Old 02-13-2002, 09:23 PM   #1081
over gear's Avatar
Trader Rating: 15 (100%+)
Originally posted by Modena AL
I bought a TC3 from a friend and all the bearings in the hub carriers were missing the teflon shields off one side...not sure why . How should I go about cleaning these?
Modena: the shield create drag on the bearing.... one shielding is good enough IMO. just make sure the seal is facing outside.
I bought an ultrasonic jewelry cleaner from Target... $19. that thing shakes all the dirt out of the bearing...
over gear is offline   Reply With Quote
Old 02-13-2002, 09:30 PM   #1082
Thanks over gear. I figured it was best to face the shield outside to keep dirt out. Should I relube the bearings with bearing oil or WD-40 or something like that after using a ultrasonic jewelry clearner?
Modena AL is offline   Reply With Quote
Old 02-13-2002, 09:37 PM   #1083
wolfeman09's Avatar
Send a message via AIM to wolfeman09 Send a message via Yahoo to wolfeman09
Red > I do not take the shields off, to much of a pain in the ass like you said. I have the bearing blaster to help clean the bearings, but i dont use motor spray. i picked up a can of, cant think of the name now (will get it for everyone in the morning when i go to the garage), with Teflon to spray the bearings with. Once they are sprayed, i spin them to get all the dirt out. I then soak em in the same stuff i sprayed overnight. When i take them out, i lube them with trinity bearing oil. They come out nice and smooth. the teflon in the spray really helps.
I am thinking of getting the sparkle from Integy to help with the cleaning of the bearings.
wolfeman09 is offline   Reply With Quote
Old 02-13-2002, 09:48 PM   #1084
IF you don't mind doing a little maintenance, remove all the shields. You will have the ultimate friction free drivetrain.
OUTofCONTROL is offline   Reply With Quote
Old 02-13-2002, 09:54 PM   #1085
over gear's Avatar
I don't put anything for relube..... i think oil or lube will attract dirt...
Old 02-13-2002, 10:00 PM   #1086
Thanks over gear. I'm going to try that jewelry cleaner out in the near future. This years season starts in 3 weeks. Gotta be fast!!!
Old 02-13-2002, 10:56 PM   #1087
rccarracer's Avatar
You must relube your bearing or you can say good bye to the bearing pretty quickly as the friction will slowly start to destroy them!!
They also will not be as smooth!!
rccarracer is offline   Reply With Quote
Old 02-13-2002, 11:05 PM   #1088
over gear's Avatar
what's the best oil for bearings?
Old 02-14-2002, 12:40 AM   #1089
Corse-R's Avatar
I've used the same over the last years. Trinity Royal lube (I have 4 bottles from about 2 or 3 years, I have reserve of oil for another 2 or 3 years more). . I have one teflon seal (usually the same that goes on the innards of the hub carrier, diff housing, input shafts, etc) I clean with rpm bearing blaster and put a dab of oil in the side that don't have shield).
Sincerely I'm not a big friend of Trinity stuff, but I reckon that some products from their catalog are fine.
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 02-14-2002, 01:09 AM   #1090
redsand's Avatar
Send a message via Yahoo to redsand
wolf, how could the oil get inside the bearing if the seals are still in it ?
redsand is offline   Reply With Quote
Old 02-14-2002, 01:41 AM   #1091
redsand's Avatar
that's exactly I'm going to do. screw the seals.
i'd rather clean the bearings once every 5 or 6 runs, simply just soak 'em or spray 'em with wd40 or acetone than have to remove 8 seals every two months or so.
Old 02-14-2002, 05:45 AM   #1092
Redsnad--Where in NE are you?
Old 02-14-2002, 06:10 AM   #1093
TPhalen's Avatar
R/C Tech Charter Subscriber
YOU MUST RELUBE THE BEARING!!!! Normally, we remove the inner shield (wolfy...it only takes 2 seconds??!?!?!), spray out the bearing and then soak it for a while in motor spray. Shake it around every now and then (or the jewelry cleaner works good, too!). Remove the bearing and slide it onto a shaft (one it came off of) and check to see how it spins. Is it free? Does it make grinding sounds? If it does, not clean...soak some more. Once that's done, remove them from the soaking solution, put them on a CLEAN cloth to absorb the remaining solution, and put ONE drop of Trinity's Royal Oil. As Corse-R said, it seems to be the best working stuff.
You can leave one shield off (redsand, yer brave!!! ) and just slide them back on and yer done!
Tony Phalen
UF1 Team Lotus/Renault
RCDriver.com
CompetitionX.com
R Sector / F1 Paint Labs
TPhalen is offline   Reply With Quote
Old 02-14-2002, 07:54 AM   #1094
Thanks for everyones response. The TC3 I got from my friend has some really gritty bearings in it.
Old 02-14-2002, 08:30 AM   #1095
Regional Moderator
Send a message via AIM to Mike F
I used it at regionals, where it was legal
As of 6 o'clock tonight, we had 32R's in stock. I would hurry though...TnT is approaching fast! I got my tires over a month ago
BTW I knew that comment was going to come from someone at the track...it was only a matter of time, lol
It's all good Alan , I've seen you race and you don't need Traction Compound, your car is always dialed. It's legal this year .
I'll pick up a set either tomorrow or Saturday. Has Jason dropped off that 1700 pack?
Mike F is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
