Old 10-05-2005, 09:40 AM   #10336
axle182's Avatar
Trader Rating: 18 (100%+)
Send a message via MSN to axle182
Well im actually doing the next best thing. When i got my TC3 second hand it came with a new chassis, so ill mill that one and set up the swing rack and see what happens. Ill leave the current chassis as is (only mod is the battery closer to the centre line and opened the motor cooling opening)
Chassis stiffeners? i was meaning the four in the corners. i replaced the tc3 ones with the tc4 ones. I noticed it all fits, but its a better fit to use the tc4 suspension mounts, as the tc3 ones come close to the upper link ball connector. Looks like my GTB has arrived, so ill be putting that in at the track tonight. Im trying the car on old hard foams so im not expecting anything spectacular, but should be decent.
Aaron "AJ" Freind
axle182 is offline   Reply With Quote
Old 10-05-2005, 12:29 PM   #10337
sosidge's Avatar
Default Shock help please
Hi all,
Can I get a little clarification on the standard way of building plastic TC3 shocks?
I'm doing some work on a friend's TC3, which looks like an early Racer edition.
At some point somebody has messed around with the spacers inside the shock, and I am trying to set it right.
The online manual suggests there should be none, but the expoded diagram suggests there should be two slim spacers in each shock.
Which is it please?
Thanks.
Old 10-05-2005, 07:41 PM   #10338
Big Rigg's Avatar
The spacers in the shocks were most likely there to set the droop. If the chassis has droop tabs take out the spacers from the shocks and set the droop from the a-arms, if not then you'll need someone elses help cuz I've never set my droop with shock spacers... sorry I couldn't be more help...good luck
[url=http://www.corallyusa.com/][color=Red]- Corraly USA -[/color][/url]
[url=http://www.corallyusa.com/specializedrc/index.htm/][color=Red]- Specialized R/C -[/color][/url]
[url=http://www.thunderrc.com/eshop/][color=DarkRed]- Team Thunder RC -[/color][/url]
[url=http://www.cfxpaintworks.com/][color=DarkOrange]- CFX Paintworks -[/color][/url]
[COLOR=DarkSlateGray]- Team Ertrachter Factor - [/COLOR]
If my last name were Oxlong, I would name my kid Mike... yup Mike Oxlong
-Heywood Jablome
I don't want to pay for my sig, so yawl figure it out...
Big Rigg is offline   Reply With Quote
Old 10-05-2005, 08:02 PM   #10339
trackdesigner71's Avatar
Send a message via AIM to trackdesigner71 Send a message via Yahoo to trackdesigner71
Are you supposed to loosen the motor mount locknuts on the underside of the chassis before installing a motor in the TC3?
trackdesigner71 is offline   Reply With Quote
Old 10-06-2005, 01:50 AM   #10340
TheCoolCanFanMan's Avatar
Hi
On a TC3, does the battery sit at the front or to the rear of the car genraly?
CCFM
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
Old 10-06-2005, 10:45 AM   #10341
minicooper's Avatar
Location: Beautiful Downtown L.A. Where the sky is always on fire and the grass is always brown
Send a message via AIM to minicooper Send a message via Yahoo to minicooper
No. The locknuts stay in the chassis. To install the motor you simply loosen the two screws on top of the motor mount (the two screws that actually go into the locknuts.)
minicooper is offline   Reply With Quote
Old 10-06-2005, 11:36 AM   #10342
Big Rigg's Avatar
Originally Posted by Trakside Trucke
Hi
CCFM
I always ran mine to the front...only rarely did I hear of people running it to the rear (the FT graphite tube thing that takes the place of the foam is a good idea too, that way you'll never smash that foam into your spur gear after forgetting to turn at the end of the straight hehehe)
-Heywood Jablome
Old 10-06-2005, 11:44 AM   #10343
axle182's Avatar
ive never driven with them forward as i prefer an under steering car, a oversteering car annoys the $%^ out of me, as it keeps spinning. I start with understeer, and progressively dial in more steering until im able to put the car where i want.
But im still fairly new to the TC3, so i may try them forward and see what it feels like. Tried mine with the new GTB last night (arrived yesterday afternoon). Stacks of power, and considering the TC3 was handling like a pig, the very smooth throttle response made it relatively easy to drive. Got some good laptimes in too. Ill be doing a complete strip and rebuild next week. Ive found the rear diff starts to slip a little after a few minutes of hard driving with the GTB on carpet. But so far, im happy
Aaron "AJ" Freind
Old 10-08-2005, 09:40 AM   #10344
Robertw321's Avatar
R/C Tech Charter Subscriber
Originally Posted by sosidge
Hi all,
Which is it please?
Thanks.
The original TC3 did not use droop screws in the a arms. Shock travel was adjusted by using limiters inside the shock.
From the original manual.
Shock travel can be adjusted on the TC3 to help speed up or slow down how fast the car changes direction when cornering. The TC3 standard setup has four limiters in each front shock and two in each rear shock.
If your track is bumpy, you may want to remove one or two limiters from each shock.
If your track has very high traction, such as carpet, then you may want to add one more limiter to each shock. Too many limiters will cause a loss of traction.
The #6466 shock travel limiter kit has four each of the three sizes of travel limiters: 1/8" (.125), 1/16" (.062) 1/32" (.031).
Standard setting is four .031 limiters for front, and two .031 limiters for rear.
Bob Williams
Robertw321 is offline   Reply With Quote
Old 10-10-2005, 09:08 PM   #10345
anthony390's Avatar
Send a message via AIM to anthony390
do any of you guys have any tips for rebuilding the plastic diffs...?
anthony390 is offline   Reply With Quote
Old 10-10-2005, 09:12 PM   #10346
rivbluenoma's Avatar
As far as I can tell Associated only sells CARBIDE 3/32" diff balls
which go for $12 a bag. Little steep for my budget. Losi sells plain steel 3/32" diff balls for about $1.50 a bag. Thats about the only tip Ive got.
rivbluenoma is offline   Reply With Quote
Old 10-11-2005, 10:42 AM   #10347
Aries326's Avatar
Trader Rating: 19 (100%+)
How much better are carbide diff balls than steel diff balls? Which ones last alot longer?
Aries326 is offline   Reply With Quote
Old 10-11-2005, 11:31 AM   #10348
WD40's Avatar
I have a tc3 that I am selling if anyone is interested. It has many many spare parts, a stock motor, and I keep it in very good shape. I have put a lot of work into it to make it very competitive. I will sell it for $150. If anyone is interested just pm me or call me at 864-650-5240. I have pictures available on request.
WD40 is offline   Reply With Quote
Old 10-11-2005, 03:20 PM   #10349
PaZ
PaZ's Avatar
whats a quick and easy way to set up a TC3 for tarmac drift fun, just messin around not hardcore stuff sumone told me soft front springs, no toe in?
Xray T2 0079
Mardave V12 VRX
Team T.J Cells
CT Race Bodies
PaZ is offline   Reply With Quote
Old 10-11-2005, 04:13 PM   #10350
anthony390's Avatar
well yes but not really what it is to be is you want the front to be softer then the rear but doent mean like real soft and for the toe in you can have a little but i dont use any
Thanks for the tips on the diff tips
New to the forum mig rod Electric Off-Road 1 01-05-2008 05:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 02:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 08:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 09:26 PM
SEO by vBSEO 3.5.0
