Old 12-13-2005, 10:44 AM   #10726
CSeils's Avatar
Trader Rating: 48 (100%+)
Does anyone have any suggestions? I'm having a pushing problem. I am running rubber on carpet and can't get the car to turn the way I think it should. I'm using Takeoff 27's tires, no sway bar. I've tried changing many things to no avail. Here is my current set up. Any suggestions are helpful, but I might have already tried them.
Front:
Ball diff
2 deg caster
0 toe in
-2 camber
middle hole in tower
80 wt
#2 piston
copper spring
ride height 5.5mm
droop 5
Rear:
-1 deg camber
outside hole in tower
50wt
#2 piston
red springs
ride height 5.2mm
droop 6-7
You can never go wrong with a Hooters Mini. But Mini Hooters are bad.
--- USVTA National Points Series Member #122 ---
customracingstickers@gmail.com - http://www.rctech.net/forum/painting-designs-graphics-photography/279695-usvta-trans-am-decals.html
CSeils is offline   Reply With Quote
Old 12-13-2005, 11:04 AM   #10727
Toma2525's Avatar
What is a TC3.5????
What steering rack upgrade?
I have an Team TC3 that i am looking to break out of retirement. It's been sitting stock collecting dust for a while now.
Yokomo BD7...TQRC Raceway Chino, CA
Toma2525 is offline   Reply With Quote
Old 12-13-2005, 11:28 AM   #10728
onnetz's Avatar
Front:
Ball diff
2 deg caster
0 toe in
-2 camber
80 wt
#2 piston
copper spring
ride height 5.5mm
droop 5
Rear:
-1 deg camber
50wt
#2 piston
red springs
ride height 5.2mm
droop 6-7
even out the ride height between front and rear and try 50wt front and rear..
with lower ride height in the rear and being so stiff in the front, all the weight is on the rear..
onnetz is offline   Reply With Quote
Old 12-13-2005, 12:44 PM   #10729
PaZ
PaZ's Avatar
steering upgrade= TC4 rack. and running rubber on carpet like me you need to really soften up, i got 50wt front 50wt rear red spring front silver rear but were using control sorex 24R's and its handling fine
Xray T2 0079
Mardave V12 VRX
Team T.J Cells
CT Race Bodies
PaZ is offline   Reply With Quote
Old 12-13-2005, 01:30 PM   #10730
Toma2525's Avatar
is there much modification you need to do to get the TC4 steering rack on the TC3? Do you know what parts i need? thanks.
Old 12-13-2005, 04:11 PM   #10731
You just need the Nitro TC3 steering rack. There's a parts set for it that comes in 2 or 3 bags. To make it work on the TC3 tub chassis, you have to do some fileing of the support castings near the current steering rack. If your doing it on a carbon chassis like IRS or BMI then you just need to drill some new mounting holes in the right position.
deeman is offline   Reply With Quote
Old 12-13-2005, 04:17 PM   #10732
anthony390's Avatar
Send a message via AIM to anthony390
a tc3.5 is simply a tc3 that has some tc4 parts eqipped on to it
thats what i have
anthony390 is offline   Reply With Quote
Old 12-13-2005, 06:24 PM   #10733
anthony390's Avatar
for people who run steel diffs...
are you guys driving the steel diffs with 3/16" by 5/16" BEARINGS or with 3/16" by 5/16" BUSHINGS(the goldish copper bushing)
thanks
Old 12-14-2005, 02:34 AM   #10734
newera152's Avatar
guys does any one know how the "Diff Check Plate" works and how to use it or if it even works.
Thanks, newera152
newera152 is offline   Reply With Quote
Old 12-15-2005, 04:19 AM   #10735
PaZ
PaZ's Avatar
diff check plate? and steel diffs with bearings
Xray T2 0079
Mardave V12 VRX
Team T.J Cells
CT Race Bodies
Old 12-15-2005, 07:15 AM   #10736
anthony390's Avatar
so you run the STEEL DIFFS with BEARINGS
Old 12-15-2005, 09:48 AM   #10737
PaZ
PaZ's Avatar
ya TC4 lightweight steel diffs with the 2 small bearings on the inside
Xray T2 0079
Mardave V12 VRX
Team T.J Cells
CT Race Bodies
Old 12-15-2005, 10:01 AM   #10738
gmintimidator's Avatar
Anthony, did you have a chance to look at my setup? I posted it on the 12th. I got a sway bar installed for this week.
I am also working on freeing up my drive line. Will the Teflon bearings be ok in the diff housings without seals? Is it ok to remove the inside seal of all the rest of the bearings? I have the car on my bench and it spins so much easier now.
Daryll
gmintimidator is offline   Reply With Quote
Old 12-15-2005, 10:16 AM   #10739
PaZ
PaZ's Avatar
im running the teflons but only cause i got them from other TC3's i got for spares if not id still be on metal shealds
Take off seals flush and use trinity royal oil to re lube them i do that to all me bearings once every 2 weeks but i only race once a week
Xray T2 0079
Mardave V12 VRX
Team T.J Cells
CT Race Bodies
Old 12-15-2005, 11:16 AM   #10740
killingtime's Avatar
Actually, the BMI will accept the nitro rack without any modifications...all holes have been drilled for you.
Mike Webb
rD Squared-MW Designs-C and R racing
Final Thoughts RC club R.I.P.
killingtime is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 05:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 02:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 08:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 09:26 PM
SEO by vBSEO 3.5.0
