Old 11-19-2005, 08:52 PM   #10561
anthony390's Avatar
Send a message via AIM to anthony390
what kind of diffs do you have and what turn motor
anthony390 is offline   Reply With Quote
Old 11-19-2005, 10:18 PM   #10562
slippery49's Avatar
i have a 23 turn motor i have 64p gears but i don't know what ones 2 run??/
i have steel diff out drives
slippery49 is offline   Reply With Quote
Old 11-19-2005, 10:28 PM   #10563
anthony390's Avatar
try starting from a 96 spur and a 38 pinion
and then work from there
i hope i helped you
Old 11-19-2005, 10:29 PM   #10564
Platinum_Racing's Avatar
Send a message via MSN to Platinum_Racing
If you were addressing me...
I have a 19T Chameleon/Monster Stock 27T which I swap out.
I use regular ball diffs in the front and back. I did get a pair of aluminum outdrives (After the rear blew but before the front blew) to dissipate heat faster. I want to wait till I can fix both diffs before I rebuild both diffs. My LHS guy sold me the wrong D-Rings...actually he sold me T4 rings instead. I need the whole thing replaced...even the thrust bearing ect...
Any advice?
Platinum_Racing is offline   Reply With Quote
Old 11-19-2005, 10:30 PM   #10565
anthony390's Avatar
same 1st post ? for Platinum_Racing
Old 11-19-2005, 10:33 PM   #10566
anthony390's Avatar
maybe thats it, your running the wrong parts
go check you part #s and then compare it to the real Part #s
and oh ya your running plastic putdrives right?
Old 11-19-2005, 10:35 PM   #10567
MadMikeB's Avatar
Default Front Wheel Bearings
Hi People,
My Tc3 seems to always be consuming front wheel bearings. Almost every meeting I check the car and one or more of the front wheel bearings is almost seized solid. I've replaced them with teflon sealed bearings and still the same problem, so I don't think its dirt related.
I think I've replaced five or six bearings in a couple of months.
I'd be grateful for any suggestions about what I'm doing wrong?
MIKE
MadMikeB is offline   Reply With Quote
Old 11-19-2005, 10:41 PM   #10568
anthony390's Avatar
what are you lubing or oiling it with
Old 11-20-2005, 05:12 AM   #10569
PaZ
PaZ's Avatar
wow thats bad, ive had my teflons in for about a year and there still smooth. DO you race indoors, outdoors, carpet? have you had any bad crashes with it?
Xray T2 0079
Mardave V12 VRX
Team T.J Cells
CT Race Bodies
PaZ is offline   Reply With Quote
Old 11-20-2005, 06:22 AM   #10570
Rick Worth's Avatar
I've run my TC3 for at least five years & don't remember ever changing a bearing. I've got the inner seal removed & sometime when changing the front caster I'll put in a drop of Royal oil but otherwise I don't touch them. Have you been hitting stuff?
Rick Worth is offline   Reply With Quote
Old 11-20-2005, 03:37 PM   #10571
MadMikeB's Avatar
Default Front Bearing Concumption
Regarding my front bearing consumption:
1. Yes I hit the usual number of barriers from time to time, but no more than most other racers I would guess.
2. I get Duratrax teflon sealed bearings, I don't lube them or anything, I just put them in.
In about a meeting or two, they just start to go crunch and I have to replace them again.
Are the Duratrax a problem???? Should I be looking at some other brand of bearing perhaps? What is a good brand of bearings, and do they sell a kit for the TC3?
MIKE
Old 11-20-2005, 03:52 PM   #10572
anthony390's Avatar
try oiling them before you put them in and then you should see a difference
i would put 35 wt of pretty much any oil
i am guessing that the bearing gets hot and then the ball bearings in the bearing get flat on a suface and so the bearing would be called DEAD now
in other words a bearing that doesnt act like a bearing
Old 11-20-2005, 03:53 PM   #10573
anthony390's Avatar
i would use 20wt - 35wt of shock oil
Old 11-21-2005, 05:38 AM   #10574
PaZ
PaZ's Avatar
i find associated own teflons are fine can afford these ceramic things
Xray T2 0079
Mardave V12 VRX
Team T.J Cells
CT Race Bodies
Old 11-21-2005, 08:52 AM   #10575
are you tightening the wheel nuts too tight ?
Associated T4 Kyosho Optima Mid
Tamiya MO3 Mini Cooper
Tamiya Falcon
Mr.Pink is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
