Old 12-10-2005, 11:14 AM   #10711
PaZ
PaZ's Avatar
more reason to drive better
Xray T2 0079
Mardave V12 VRX
Team T.J Cells
CT Race Bodies
PaZ is offline   Reply With Quote
Old 12-10-2005, 01:03 PM   #10712
anthony390's Avatar
Send a message via AIM to anthony390
anthony390 is offline   Reply With Quote
Old 12-11-2005, 01:43 PM   #10713
PaZ
PaZ's Avatar
whats the best and easy way to free up a TC3 drive train without spending loads on new parts and stuff?
Xray T2 0079
Mardave V12 VRX
Team T.J Cells
CT Race Bodies
Old 12-11-2005, 02:37 PM   #10714
Tyson's Avatar
best way to free it up is to rebuild.
Strip it down, clean bearings, lube bearings, shim diffs, and shim outdrives.
thats all there is to it.
Tyson is offline   Reply With Quote
Old 12-11-2005, 03:05 PM   #10715
Rick Worth's Avatar
Make sure the diffs are free in the housings. When you turn the housing upside down, the diff should fall out. You may have to grind on the side of the housing where the bearings ride to get the needed play. Then shim accordinally. Remove all the inside (covered) bearings seals & make sure the thick grease is washed out & reoil with thin oil like Royal oil. Don't over tighten the top diff housing screws or the rear diff output saddle screws.
Rick Worth is offline   Reply With Quote
Old 12-11-2005, 07:25 PM   #10716
gmintimidator's Avatar
Thanks for the help on the nuts. I ended up just installing my new ones backward and the car worked great. We have a 5mm chassis height rule, so I had to adjust my setup on my car to meet that. I am using the factory setup out of the AE book with the exception of the sway bars (on order) and now the chassis height. I ended up having a lot of trouble with traction rolling the car after I raised it up. I only put tire stuff on the rears for the main, but still had problems with it rolling when I tightened up my line. I would like to know what causes this so I can figure out how to correct it. I am sure I could get an answer, but I would rather know the how and why please.
Daryll
gmintimidator is offline   Reply With Quote
Old 12-11-2005, 08:58 PM   #10717
anthony390's Avatar
your welcome
and well your car has body roll right
so i would stiffen up the chassis and supension (the cause is the oppisite of what i said)
after that put the tire SAUCE on both or dont even put any
another reason is that you are running on high grip sufaces so do the same as what i said (siffen chassis and suspension)
oh ya what are you running?
Old 12-12-2005, 02:39 AM   #10718
PaZ
PaZ's Avatar
cheers guys ive taken the one side outta the bearings and flushed already but i got a week until i race so ill spend a good day rebuilding the monkey
Xray T2 0079
Mardave V12 VRX
Team T.J Cells
CT Race Bodies
Old 12-12-2005, 09:39 AM   #10719
Anthony, thanks for the info. So soft suspension gives body roll which turns the car over.
I am running touring car stock. I am also using the V2 Stratus. I have run mostly dirt oval so getting the car to turn left isn't too bad, both ways is more difficult.
I tried my car in warm ups and it was loose when I had no suce so I went back to putting it on the inner half of my fronts and full rear. I didn't have trouble till after I raised the ride height when I found out there was a 5mm minimum. I didn't think a .5mm would make so much difference. I also didn't have time to get the car back on the tweak board.
When I stiffen the suspension. Would you do it incrementaly around the car, ie go up a spring rate front and rear?
Would a sway bar not help with body roll by limiting how much the arms move?
Daryll
Old 12-12-2005, 02:09 PM   #10720
lazyboy's Avatar
Send a message via AIM to lazyboy
Daryll
a stock roll bar for stock rubber would be a good next change to the car. it stops the the front end from having to much roll in the corner, there by keeps the car more planted/level in the corner and keeps up corner speed and doesnt make the car push out(mid corner and exit).. if u do spring rates, going up a rate in the front and rear keeping the front balanced and the rear balanced spring wise is something else to play with(what springs are you running?). also try different pistons and shock oils. for rubber i normaly ran #2 pistons and 40 weight AE oil all around on a med grip carpet track or a 40F-35R to get some more rear traction, all depends on the track condition.
if this doesnt make sense pm me and ill give u my rubber starting setup for a dual diff car on carpet.
Random Guy
FT B4
Sponsored by Axiom Motors
Trackside hobbies
lazyboy is offline   Reply With Quote
Old 12-12-2005, 03:17 PM   #10721
anthony390's Avatar
Daryll
your welcome
and well i think lazyboy ansewr your ?(s)
Old 12-12-2005, 03:43 PM   #10722
I am running foams on carpet
Front:
F+2
4 deg caster
0 toe in
-1.5 camber
middle hole in tower
only 1 choice in my current lower arms
70 wt
#2 piston
white spring
Jaco Double Purple (only inside 1/2 has traction comound)
ride height 5mm
droop 6
Camber link:upper and inward
Rear:
R+3-0
-2 deg camber
only 1 choice in my arms
50wt
#2 piston
red springs
Jaco Purple (complete coverage on traction compound)
ride height 5mm
droop 4
camber link: lower and inward tower
closet to the wheel on the carrier
wheelbase short.... opps mistake
I really appreciate you guys giving me the why to go along with the fix. Getting the latest greatest setup from associated is great to get you in the ball park, but when the track changes, it's nice to know how to go about making the changes and doing it methodically.
Thanks again
Daryll
Old 12-13-2005, 08:07 AM   #10723
slotcarrod's Avatar
What is a TC3.5?
I just put TC4 arms (drilled out mounts), castorblocks, hubs, towers and braces on my trusty IRS TC3. I love the car! All this make it a TC3.5? Are there more TC4 parts I should put on my car that will make it better?
Rod
It's been said that politics is the second oldest profession, it bares a great similarity to the first.
Rod Littau
slotcarrod is offline   Reply With Quote
Old 12-13-2005, 08:29 AM   #10724
TAO3RS's Avatar
Send a message via Yahoo to TAO3RS
hello fellow tc3 owners! hehehe
TAO3RS is offline   Reply With Quote
Old 12-13-2005, 09:41 AM   #10725
PaZ
PaZ's Avatar
the new steering rack design? I tried to fit it to my blue warpspeed TC3 but it ment i would have to re drill it and i am not doing that i haven't even scratched it. Shame i dont use it any more
Xray T2 0079
Mardave V12 VRX
Team T.J Cells
CT Race Bodies
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
