Old 03-20-2006, 10:49 PM   #10951
Trader Rating: 76 (100%+)
Default Breakage
Hi All
This may of been covered in earlier post but i looked and couldnt find
I am running a 5.5 in my TC3 There isnt a race day that doesnt pass when i am not breaking a dog bone thru the connecting pin at the axle.
I am usuing a front irs spool and composite bones. Guess this is where the trouble lies?? Would this also do the same thing with alloy front bones( thinking they would most likely twist anyways ) or would i be better going back to a ball diff. or is there other bones that canbe used???
Any help or advice would be greatly appreciated
Do you won't free Post on your items, PLEASE contact AUSTRALIA POST to confirm your eligibility and enter your code number here. Otherwise standard rates apply. Why don't people haggle or complain with o/s postage but always want local postage for free or moan like their left hand was cut-off, Come on guys Aus post do have set costs , it isn't the seller trying to rip you off.Items must be sold. All reasonable offers considered
addicted is offline   Reply With Quote
Old 03-21-2006, 04:34 PM   #10952
anthony390's Avatar
Send a message via AIM to anthony390
well i can tell you that the composite ones will always practicly crack with the 5.5
but the suspension also plays a roll on this
when the wheel is lifted off the ground during cornering then when the tire suddenly goes back on the ground there is a QUICK tension that was applied to the drivetrain thus breaking or twisting the dogbone
ill try the ft tc4 dogbones and if your still messing up dogbones...ill play around with the suspension
hope it helps
P.S.....NICE AVATAR
anthony390 is offline   Reply With Quote
Old 03-22-2006, 02:19 AM   #10953
bubbles's Avatar
I highley praise using the blue aluminium TC4 bones. They're actually stronger than the MIP shiney CVD's that everyone would upgrade to.
The ball diff would have much more "give" in the drivetrain, and you wouldn't have that hard impact of twist from the motor to the wheel gaining traction.
bubbles is offline   Reply With Quote
Old 03-22-2006, 03:32 AM   #10954
Thanks for the feed back
I will try the tc4 alloy bones and see what happens if not ill go back to the ball diff
Old 03-22-2006, 08:11 PM   #10955
anthony390's Avatar
your welcome
Old 03-23-2006, 02:16 AM   #10956
bubbles's Avatar
Make sure you're using adequate amounts of black grease in the CVD. Mine are looking a little dry, and when running the One-Way, it wears the aluminium bones pre-maturely.
Old 03-29-2006, 06:48 PM   #10957
RED-LINE M03's Avatar
Trader Rating: 127 (100%+)
Default Bmi TC3
Can some body that has been running the BMI TC3 tell me if the older TC3 with the BMI chassis is better than the more currerent RDX's and Cyclones. I've been noticing that the older BMI TC3 have been winning a lot of races @ are local tracks. Can some on tell me why the older car is handling better than the more current cars. I know the ackerman is awesome on the TC3.
Any help would be great.
A battery pack a day keeps the stress away
RED-LINE M03 is offline   Reply With Quote
Old 03-29-2006, 07:25 PM   #10958
ScottyP's Avatar
I can't comment on direct driving comparisons with RDX, MSX, Cyclone, T2 etc, but what I can say is that my BMI TC3 is easily a match for any of these cars in stock on asphalt.
The BMI car is beautifully balanced and easy to tune and drive. I was thinking of 'upgrading' to a FTTC4, but really can't justify it with the 'old' car running so strong!
Cheers,
Scotty P.
ScottyP is offline   Reply With Quote
Old 03-29-2006, 07:29 PM   #10959
RCSteve93's Avatar
all you need to win is skill and a hot setup.
rm -rf /windows
RCSteve93 is offline   Reply With Quote
Old 03-29-2006, 07:30 PM   #10960
RCSteve93's Avatar
were do you guys mount your AMB personal transponders on your TC3.
rm -rf /windows
Old 03-29-2006, 08:44 PM   #10961
trackdesigner71's Avatar
Send a message via AIM to trackdesigner71 Send a message via Yahoo to trackdesigner71
What size are the servo mount screws for the TC3? I was wondering if I could pick up a comparable type of screw at a hardware store and use those to install my servo (with mounts) in my TC3.
trackdesigner71 is offline   Reply With Quote
Old 03-30-2006, 02:45 AM   #10962
tc3team's Avatar
Ive found that the standard screws strip quite easily in the servo mounts. Its better to use the same length as the original ones,but with a courser thread.
Then use some threadlock for the best result.
Just make sure you have a good set of allen drivers!
tc3team is offline   Reply With Quote
Old 03-30-2006, 03:40 AM   #10963
bubbles's Avatar
On top of the servo...
4-40 thread, and I believe it's 3/8 of an inch long.
Old 03-30-2006, 05:57 AM   #10964
RCSteve93's Avatar
If you use the aluminum servo mount the servo will be rock solid.
rm -rf /windows
Old 04-16-2006, 02:56 PM   #10965
anthony390's Avatar
i am now using metric nuts for my wheel axles
well yea i like it better now cause i can bolt on any wheel i want
New to the forum mig rod Electric Off-Road 1 01-05-2008 05:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 02:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 08:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 09:26 PM
SEO by vBSEO 3.5.0
