Like Tree4Likes
Old 08-31-2005, 08:43 AM   #10216
anthony390's Avatar
Send a message via AIM to anthony390
hey i was wondern if the wheel base from the tc4 is the same as the tc3 and whats the difference in the dog bones
anthony390 is offline   Reply With Quote
Old 08-31-2005, 09:52 AM   #10217
tom235's Avatar
Originally Posted by graphiteman
I decided to try the Losi XXX- rear hubs, and the CVD driveshaft will not reach the drive cups unless I run an excessive amount of camber. Is there a differential drive cup that is a bit longer so I can give these hubs a try?
make sure your not running the losi off set hubs then you need a ton of camber.
i have losi hubs all the way around on my tc3 and they work great.never broke one
tom235 is offline   Reply With Quote
Old 08-31-2005, 11:15 AM   #10218
Aries326's Avatar
Trader Rating: 19 (100%+)
What are the part numbers to those losi hubs? I've got losi hubs NIP for the fronts that came with my TC3 that I bought, but I don't have any for the rear. Thanks.
Aries326 is offline   Reply With Quote
Old 08-31-2005, 11:45 AM   #10219
tom235's Avatar
here are the losi #'s 1/2 deg 9852 1 deg 9853
Old 08-31-2005, 12:49 PM   #10220
Rick Worth's Avatar
Don't forget A-9847 are the 0 degree graphite hubs. R.W.
Rick Worth is offline   Reply With Quote
Old 09-01-2005, 08:19 AM   #10221
Default -2 degrees kick?
Hey guys. I'm setting up my FT TC3 for carpet, and using Blackstock's Snowbirds setup for a starting point. How can I achieve -2 degrees of front kickup? I thought you can only go +2 or 0 degrees...
Second, is this a pretty good setup to start with, or am I better off using AE's carpet setup in the back of the owner's manual? The track is Ozite, lots of tight 90 and 180 degree corners, one short straight.
Slow4dr is offline   Reply With Quote
Old 09-01-2005, 08:22 AM   #10222
he tells you how on the "ask Mike Blackstock thread" on this forum.
DLM2005 is offline   Reply With Quote
Old 09-01-2005, 08:45 AM   #10223
Aries326's Avatar
Thanks!
Old 09-01-2005, 09:04 AM   #10224
Thanks DLM. Can you save me some time, what page is this on? (30 pages)
Old 09-01-2005, 12:30 PM   #10225
Rick Worth's Avatar
Use the F+0 block & put .032" spacers under the rear block.
Old 09-01-2005, 12:45 PM   #10226
YEkim's Avatar
Send a message via AIM to YEkim Send a message via MSN to YEkim Send a message via Yahoo to YEkim
TC3 Tub Chassis Mod
I have found that once I modified my tub chassis to get the battery packs more to the center, the chassis is not as stiff. I know this is because I have removed material from the center beam, but does anyone know of a way to counter act this?
Thanks,
Yekim
YEkim is offline   Reply With Quote
Old 09-01-2005, 07:57 PM   #10227
Shopkeeper's Avatar
Trader Rating: 35 (100%+)
Default BMI
BMI makes a uppper deck for the tub chassis that will stiffen it back up.
Shopkeeper is offline   Reply With Quote
Old 09-01-2005, 11:35 PM   #10228
graphiteman's Avatar
I picked up the wrong parts, so thanks for the info pertaining to the Losi hubs and part numbers!
Do those of you running the Losi hubs leave the ball cup on top when installed? It leaves the camber link at an odd angle.
graphiteman is offline   Reply With Quote
Old 09-02-2005, 03:55 AM   #10229
Rick Worth's Avatar
Yes, leave it on top. You may need to shave a little off the top with an Exacto off the ballcup for wheel clearance. The do angle forward some but work fine.
Old 09-02-2005, 04:11 AM   #10230
Secret_weapon's Avatar
I like to try different setup's, any new tc3 setup with spool diff.
Secret_weapon is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
