Old 10-01-2005, 11:10 AM   #10321
graphiteman's Avatar
I dont use one for my TC3. The steering rack has a servo saving feature built in. You may want to back the screw out (check your manual) which you can adjust through a small hole in the bottom of the chassis. The manual states the screw should be flush with the top of the nut.
graphiteman is offline   Reply With Quote
Old 10-01-2005, 01:34 PM   #10322
Aries326's Avatar
Trader Rating: 19 (100%+)
I forgot to mention, I have the NTC3 steering rack mod. Maybe I gotta look at it again and make sure everything is lined up right. Maybe that's why the servo went on me...
Aries326 is offline   Reply With Quote
Old 10-01-2005, 07:30 PM   #10323
rivbluenoma's Avatar
Anyone have trouble with the diffs in their tc3? I cant get my front diff working right. Took it out, inspected it, reassembled it and reinstalled. If I set the diff loose enough to allow one wheel to spin opposite of the other then neither of the front wheels get full traction as if the diff is slipping under acceleration. If I set it tight enough to get full acceleration at the front wheels, it loses all ability to act like a diff, and is more like a spool. Whats the deal? My rear diff works nice, and I cant see anything that would cause the front diff to work any differently.
rivbluenoma is offline   Reply With Quote
Old 10-01-2005, 10:11 PM   #10324
anthony390's Avatar
Send a message via AIM to anthony390
im not qiure sure if this is the problem but take it out and disassemble it and take out any burrs and make sure you take out all the grit(dirt or shavings) and then spray it with some motor cleaner or buggy blast and then install like before if it doesn't do any good then sorry
anthony390 is offline   Reply With Quote
Old 10-03-2005, 01:49 PM   #10325
Problem fixed. Previous owner decided that outdrives from a pro4 would work nicely in the front of a tc3. Installed new associated out drives in the front diff, works great now. nice and smooth
Old 10-03-2005, 05:17 PM   #10326
anthony390's Avatar
what the heck he put a pro4 one way on the tc3 i never tought of that but i guess it wont work
Old 10-03-2005, 05:31 PM   #10327
Aries326's Avatar
Default PLASTIC BLOCK CARRIER BUSHINGS
Does any one know where I can find PLASTIC BLOCK CARRIER BUSHINGS? I've got some aluminum block carriers and I want to use them but it has some missing plastic bushings. I have some regular steel ones but I don't want to use those. It may damage the aluminum and eventually become too loose. Thanks.
Old 10-03-2005, 07:59 PM   #10328
Not exactly. Everything was original tc3 parts except for the pro4 outdrives and outdrive bearings. What was this guy thinking? $14 worth of new bearings and $5 for new outdrives and the little p.o.s. is back in business.
Old 10-04-2005, 07:52 AM   #10329
axle182's Avatar
Trader Rating: 18 (100%+)
Send a message via MSN to axle182
Can anyone suggest a good TC3 setup for carpet mod? I can run foam or rubber. Will be running a GTB with the 5.5 setup and gp33's. Chassi has been modified with batteries more central, it has TC4 chassis stiffeners, and towers. I have a NTC3 steering rack setup ready to go in also. Can someone please post me a good setup for my TC3 on carpet? Thanks
Aaron "AJ" Freind
axle182 is offline   Reply With Quote
Old 10-04-2005, 08:44 AM   #10330
You shouldnt need the NTC3 steering rack setup if your only running carpet. That mod is done because of rocks getting caught in the steering rack. hopefully there arent many rocks at your carpet track.
Old 10-04-2005, 09:03 AM   #10331
axle182's Avatar
I thought it was more a tuning option? Looking at the steering arrangements, theres a huge difference in steering linkage angles between the rack and the swingrack??? can anyone confirm if its worth changing to the swingrack?????? thanks
Aaron "AJ" Freind
Old 10-04-2005, 04:17 PM   #10332
Aries326's Avatar
Look through the old posts. I'm pretty sure people were saying that there's too much ackerman.
What chassis stiffeners are you using? The ones mounted in the corners?
Old 10-04-2005, 05:34 PM   #10333
anthony390's Avatar
after reading this i would say change it if you TRULY TRULY NEED IT or want it and if you do just put spacers to lower the ankerman but i wouldnt really recomend it for carpet racing
Old 10-04-2005, 08:10 PM   #10334
Aries326's Avatar
I tried that but then the cups hit prematurely where the swing rack is connected to the posts. Your turning radius goes down alot.
Old 10-04-2005, 09:31 PM   #10335
anthony390's Avatar
oh then im not sure what to say well i guess i wouldnt do it no more since your dong carpet anyway
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
