Old 12-15-2005, 11:54 AM   #10741
PaZ
PaZ's Avatar
y couldnt warpspeed have done that lol
Xray T2 0079
Mardave V12 VRX
Team T.J Cells
CT Race Bodies
PaZ is offline   Reply With Quote
Old 12-15-2005, 12:46 PM   #10742
Send a message via AIM to R/C Anonymous
Speaking of Warpspeed....if anyone has a Warpspeed Demon TC3 or chassis they want to sell...PM me please, thanks
Geoff C.
R/C Anonymous is offline   Reply With Quote
Old 12-15-2005, 12:50 PM   #10743
gmintimidator's Avatar
I pulled my seals out and soaked them in an integy bearing washer filled with brake cleaner. It has an offset motor on it so it vibrates the crap out of them. I got a much better job now that I removed the shileds and the car is a lot easier to roll. I seen another racer with no shields on his diff bearings, but I can't afford to destroy them... I've heard it's ok to run the shields on the external side only which makes sense for the outdrives but the diff bearings looked sealed enough by the housing that I should be able to get away with it
I also use a drop or two of the royal oil to lube them with and have been doing the clean and relube on a 2 week interval racing once a week.
gmintimidator is offline   Reply With Quote
Old 12-15-2005, 01:12 PM   #10744
PaZ
PaZ's Avatar
same as what i do but i cant affort a bearing cleaner vibrator box thingy lol
P.M sent
Xray T2 0079
Mardave V12 VRX
Team T.J Cells
CT Race Bodies
Old 12-15-2005, 01:14 PM   #10745
P.M sent
right back atcha
Geoff C.
Old 12-15-2005, 01:23 PM   #10746
PaZ
PaZ's Avatar
and again
Xray T2 0079
Mardave V12 VRX
Team T.J Cells
CT Race Bodies
Old 12-15-2005, 03:01 PM   #10747
Just got my new BMI TC3 chassis from the "new batch" that Jason made and all I can say is that it is a really great looking chassis (I have the older one also) - and it appears it might be a bit lighter - haven't weighed it yet.......The new graphite material that was used in this batch is fantastic looking (and we all know how well BMI stuff works on the track!!!!!!!)
DLM2005 is offline   Reply With Quote
Old 12-15-2005, 03:06 PM   #10748
I thought that Intedy Sparkle bearing cleaner was a great deal at $18.95
Old 12-15-2005, 03:21 PM   #10749
PaZ
PaZ's Avatar
groovey how far back from the orignal position of the STD TC3 steering do you have to drill to fit the TC4 swing rack?
Xray T2 0079
Mardave V12 VRX
Team T.J Cells
CT Race Bodies
Old 12-15-2005, 04:43 PM   #10750
anthony390's Avatar
Send a message via AIM to anthony390
Originally Posted by gmintimidator
Anthony, did you have a chance to look at my setup? I posted it on the 12th. I got a sway bar installed for this week.
I am also working on freeing up my drive line. Will the Teflon bearings be ok in the diff housings without seals? Is it ok to remove the inside seal of all the rest of the bearings? I have the car on my bench and it spins so much easier now.
Daryll
actually yes but i think i forgot to read somthing like
well what do you want me to do
anthony390 is offline   Reply With Quote
Old 12-15-2005, 05:03 PM   #10751
No worries, I was just wondering if you had any comments or suggestions
Daryll
Old 12-15-2005, 05:12 PM   #10752
anthony390's Avatar
seems ok to me
but the real question is to you
what do you feel that is a problem to you or is there somthing that you would like to have or change?
Old 12-15-2005, 06:04 PM   #10753
I am having trouble with the car rolling over onto it's lid when I drive the car hard. I can just about hit the lap times of the top cars, within 2 tenths but the car will usually roll right over over when I drive it harder. You were suggesting stiffening up the suspension or a sway bar.
Daryll
Old 12-15-2005, 06:24 PM   #10754
anthony390's Avatar
yup so that should be it
Old 12-15-2005, 06:37 PM   #10755
How would you go about it? I can't figure out if it's the rear or the front or both laying over. Do I go up a spring rate all around or just go up on the oil in the rear?
New to the forum mig rod Electric Off-Road 1 01-05-2008 05:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 02:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 08:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 09:26 PM
SEO by vBSEO 3.5.0
