Old 09-27-2005, 04:33 AM   #10306
trackdesigner71's Avatar
Send a message via AIM to trackdesigner71 Send a message via Yahoo to trackdesigner71
Originally Posted by rcnutmich
i assume you have the end bell on the motor,,,once you insert the motor ..the motor will rotate towards the other side and closes up the mesh
Ok thanks. although I had a look at the locknuts on teh underside of the motor mount and I think I need to cinch those down as well. Can anyone tell me what size those are and also could they spare a wrench of that size?
trackdesigner71 is offline   Reply With Quote
Old 09-27-2005, 09:15 AM   #10307
viper15's Avatar
What kind of spur and pinnion gears should I use? I have a chameleon 19t and p2k 27t motors. When i tried to calculate it it seemed under geared. What is the internal gear ratio?
viper15 is offline   Reply With Quote
Old 09-27-2005, 03:32 PM   #10308
Aries326's Avatar
Trader Rating: 19 (100%+)
I believe the internal gear ratio is 2.2. For the stock motor, they recommend a 28T pinion for a 72T spur.
Aries326 is offline   Reply With Quote
Old 09-27-2005, 03:34 PM   #10309
Trader Rating: 17 (100%+)
TC3/4 Internal ratio is 2.5:1
Team Powers, SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
www.TeamPowersUSA.com
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 09-29-2005, 12:06 AM   #10310
Aries326's Avatar
Oops, sorry, you are right. I was thinking of my MR4TC Special. I just purchased some new pinions for it.
Old 09-29-2005, 12:36 AM   #10311
spanish armada's Avatar
Default conversion
Can a tc3 be converted into a tc4? if so, than what is needed.
spanish armada is offline   Reply With Quote
Old 09-29-2005, 04:44 AM   #10312
TC3ElectricGuy's Avatar
well. few weeks ago i bought brand new a TC3 Factory Team Kit.
spent a grand total of around AU$1000 on the car.
just today i bought a ntc3 off a member from this site. i guess after being at the race track i wanted the fun of a gas car. but this car will be my backup and fun car. i might race it every so often.
i just love this car. it's the first proper R/C car i've owned and i didn't want to do things half assed.
TC3ElectricGuy is offline   Reply With Quote
Old 09-29-2005, 08:12 AM   #10313
axle182's Avatar
Trader Rating: 18 (100%+)
Send a message via MSN to axle182
From what i heard from a TC4/3 driver, the TC4 wasnt a huge enough upgrade to warrant the money. He has slowly upgraded his TC3, with TC4 suspension link mounts (not using the shock towers to mount the link anymore. I have just done this and the TC4 chassis braces fit on the TC3 fine). The next step is setting up a TC4, or NTC3 steering rack setup. Apart from these things, im not sure what else is worth changing. Not sure if the TC4 shock towers fit the TC3? Anyone know?
Aaron "AJ" Freind
axle182 is offline   Reply With Quote
Old 09-29-2005, 01:17 PM   #10314
Aries326's Avatar
TC4 shocks towers will fit the TC3. I've seen pictures of people using them.
I've got the NTC3 Steering rack on my TC3 now but someone said that steering is reduced and there is too much ackerman? Any input on this. He also suggested putting in the TC4 steering instead. Has anyone done this successfully? Thanks!
Old 09-29-2005, 02:50 PM   #10315
what size are the locknuts under the motor mount on the TC3?
Old 09-29-2005, 02:54 PM   #10316
JWATT is offline   Reply With Quote
Old 09-29-2005, 04:22 PM   #10317
anthony390's Avatar
Send a message via AIM to anthony390
hey thats what i did
anthony390 is offline   Reply With Quote
Old 09-29-2005, 04:58 PM   #10318
rcnutmich's Avatar
Send a message via Yahoo to rcnutmich
what kind of tires do you have on the tc3???? looks like drift wheels
rcnutmich is offline   Reply With Quote
Old 09-30-2005, 10:15 PM   #10319
anthony390's Avatar
ya i do have drift wheel on it and any one like pro have any grip damper tips for the tc3
Old 10-01-2005, 07:13 AM   #10320
Aries326's Avatar
Default Servo Saver
Does anyone here use a servo saver with their TC3? If so, which one? I just brined up a servo the other day and I wanna make sure I don't do it again. Thanks!
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
