Old 11-22-2005, 05:54 PM   #10591
killingtime's Avatar
Lithium Polymer
Mike Webb
rD Squared-MW Designs-C and R racing
Final Thoughts RC club R.I.P.
killingtime is offline   Reply With Quote
Old 11-22-2005, 05:55 PM   #10592
anthony390's Avatar
Send a message via AIM to anthony390
what servo are you running?
do you have a power cap(capacitor)?
if you dont have a power cap, you most probalbly need one
that is because when you slam the throttle all the amppage goes to your motor and none to the sevo and so the servo would not keep striaght because of no electricity going to the servo(not enough electricity to the servo)
anthony390 is offline   Reply With Quote
Old 11-22-2005, 06:50 PM   #10593
HK Racing Joe's Avatar
Send a message via AIM to HK Racing Joe
I just Threw together my third TC3 with a Carbon Tub it handles amazing but everyoen once and a while it spin coming out of the corners on power. Any tips to help to prevent that. I've never had this problem with the Tc3 before
HK Racing Joe is offline   Reply With Quote
Old 11-22-2005, 07:49 PM   #10594
MadMikeB's Avatar
OK, that's a good suggestion, I will check. I'm pretty sure I'm ok with the spacers and shims. Its real wierd. And annoying - the rest of the car is super dialed, just this one problem.
MIKE
Originally Posted by Mr.Pink
well if you tighten the wheel nut too tight , you can bend the rim into the hex nut and then that could rub against the bearing , and/or have the pin bent inward against the bearing . causing it too fail
MadMikeB is offline   Reply With Quote
Old 11-22-2005, 08:05 PM   #10595
anthony390's Avatar
longer wheel base or just a bit more grip in the front
Old 11-22-2005, 09:42 PM   #10596
I agree that you should try a longer wheelbase, but don't increase front grip. You want to try (IMHO) to stiffen the front springs, soften the rear, soften rear sway bar, more negative rear camber, increase rear toe-in, and finally increase front droop. Any of these things should help with being loose on-power.
Mike Webb
Old 11-22-2005, 09:51 PM   #10597
anthony390's Avatar
but he said he spins out while he is on throttle comeing out of the turn
so wouldnt you want the front to straightn you out while accelerating
oh ya, a have to is more toe-in in the rear like what killing time said
sorry but what is "(IMHO)"
Old 11-22-2005, 09:58 PM   #10598
No, if he is spinning out while on the throttle, that means that there is not enough weight being transfered to the rear tires, hence the harder springs in front/softer in rear. Of the two possible problems he is having 1. not enough traction in the rear, 2. Too much traction in the front causing oversteer. No matter what he doesn't want more front bite.
btw- IMHO = in my humble opinion
Mike Webb
Old 11-22-2005, 10:08 PM   #10599
anthony390's Avatar
oh i see(about IMHO)
but the way i think of it it is because too much traction in the back which would leave the rear to push the front into an angle and then spinning out
not tring to do a showdown of knowledge but...
Old 11-22-2005, 10:26 PM   #10600
nitrs4rcr2's Avatar
Send a message via AIM to nitrs4rcr2
how would I go about and set the droop if i have aluminum suspension arms that don't have droop screws all around on my tc3 factory team car???*note it also has aluminum steering knuckles *
nitrs4rcr2 is offline   Reply With Quote
Old 11-22-2005, 10:48 PM   #10601
If the rear had too much traction and forced the front at an angle, that's called a push. You'll lose steering but not spin out.
Refer to the XXXmain chassis set-up guide. What I had stated came straight from it (pg. 66).
Mike Webb
Old 11-22-2005, 11:48 PM   #10602
anthony390's Avatar
oh i see but i dont have that
what i said is just based on my experience
so ya
nitrs4rcr2
what the frist tc3s have is shock limiters to set the droop
Old 11-23-2005, 07:14 AM   #10603
nitrs4rcr2's Avatar
Cool
mine is a 2nd generation tc3ft.....plus i have the threaded shocks on it...
Old 11-23-2005, 11:40 AM   #10604
PaZ
PaZ's Avatar
i dont think you can set the droop with the threaded shocks and ally wishbones i should know cause i got them to
Xray T2 0079
Mardave V12 VRX
Team T.J Cells
CT Race Bodies
PaZ is offline   Reply With Quote
Old 11-23-2005, 12:24 PM   #10605
Instead of droop screws, you put spacers INSIDE the shocks to limit their travel. Then set with a droop gauge. Problem is when you want to change droop, you must take all 4 shocks apart.
JWATT is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 05:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 02:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 08:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 09:26 PM
SEO by vBSEO 3.5.0
