Old 10-11-2005, 08:44 PM   #10351
WD40's Avatar
Touring Car, electronics blowout!!!
WD40 is offline   Reply With Quote
Old 10-11-2005, 08:49 PM   #10352
anthony390's Avatar
Send a message via AIM to anthony390
can i flip my d-rings around like keep it on the same outdrive but flip it around
anthony390 is offline   Reply With Quote
Old 10-11-2005, 09:06 PM   #10353
trackdesigner71's Avatar
Send a message via AIM to trackdesigner71 Send a message via Yahoo to trackdesigner71
I loosened and retightened the screws on my motor mount but the motor still is very loose fitting. What do I do? I cant set gear mesh because of it because the motor is moving around when I touch it...HELP!
trackdesigner71 is offline   Reply With Quote
Old 10-11-2005, 09:20 PM   #10354
rivbluenoma's Avatar
Yup. Did it on my car and it works fine.
rivbluenoma is offline   Reply With Quote
Old 10-11-2005, 09:30 PM   #10355
Aries326's Avatar
Trader Rating: 19 (100%+)
That's weird. Are you using the right length screws? Are you using the spring on the outside screw? Are the nuts there inside the hole near the bottom of the chassis? They hold the screws tight.
Aries326 is offline   Reply With Quote
Old 10-11-2005, 09:55 PM   #10356
They are the screws that came on the car. Nothing was removed so everything is where it should be. the locknuts are really in there though and I dont have anything to reach in there if I need to loosen em
Old 10-12-2005, 08:04 AM   #10357
anthony390's Avatar
thanks and for the motor mount the screws might be stripped!!! so ill try to look if i were you and push out the nut from the top
Old 10-12-2005, 09:37 AM   #10358
sosidge's Avatar
Originally Posted by Robertw321
The TC3 standard setup has four limiters in each front shock and two in each rear shock
Thanks for that, that is actually the setup I guessed at!
Old 10-12-2005, 12:18 PM   #10359
Big Rigg's Avatar
Alot of times this means the spring on the outside screw of the motor clamp has gotten too weak. Try getting a new one... ( I think there was a B4 spring that was a bitt beefier that would also work good). Also try taking your exacto blade and cutting (scratching) some vertical lines in both the chassis, the motor cam and the clamp, that should prevent any slippage whatsoever. Good luck
[url=http://www.corallyusa.com/][color=Red]- Corraly USA -[/color][/url]
[url=http://www.corallyusa.com/specializedrc/index.htm/][color=Red]- Specialized R/C -[/color][/url]
[url=http://www.thunderrc.com/eshop/][color=DarkRed]- Team Thunder RC -[/color][/url]
[url=http://www.cfxpaintworks.com/][color=DarkOrange]- CFX Paintworks -[/color][/url]
[COLOR=DarkSlateGray]- Team Ertrachter Factor - [/COLOR]
If my last name were Oxlong, I would name my kid Mike... yup Mike Oxlong
-Heywood Jablome
I don't want to pay for my sig, so yawl figure it out...
Big Rigg is offline   Reply With Quote
Old 10-12-2005, 12:19 PM   #10360
tom235's Avatar
did you check to see if the motor cam is cracked
tom235 is offline   Reply With Quote
Old 10-12-2005, 07:03 PM   #10361
anthony390's Avatar
is your motor screwed on to the cam?
Old 10-12-2005, 07:09 PM   #10362
Ah...(light bulb comes on) I thought something was missing...I will dig the cam out of my bag of parts and try the installation again. Thanks!
Wow I feel like a goober...
Old 10-12-2005, 07:42 PM   #10363
anthony390's Avatar
so it wasnt screwed on lol well its ok no need to feel embarrest(I didnt spell that right huh).... we all do something like that at least once well your welcome
Old 10-12-2005, 07:52 PM   #10364
anthony390's Avatar
oh ya i just installed team losi xxxs rtr front steering knuckle on my car is that bad? because i noticed i get alot more steering and my knuckes dont even touch the hub!!!
THANK YOU
Old 10-12-2005, 09:07 PM   #10365
anthony390's Avatar
xxxs steering knuckles and the front hubs are tc3's should i change the front hubs to xxxs front hubs?
New to the forum mig rod Electric Off-Road 1 01-05-2008 05:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 02:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 08:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 09:26 PM
SEO by vBSEO 3.5.0
