Like Tree4Likes
Old 08-15-2006, 09:03 PM   #11041
anthony390's Avatar
Send a message via AIM to anthony390
has anyone gotten the tc3 under 2 pounds?
anthony390 is offline   Reply With Quote
Old 08-16-2006, 08:52 AM   #11042
CarissaF's Avatar
Smile
If any hardcore tc3 guys are interested. I'm trying to sell my tc3. It's in good condition. I have pics. It would be a good racer, backup spare. I'm looking for $150. I can only ship to the lower US 48 states. I need cash to fix my real car! PM me if your interested. Thanks.
CarissaF is offline   Reply With Quote
Old 09-08-2006, 02:00 PM   #11043
SammyXp's Avatar
Are you serious? With running gear?
SammyXp is offline   Reply With Quote
Old 09-08-2006, 06:36 PM   #11044
anthony390's Avatar
haha yeah i was just wondering if not, what was the lightest anybody has gotten it???
thanks
Old 09-10-2006, 02:59 PM   #11045
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
I know this has been asked what is a starting point for stock 64p
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 09-11-2006, 05:11 AM   #11046
For stock I run 100 spur and 30 to 36 depending on tire size and track. Monster motors at about .95 rollout Blue motors at about 1.1 rollout
rockdog200 is offline   Reply With Quote
Old 09-11-2006, 02:13 PM   #11047
Trader Rating: 38 (100%+)
any one have a good source to pic up aftermarket hop ups for a tc3?
maddog23 is offline   Reply With Quote
Old 09-11-2006, 02:41 PM   #11048
I have a lot of new stuff for a TC3. What are you looking for?
DOTMAN is offline   Reply With Quote
Old 09-11-2006, 09:26 PM   #11049
AUSSIE BOB's Avatar
Default BMI TC 3
Taffyjrn5, i have a TC3 BMI that is a rocket, handles like it is on rails. Just so happens i have a spare BRAND NEW BMI chassis (1 X 5 min race with protection under it) with as new running gear all set up ready to go for sale. I know you live in Perth so i will not drop it off, but give us a call. $240 plus postage, just add radio motor battery and body.
05 lives
AUSSIE BOB is offline   Reply With Quote
Old 09-14-2006, 06:04 AM   #11050
CSeils's Avatar
Trader Rating: 48 (100%+)
What can I do to correct my car from pushing? I "think" I know what to do but I wanted to check to see if I'm right. I can go down the straight at full throttle into a right hand sweeper and the car just doesn't want to turn.
My set up now is:
Front - 50w, blue spring, 4 mm droop, shock mounts outside holes,
Rear - 30w, silver spring, 5.5 mm droop, shock mount middle hole,
Any comments and ideas are welcome, thanks.
You can never go wrong with a Hooters Mini. But Mini Hooters are bad.
--- USVTA National Points Series Member #122 ---
[email protected] - http://www.rctech.net/forum/painting-designs-graphics-photography/279695-usvta-trans-am-decals.html
CSeils is offline   Reply With Quote
Old 09-14-2006, 06:38 AM   #11051
SammyXp's Avatar
My set up now is:
Are you running any toe?
Have you tried the same setup, with the rear shock on the outside hole?
Old 09-14-2006, 06:55 AM   #11052
nagatahawk's Avatar
your cars seems out of balance the front is way stiffer than the rear.
change one thing at a time: for asphalt
go softer spring in front. Blue to gold.
try that, if it still over steers go lighter on shock oil.
go to 30 wt oil in shocks.
for carpet go stiffer in the rear. blue shocks and 50 wt oil.
rear droop increase will give you more off throttle steering.
front droop increase will give you more rear traction because of weight transfer to the rear. I would leave this alone if your looking for more steering.
I hope this helps
wn
nagatahawk is offline   Reply With Quote
Old 09-14-2006, 07:03 AM   #11053
SammyXp's Avatar
Gold (19.5lbs/in) is stiffer than Blue (17lbs/in). The factory setting has the front stiffer than the rear. His is actually the same as factory in rear and one step softer in front. You'd think this would give him a little more steering. Being on the middle hole in the rear is going to allow a little more weight transfer to the rear under throttle, though.
Looks like he's already got 1mm less droop in front than the 'standard' setup, though.
Old 09-14-2006, 07:16 AM   #11054
nagatahawk's Avatar
thanks,
I just pulled by tc3 from mothballs and forgot the color sequences. I will check them with a micrometer.
I would go to lighter oil in front shock. then try the shock positions
most set ups i have seen and used had same oil weight in front and rear.
I will give my old tc3 a run this week end to see how it fares against all the hi tech cars out there. it feels pretty good so far out side the house, but you know how that goes.
wn
Old 09-14-2006, 07:20 AM   #11055
santinuchi's Avatar
Default hmmm
carpet or asphault?
santinuchi is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
