Old 10-24-2005, 06:48 PM   #10441
tom235's Avatar
Originally Posted by anthony390
thanx but what do you mean by ''did the washer make a diff''
when you put the washer under the front did the car handle better
tom235 is offline   Reply With Quote
Old 10-24-2005, 07:29 PM   #10442
anthony390's Avatar
Send a message via AIM to anthony390
yes it did beacuse the caster rose and so i get better turning grip sorry i tought you meant like differential but i know now its difference
anthony390 is offline   Reply With Quote
Old 10-24-2005, 08:10 PM   #10443
anthony390's Avatar
hey do you think the front arms will break easier because of this please tell if you know
Old 10-25-2005, 12:16 AM   #10444
Aries326's Avatar
Trader Rating: 19 (100%+)
Did you use that washer mod for drifting or racing? How thick was the washer you used or did you use a shim? If so, how thick was the shim?
Aries326 is offline   Reply With Quote
Old 10-25-2005, 11:16 PM   #10445
anthony390's Avatar
oh hey henry well ya i did it for both grip and drift
the thickness of the spacer is as thick as the rear wheelbase spacers on one side put together if you have rear tc3 hubs that is
mine is color white but i also have black ones and thats what i used..you use a total of 3 spacers
put the spacers under the front arm mount... one right under the bumper mount but on top of bumper and the other two is on top of the bumper but under the arm mount (each next to the screw nubs things) if you want a picture just ask me if you dont quite understand... sorry
Old 10-26-2005, 01:49 AM   #10446
Aries326's Avatar
I got it. I'll have to try it out when spring comes. How is it running now through your turns?
Old 10-26-2005, 04:39 AM   #10447
RED-LINE M03's Avatar
Trader Rating: 127 (100%+)
Default BMI TC3 or FT TC 4
Can any of the long time AE guys answer a question for me?
What is a better car for asphalt racing?(BMI TC3 or FT TC 4)
I have heard that the TC3 with the BMi 3mm chassis is the way to go.
I have also heard that the ackermann, and the sterring slop is much better on the TC3.
Any help would be great.............
Thanks,
E
RED-LINE M03 is offline   Reply With Quote
Old 10-26-2005, 07:58 AM   #10448
anthony390's Avatar
like in drift or in grip well heres the answer for both: grip i get more grip with the steering and so my turns are much easier to do and for drift i am able to counter steer more now and i like that beacuse countersteer for 4wds in drifting is not needed throughout the turn but with my setup its looks like rear wheel drive
did i answer you question?
Old 10-26-2005, 07:59 AM   #10449
anthony390's Avatar
oh ya ill go with the FT TC4 alot better but if your just going to bash around then ill go with the BMI TC3
Old 10-26-2005, 12:17 PM   #10450
PaZ
PaZ's Avatar
yer id get the FT TC4 i had a TC3 3mm conversion kit and in all honesty it didnt make a massive difference i went back to the STD FT chassis iv'e never tried ackerman
Xray T2 0079
Mardave V12 VRX
Team T.J Cells
CT Race Bodies
PaZ is offline   Reply With Quote
Old 10-26-2005, 04:52 PM   #10451
anthony390's Avatar
here is my caster mod i just used black spacers but its the same thickness as the white ones you can tell the thickness in the pic
i put a foam tape so the spacer doent slide out from vibrartions
and sorry... its a bit blurry if you still have ?s just ask, im fine with it
Old 10-26-2005, 05:37 PM   #10452
graphiteman's Avatar
Red-Line, the TC3 with the BMI chassis handles excellent, and is certainly not a basher. After I put a new chassis on my car, I started winning races. I run on a high-traction, indoor asphalt surface. I run my car very stiff, and this may not work on a low-traction surface.
graphiteman is offline   Reply With Quote
Old 10-27-2005, 04:44 PM   #10453
BIG DADDY8's Avatar
Trader Rating: 62 (100%+)
Send a message via AIM to BIG DADDY8
Default Need a basic set up??
Looking for a good set up for my ft tc3. Not the new version. The chassis has been milled for the battery to sit closer inside. Other than that it has the settings to the manual. Does the rear shock tower replacing the front tower really make that much of a differance?
BIG DADDY8 is offline   Reply With Quote
Old 10-27-2005, 05:55 PM   #10454
I use to standard front shock tower that came with the kit. By using the rear tower on the front, you are moving the socks out toward the wheels more, and you can use a softer spring. Try it, the parts are cheap.
If you dont like your setup now, what do you want the car to do? The problem with using other drivers setup is that it may not suit your driving style. The settings right from the box are pretty good. change the rear toe block to 2+0 if you have not already tried it. Also, the amount of droop in both front and rear suspension arms can make a huge difference.
Old 10-27-2005, 06:21 PM   #10455
anthony390's Avatar
umm i have i big problem for a long time now and i was wondering if anybody is having problems with the droop and the shock oils being just right
maybe i should just rebuild my shocks and reset my droop...do you guys think i should do that?
oh ya im using composite shock bodies and caps... should i change that?
THANKS
New to the forum mig rod Electric Off-Road 1 01-05-2008 05:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 02:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 08:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 09:26 PM
SEO by vBSEO 3.5.0
