Old 02-01-2006, 02:47 AM   #10876
ScottyP's Avatar
OK all you TC3 gurus, what's wrong with this picture?
I've been told everything from it's a oneway from an NTC3, to I need different outdrive bearings (with a larger ID to fit over the oneway bearings) to I have an 'old' diff housing and the newer ones are wider!
What gives?
Cheers,
Scotty P.
ScottyP is offline   Reply With Quote
Old 02-01-2006, 06:08 AM   #10877
It is a Nitro part, not electric.
JWATT is offline   Reply With Quote
Old 02-01-2006, 06:19 AM   #10878
To use a one way in a TC3 you need the bearings that fit - they are not the same as the standard outdrive bearings.
DLM2005 is offline   Reply With Quote
Old 02-01-2006, 08:02 AM   #10879
Send a message via AIM to R/C Anonymous
push the bearings all the way on
Geoff C.
R/C Anonymous is offline   Reply With Quote
Old 02-01-2006, 01:23 PM   #10880
ScottyP's Avatar
More conflicting opinions!
According to AE's web site, the part number for TC3, NTC3 and TC4 oneway is the same. Did they change at some point?
So you're saying the bearing need to fit OVER the one-way bearings that protrude from the housing? That would make sense. Anyone have the size so I can order some?
Pure genius... whay didn't I think of that!
Cheers,
Scotty P.
Old 02-01-2006, 01:47 PM   #10881
You need the special metric bearings for the one way (standard diff bearings ID is too small). My mistake, the diff housings are the same, it is the outdrives that are different between the nitro and electric.
Old 02-01-2006, 02:51 PM   #10882
the original TC3 one-ways fit the stock bearings in the diffs.
the Heavy Duty one-way(Yokomo) takes bearing with a larger I.D. to fit
Geoff C.
Old 02-01-2006, 03:07 PM   #10883
Aries326's Avatar
Trader Rating: 19 (100%+)
What gives?
Cheers,
Scotty P.
Scott, I gave you the wrong info. I double checked my bearings on my front one-way and they are the same diameter as the regular bearings but the inside diameter of the hole is BIGGER. R/C Anonymous is correct. The bearings I've been using with my front one-way are not the stock ones, they are the larger metric ones used with Yokomo cars. I checked it out after I saw the picture of your one-way. We do have the same one!
Point1Drift
http://www.driftercentral.com
Aries326 is offline   Reply With Quote
Old 02-04-2006, 10:34 PM   #10884
JTM29's Avatar
Hey,
I bought a Tamiya J 540 motor and realised it doesnt fit.. What 540 motors do?
JTM29 is offline   Reply With Quote
Old 02-04-2006, 10:45 PM   #10885
slippery49's Avatar
to get any 540 satd motor to fit you will need to drill/file/ream the motor mount cam.
These are made for everything other then the 540J
slippery49 is offline   Reply With Quote
Old 02-05-2006, 12:16 AM   #10886
TAO3RS's Avatar
Send a message via Yahoo to TAO3RS
Originally Posted by JTM29
Hey,
it really wouldnt fit, because the can is longer..
try any rebuildable 23t motor.
TAO3RS is offline   Reply With Quote
Old 02-05-2006, 01:05 AM   #10887
NOZ69's Avatar
Nah they do fit...as been said B4 you just have to drill/ream out the motor cam.
Just be carefull not to take out too much.
Cheers
FT TC4, LRP TC Sphere, LRP X-11 13.5
SC10 4x4
M03M Suzuki Swift
Power by Feral
Sanwa MX-3 FHSS
NOZ69 is offline   Reply With Quote
Old 02-05-2006, 01:49 AM   #10888
TAO3RS's Avatar
what im trying to say is.. if ther will be no modifications in the motor cam, the tamiya 540j motor wouldnt really fit.
budget and plan wise settle for a rebuildable 23turn. IMO
Old 02-05-2006, 05:29 AM   #10889
csdspeed's Avatar
Send a message via Yahoo to csdspeed
Hey guys, I need urgent help. I posted here before if tc4 differential outdrives fit and yes it does. But now I need to know if the steel/aluminum outdrives for NTC3 can be used on the TC3. Really Need to know. Thanks.
csdspeed is offline   Reply With Quote
Old 02-05-2006, 07:18 AM   #10890
DaveW's Avatar
Nope... the outdrives for the NTC3 are longer... the balls and gear will fit but the diff once installed will not work with your TC3 CVD's.
- DaveW
...you better run like im booger flickin...
DaveW is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
