Old 01-06-2006, 12:03 PM   #10816
http://www.bmiracing.com/
I have an extra chassis if you can't find .........
DLM2005 is offline   Reply With Quote
Old 01-06-2006, 12:50 PM   #10817
How much are you looking to get for the BMI chassis? I see they offer different colors, which is yours?
birel1 is offline   Reply With Quote
Old 01-06-2006, 01:09 PM   #10818
I believe they are only making them only in black now (gloss not satin) I have an extra satin black - the top in in exc cond - bottom chassis has typical asphalt marks - would trade for a couple f and f+2 front arm mounts and a couple sets of front and rear arms....if interested..........about $40 worth of parts....chassis has nerf wing also.....
Old 01-06-2006, 02:02 PM   #10819
PaZ
PaZ's Avatar
SHE WILL NEVER DIE NEEEEEEVEEEEEEEEEER i got 2 one i race each week and one i drift when ever i can long live the TC3
Xray T2 0079
Mardave V12 VRX
Team T.J Cells
CT Race Bodies
PaZ is offline   Reply With Quote
Old 01-06-2006, 04:40 PM   #10820
Do you have digital photos of the chassis that you can send me? If it looks good, I may agree to your request. Is the chassis straight?
birel1@yahoo.com
Old 01-06-2006, 05:15 PM   #10821
anthony390's Avatar
Send a message via AIM to anthony390
i also really want to get a BMI top plate for my tc3 but i was just thinking to put the FT tc4 top plate on my tc3 (i know all what i need already )
anthony390 is offline   Reply With Quote
Old 01-06-2006, 05:24 PM   #10822
TAO3RS's Avatar
Send a message via Yahoo to TAO3RS
nice chassis..
do they sell the top plate alone? tnx
TAO3RS is offline   Reply With Quote
Old 01-06-2006, 07:58 PM   #10823
anthony390's Avatar
Originally Posted by TAO3RS
nice chassis..
sorry but who are you talking too
Old 01-06-2006, 09:03 PM   #10824
Trader Rating: 27 (100%+)
Send a message via AIM to John Stranahan
This question was asked a few months ago. Did not find an answer so here is a list of parts required to convert a TC3 to TC4. The new chassis addresses 3 main problems. One the new motor mount should not warp the right rear corner of the chassis upward from motor heat. This messes up the tweak in hot climates where motor heat is more of a problem. The new chassis puts todays heavier batteries (high capacity NiMH) closer to the center of the car for better side to side balance. You get rid of the old steering which tends to build up dirt on center and causes loss of trim. The old rack can be cleaned regularly with the backside of an X-acto knife. Anyway I got a good deal at Stormer as the graphite chassis and chassis braces and shock towers came together in a kit at a reduced price.
ASC31003 TC4STEERING RACK 1 $4.50 $4.50
ASC31010 TC4 SUSPENSION ARM MOUNT SHIMS BALLS. 2.95
ASC31022 TC4STEERING BELLCRANK POSTS ~ 1 $4.50 $4.50
ASC31025 TC4 SUSPENSION ARM MOUNT SET 1 $4.50 $4.50
ASC31111 TC4 Factory Team Servo Mounts, carbon 1 $3.95 $3.9
ASC31042 TC4 MOLDED CARBON COMPONENT SET 1 $24.99 $24.99
ASC31019 TC4 DRIVE SHAFT ACCESSORIES 1 $3.50 $3.50
ASC31046 TC4 MOTOR MOUNT: blue aluminum 1 $14.95 $14.95
ASC31026 TC4 Front BUMPER 1 $4.50 $4.50
ASC2225 NITRO TC3 BUMPER TOP BRACE 1 $2.50 $2.50
ASC2229 NITRO TC3 Steering RACK HARDWARE SET 1 $5.95 $5.95
ASC31024 TC41NNER HINGE PIN SET 1 $2.95 $2.95
Subtotal, excluding shipping: $80
Add 4 Asc 3916 3/16 x 5/16 ball bearings (diff bearings work) for ball bearing steering. $10.00
I finished the conversion of my TC3 to TC4 with Associated parts. Here are some additional items you might need as well as some additional items that are different on the TC4
ASC 2230 TC4 front Body Posts, The old rear ones will work. The fronts too if you want to redrill them. They will be oversized in diameter though.
ASC7874 and 6926. These are 5/8 and 7/16 inch Socket head capscrews for the motor mount clamp. The old motor mount clamp from the factory team kit will fit, but the new one lets the motor breathe a little better.
ASC 2229 listed above for the new steering links was short two bushings to work on the TC4 so you will need at least two more bearings or bushings 3/16 x 5/16.
The New TC4 has thicker input shaft cups for the diff, but they are not larger outside diameter. The new driveshaft thus has a smaller ball on the end. The old shaft will not fit the new cups or vice versa. If your shaft is the least bit damaged get a new shaft and use the newer cups.
Photo of the finished conversion on my post 10843. Here is a link
http://www.rctech.net/forum/showthre...ge#post2064815
John Stranahan is offline   Reply With Quote
Old 01-07-2006, 04:29 AM   #10825
TAO3RS's Avatar
its for everyone..
Old 01-07-2006, 09:05 AM   #10826
Aries326's Avatar
Trader Rating: 19 (100%+)
nice chassis..
BMI used to sell the top plate alone. I'm not sure if they still do. I think theu just sell the complete kits now.
Point1Drift
http://www.driftercentral.com
Aries326 is offline   Reply With Quote
Old 01-07-2006, 10:48 AM   #10827
PaZ
PaZ's Avatar
y do u want a top plate for a TC3 ive had the one of my warpspeed off it and it did sweet fa. I cant see it stiffing it up anymore than it is its solid lol
Xray T2 0079
Mardave V12 VRX
Team T.J Cells
CT Race Bodies
Old 01-07-2006, 03:44 PM   #10828
trackdesigner71's Avatar
Send a message via AIM to trackdesigner71 Send a message via Yahoo to trackdesigner71
Random ?: is the servo horn supposed to be vertical or horizontal and what about the ball cup? I want to make sure that I have that installed properly.
Random ? #2: when installing the receiver, what do you do to keep the antenna wire from going down through the hole in the chassis bottom so you can put it through the antenna tube?
trackdesigner71 is offline   Reply With Quote
Old 01-07-2006, 04:51 PM   #10829
PaZ
PaZ's Avatar
from the middle hole to the top whole the gap should be 3mm to the right if lookin from the front according to the book infront of me the top of the servo horn is 3mm to the right of centre hole
#2 i just used a screw driver when i install it to stop it going down but im cheap
Xray T2 0079
Mardave V12 VRX
Team T.J Cells
CT Race Bodies
Old 01-07-2006, 09:32 PM   #10830
TAO3RS's Avatar
okay thanks!
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
