Old 10-28-2005, 03:06 PM   #10456
tom235's Avatar
[QUOTE=anthony390]umm i have i big problem for a long time now and i was wondering if anybody is having problems with the droop and the shock oils being just right
maybe i should just rebuild my shocks and reset my droop...do you guys think i should do that?
i would start there.make sure when you set your droop the shocks are off so you get a good setting
tom235 is offline   Reply With Quote
Old 10-28-2005, 03:55 PM   #10457
anthony390's Avatar
Send a message via AIM to anthony390
thanks i just did and there perfect now
what about my shocks what should i do with them
thanks
anthony390 is offline   Reply With Quote
Old 10-28-2005, 05:00 PM   #10458
newera152's Avatar
If I'm setting up my tc3 and I'm setting the toe, droop, chamber which should I do first.
Thanks,newera152
newera152 is offline   Reply With Quote
Old 10-28-2005, 05:47 PM   #10459
anthony390's Avatar
altough i still need help i would do the droop first
Old 10-28-2005, 07:28 PM   #10460
quick question.
In the setup sheets there is something called "limiters" under the shock section. What are "limiters"?? Are they refering to o-rings??
Thanks,
Gareth
Floss_LUC is offline   Reply With Quote
Old 10-28-2005, 07:59 PM   #10461
anthony390's Avatar
yes they are
i have a question to... how important is the foam in the shocks
Old 10-28-2005, 08:38 PM   #10462
graphiteman's Avatar
I think the limiters are used to adjust the droop in the TC3's that dont have the updated arms.
graphiteman is offline   Reply With Quote
Old 10-28-2005, 11:02 PM   #10463
Aries326's Avatar
Trader Rating: 19 (100%+)
I'm not sure how important the foam is, but if it's there, it's gotta be for something. I just built some new shocks and I used the foams.
It's such a pain rebuilding shocks. The way these shocks are built, you get spillage from the oil in the cap. Then when you're done screwing the tops on, the rebound isn't the same on all the shocks and you have to try adjusting the amount of oil inside until they rebound at approximately the same speed. I wonder if bladders can be used with these shocks. Wouldn't that eliminate the problem of having different rebound in your shocks?
Aries326 is offline   Reply With Quote
Old 10-28-2005, 11:27 PM   #10464
anthony390's Avatar
ya i guess so to so i just kept in on there and guess what henry i just built a composite shock that doesnt leak or well ya it doent leak on the shaft
Oh ya and i just fixed the worsed problem for the composite shocks
Old 10-29-2005, 09:05 AM   #10465
Aries326's Avatar
Composite shocks? I didn't know you had the racer kit. I've got two extra threaded shock bodies if you want them. The problem is that one of them is missing the ring that you adjust. I don't know how the original owner managed to lose that piece. I don't know if you can buy that part seperately. If you can get those two shocks going, you at least have two less shocks to worry about leaking...
Old 10-29-2005, 09:07 AM   #10466
BatJam1's Avatar
Does anyone know what i would have to do to convert my TC3 to a drift car?
BatJam1 is offline   Reply With Quote
Old 10-29-2005, 10:17 AM   #10467
anthony390's Avatar
thanks henry... ALOT
and for batjam just put drift wheels on your tc3 and its a drift car(really dont have to worry about set-ups just your diffs and your set)
Old 10-30-2005, 12:07 AM   #10468
rpmmaxxed's Avatar
Send a message via AIM to rpmmaxxed
can anyone suggest a good body to run at socal?
Looking at the stratus 3.0...
Previously ran an S2000 for kicks, but I know it was a hinderance.
Any info is appreciated.
Thanks.
rpmmaxxed is offline   Reply With Quote
Old 10-30-2005, 03:55 AM   #10469
Robertw321's Avatar
R/C Tech Charter Subscriber
Yokomo bladder caps are a direct fit for TC3 shocks.
Bob Williams
Robertw321 is offline   Reply With Quote
Old 10-30-2005, 04:03 AM   #10470
JonboyGB's Avatar
Thanks.
Never run at SoCal but the Dodge3 is a great all-rounder. Put one on my car middle of this year and it hasnít come off!
www.zen-racing.co.uk
JonboyGB is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 05:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 02:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 08:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 09:26 PM
SEO by vBSEO 3.5.0
