Old 11-21-2005, 09:48 AM   #10576
every time i take a turn the inside rear wheel lifts of the ground i tryed all kinds of sway bars but they dont seem to be working. ive tryed every spring i got and oil but it leads back to the say bar, is there a trick to them??
thekid22 is offline   Reply With Quote
Old 11-21-2005, 10:07 AM   #10577
PaZ
PaZ's Avatar
mine did that under hard turning and it was cause the shocks oils wernt quite equal with the other side when i did that it was fine thats all i can think of. have you got the small screws with washers on that hold the sway bar to the diff case? if so make sure there not to tight or loose but can move freely
Xray T2 0079
Mardave V12 VRX
Team T.J Cells
CT Race Bodies
PaZ is offline   Reply With Quote
Old 11-21-2005, 12:20 PM   #10578
MadMikeB's Avatar
uite possibly, what effect would this have on my bearings?
Originally Posted by Mr.Pink
are you tightening the wheel nuts too tight ?
MadMikeB is offline   Reply With Quote
Old 11-21-2005, 12:23 PM   #10579
Do you have the spacers between the bearings?
JWATT is offline   Reply With Quote
Old 11-21-2005, 12:45 PM   #10580
ok thanks
Old 11-21-2005, 07:10 PM   #10581
anthony390's Avatar
Send a message via AIM to anthony390
Finaly got my steering DIALED
anthony390 is offline   Reply With Quote
Old 11-21-2005, 08:13 PM   #10582
well if you tighten the wheel nut too tight , you can bend the rim into the hex nut and then that could rub against the bearing , and/or have the pin bent inward against the bearing . causing it too fail
Associated T4 Kyosho Optima Mid
Tamiya MO3 Mini Cooper
Tamiya Falcon
Mr.Pink is offline   Reply With Quote
Old 11-21-2005, 08:20 PM   #10583
graphiteman's Avatar
thekid22,
What does your car do when the inside rear comes off the ground? What are you running for springs, shock oil, droop?
graphiteman is offline   Reply With Quote
Old 11-21-2005, 09:52 PM   #10584
it diffs out. and i lose all turning speed so it would whip around.
i got 45 wt in front and 30 in rear
i had with copper in rear i had white,purple, copper. red, white.
i tryed every differint combo. i dont have a droop gage so i dont know
Old 11-21-2005, 11:27 PM   #10585
Droop is part of the problem, as is the spring setting (stiffness) in the rear. Does your car spin out in both directions when it diffs-out? Not knowing where the droop is makes it difficult. If you have a droop setting of 3 on the left rear, and 4 on the right rear, your car will probably diff-out turning right. One of the Associated plastic droop guages are inexpensive, and very helpful in getting your car set up properly. How do you check for tweak on your car.... just curious?
Old 11-22-2005, 05:19 AM   #10586
the car sets as level as i can see. it will diff out evenly both turns.when the car sat low were i would wont it there was not enuff presser on the rear to make it tuch the track and stop the diff. what do u mean by tweak like one side lower than the other.
Old 11-22-2005, 05:43 AM   #10587
Put the car on a flat surface, put an exacto in the EXACT center of the car and lift it up. Both tires should lift away at the same time. If one tire is off the surface and one is touching, then it is tweaked. Buy or borrow an AE droop gauge and go to AE's site and learn how to use it to set the car to the recommended droop.
Old 11-22-2005, 06:08 AM   #10588
the car lifts up even.iam gona get a gauge today.
Old 11-22-2005, 04:21 PM   #10589
I have a BMI TC3 with super nitro rims & tires. Slick on the front, and tread on the rear. Iím running lipo with 19 turns. When I go full speed, the car will go straight, and all the sudden it decide to turn and flip, or spin out. I have a AM Futaba Radio with GM V4 ESC.
rcmania67 is offline   Reply With Quote
Old 11-22-2005, 04:51 PM   #10590
anthony390's Avatar
ummm sorry for my stupidity
but WHAT IS LIPO
THANKS
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
