Old 11-12-2005, 08:36 PM   #10531
anthony390's Avatar
Send a message via AIM to anthony390
does any one know if i have 30-40 mph tc3 on a bumby road like a street,... would the composite CVDs snap on the part that is the universal?
oh ya i have steel outdrives and a bit tighted
THANKS
anthony390 is offline   Reply With Quote
Old 11-13-2005, 08:55 AM   #10532
Trixter's Avatar
I've been using the composit CVD's and the plastic diff halves ever since I built my car, I've run a 9 turn motor and not had any wear at at all, however I also use the Schumacher 'blades' on the end of the CVD. See photos
Slash 4X4, Bone stock and trying to keep it that way.
PRO MATCH BATTERIES.....THANKS JEFF !!
Trixter is offline   Reply With Quote
Old 11-13-2005, 10:51 AM   #10533
anthony390's Avatar
thanks but what i was wondering is the part on the CVD that is connected to the axle (axle that hold hex hub and wheel)
what i am wondering is if it would crack or snap there
Old 11-13-2005, 10:52 AM   #10534
anthony390's Avatar
oh ya where did you get and what are the Schumacher ''blades''
thanks
Old 11-13-2005, 11:01 AM   #10535
anthony390's Avatar
never mind i found out what and where i can find them
Old 11-13-2005, 12:01 PM   #10536
BIG DADDY8's Avatar
Trader Rating: 62 (100%+)
Send a message via AIM to BIG DADDY8
Originally Posted by RED-LINE M03
I am thinking of buying this car what would be a good price?
TC3 BMI 2mm & 3mm chassis
Thanks,
E
Does the BMI chassis make that much difference on the handling????
BIG DADDY8 is offline   Reply With Quote
Old 11-13-2005, 12:07 PM   #10537
anthony390's Avatar
im not that sure if it makes a difference that you can notice that easily but it does
i do know that it makes it quite STIFFER and so ya
hope it helps you
Old 11-13-2005, 12:28 PM   #10538
newera152's Avatar
Post
I was thinking about getting one for my TC3 and was talking to the guy at the track friday nite, they say every body they know the used it has a big change in handling. also whats the biggest spur gear that will fit on the TC3, I have 100 and upthey just look to big to fit.
newera152
newera152 is offline   Reply With Quote
Old 11-14-2005, 04:06 AM   #10539
RED-LINE M03's Avatar
Trader Rating: 127 (100%+)
Default BMI TC3
4-SALE BMI TC3 ( BMI, IRS, NIFTECH, ACER, RPM )
TC3 BMI, IRS, Niftech, Acer,RPM.....Pics
RED-LINE M03 is offline   Reply With Quote
Old 11-15-2005, 07:38 AM   #10540
PaZ
PaZ's Avatar
anthony390- soz mate my comp caught a worm lol all i did was remove the bearings from the diff gear thing and tightened it right up, its taken everything drift on road racing and some carpet racing. But i wouldnt do it with plastic ones they may melt lol like mine did when it got loose.
Nice BMI mate, i had the blue warpspeed demon it didn't make a massive improvement in handling but looks nice. Iv'e now gone back to the FT graphite chassis and found it just as good.
Xray T2 0079
Mardave V12 VRX
Team T.J Cells
CT Race Bodies
PaZ is offline   Reply With Quote
Old 11-15-2005, 03:46 PM   #10541
anthony390's Avatar
thanks PaZ for the info but you said bearings
i have a goldish colored bushings in my plastic and steel diffs
a bit
sorry
Old 11-15-2005, 04:04 PM   #10542
PaZ
PaZ's Avatar
I ment the bearings in the actual gear, when u take the diff appart the gear in the middle comes off and its got lots of little ball bearings in it take em out lube up tighten up fully away u go
Xray T2 0079
Mardave V12 VRX
Team T.J Cells
CT Race Bodies
Old 11-15-2005, 04:15 PM   #10543
Aries326's Avatar
Trader Rating: 19 (100%+)
Awesome! Those make total sense - evenly distribute all that power instead of concentrating it on the pins. Will those also fit the steel or aluminum diff halves?
Aries326 is offline   Reply With Quote
Old 11-15-2005, 04:23 PM   #10544
anthony390's Avatar
oh i c i tought the gold bushing that goes on the diff outdrive but ok
i out2 try it
Old 11-16-2005, 11:56 AM   #10545
PaZ
PaZ's Avatar
hope it works out ok
Xray T2 0079
Mardave V12 VRX
Team T.J Cells
CT Race Bodies
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
