPLE ASSOC. OR BLACK IRS SPRINGS
SHOCK POSITIONS INNER ON SUSP ARM 1 HOLE IN ON TOWER
F-0 FRONT BLOCK
40WT REAR OIL W/RED SPRINGS ASSOC. AND #2 PISTONS
OUTER HOLE ON ARM IN 1 ON TOWER
R+2+3 BLOCK IN REAR WITH AN F ON THE INSIDE BLOCK FOR 1DEGREE OF TOE
5MM RIDE HEIGHT ALL AROUND....
CAR'S GOOD.....
IF YOU WANNA PLANT THE REAR END A BIT MORE LOWER THE REAR ROLL CENTER.
santinuchi is offline   Reply With Quote
Old 09-14-2006, 07:41 AM   #11060
santinuchi's Avatar
Default .
i'M CONFIDENT ENOUGH IN THAT SETUP TO BE TAKING TO THE IIC IN VEGAS NEXT WEEK....
Old 09-14-2006, 07:47 AM   #11061
SammyXp's Avatar
If you wanna try something entirely new, that setup Santinichi posted sounds pretty good.
Old 09-14-2006, 08:01 AM   #11062
CSeils's Avatar
So your saying that I need to go stiffer?
Sorry, forgot to mention that I'm running rubber tires on carpet.
Ride height is just above 5 mm. Front toe is maybe 1 (car is at home, I am at work)
Old 09-14-2006, 08:04 AM   #11063
santinuchi's Avatar
Default uh oh
setup i posted is for foams....sorry
Old 09-14-2006, 08:38 AM   #11064
SammyXp's Avatar
Oh ok, no - for rubber tires on carpet stick with your current base setup. I would first try moving the front shock to the middle hole. It's a quick and easy way to test the effect of softening both damping and spring rates.
I assume you've got 1 degree toe *out*, right?
Old 09-14-2006, 08:46 AM   #11065
CSeils's Avatar
actually it's toe "in".
Old 09-14-2006, 09:15 AM   #11066
SammyXp's Avatar
I run toe in on really big tracks to gain some high speed stability, but you'll have better turn in with 0-1 degrees toe out. Might want to wander just a little bit on very long straights though, particularly if you run mod.
Make one change at a time, though. So you know what to attribute the change to.
Old 09-14-2006, 01:07 PM   #11067
X-Ray domination
http://www.teamxray.com/teamxray/new...4fa0211c645359
Still going strong
They are still following that 'good old' noise
Jan van Steeg is offline   Reply With Quote
Old 09-14-2006, 01:15 PM   #11068
SammyXp's Avatar
Originally Posted by Jan van Steeg
X-Ray domination
Still going strong
Congratulations on your win! Showing the world that the TC3 can still hang with the high dollar new cars.
I love how they referred to the TC3 as "vintage", haha...
The Stock class saw Jan van Steeg on pole with a vintage Asso TC3 ahead of Vasco Christiaanse and Richard Oversloot with an FK05.
Old 09-24-2006, 01:55 PM   #11069
TC3 is still unbeatable
TC3, they still have to follow it
do you hear it?
try to follow
TC3, dutch national stock champion 2006
Old 09-25-2006, 05:37 AM   #11070
do you hear it?
try to follow
I saw it,
Well done Jan!!
Rob.
Rob Janssen is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
