Old 08-15-2005, 11:40 AM   #10201
Originally Posted by HRCRACER123
Hey Guys. What is a good bumper for my TC3. I have the rpm one and it keeps bending down from me hitting stuff and the bumper scrapes the carpet. Any suggestions?
I'm having the same problem as well. I've used the BRP one in the past. It is made of 1/8" Kydex and doesn't really do a much better job than the RPM one. I think that I might make one out of Carbon Fiber and be done with it.
-Eric
Team BSR
Team Power Push
Protoform Race Bodies
KSKT Racing - #1 in SK Racing Chassis
Darkside Motorsports - "WE ARE WHAT'S NEXT." - www.darksidems.com
THE DARKSIDE is offline   Reply With Quote
Old 08-15-2005, 01:40 PM   #10202
killingtime's Avatar
Originally Posted by ajg
Also, can anyone tell me what the correct pinion for a 68t (these are the only ones I have right now) spur gear (48p) would be, using a monster stock motor (for a smaller track, about a 60ft straight)? Thanks
My starting point for choosing a pinion, is to get one that will hit your top speed about 3/4 the way down the straight. Once you have that figured out, see how it feels on the infield. If it doesn't have the torque you like, then drop a tooth or so.
You are not going to get a good answer about "what pinion to run?" from people who have never seen the track your running or seen the car on it. I was told from one of the well known motor builders that advertised on this site, that two identical motors don't always need the same pinion to run at their best. So don't get yourself stuck in the trap "This pinion worked in my other P2K2, so it should be fine in this P2K2". So with that said, I hope you can find the pinion you need, to any track you go to from now on.
Mike Webb
rD Squared-MW Designs-C and R racing
Final Thoughts RC club R.I.P.
killingtime is offline   Reply With Quote
Old 08-15-2005, 01:56 PM   #10203
ajg
Registered User
ajg's Avatar
Ok, Thanks. I'll just have to go to the track early and try different pinion before practice starts.
ajg is offline   Reply With Quote
Old 08-15-2005, 04:06 PM   #10204
Aries326's Avatar
Trader Rating: 19 (100%+)
-Eric
I recently bought a Factory TC3 here for my cousin and the previous owner seemed to know what he was doing. He left the original plastic bumper mount (or whatever it is called) but instead of having a thick foam bumper, his bumper was half the thickness but was pretty hard. You can tell that it would definitely protect your front end.
Look for wannabee and ask him about it if you're curious. He is the guy I bought it off of.
Aries326 is offline   Reply With Quote
Old 08-15-2005, 04:19 PM   #10205
Scott S's Avatar
Trader Rating: 30 (100%+)
What I've done with much success is use an RPM TC3 front bumper and a trinity foam bumper together. The key is to fill the foam bumpers' triangular holes with peices of foam made out of the stock tc3 grey bumper. After it's filled, round off the bumper as nessecary to fit under your body so it's supported. This method provides a great hard bumper which keeps the front end from breaking and almost always keeps the front end from bending down. If it does bend down, just use a heat gun and bend it up slightlyy.. just enough so it bends up next time you hit instead of down. Hope this helps!
Xray T2 007 | Xray T2 | CRC 3.2R | CRC Gen X
Willis Hobbies | 360 RC Speedway & Hobbies | LIR
Scott S is offline   Reply With Quote
Old 08-16-2005, 02:46 PM   #10206
PaZ
PaZ's Avatar
thats exactly what i did
Xray T2 0079
Mardave V12 VRX
Team T.J Cells
CT Race Bodies
PaZ is offline   Reply With Quote
Old 08-17-2005, 06:53 AM   #10207
cartix's Avatar
Trader Rating: 33 (100%+)
Is the Xtreme TC3 carbon fiber chassis good?
cartix is offline   Reply With Quote
Old 08-17-2005, 08:22 AM   #10208
Tech Legend
Wild Cherry's Avatar
Originally Posted by DLM2005
2) also check out Mike Blackstocks thread on this forum and space the rack up per his instruction.
Could it be possible to give a page number of that post or date ect ?
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 08-17-2005, 08:38 AM   #10209
Nova F1 Racer's Avatar
R/C Tech Charter Subscriber
page 252
This is DICK!!! And you're NOT!
RC Tech member #11
Aussie Rules Footy, Brisbane LIONS!!
[url]http://www.pitter-pat.com/[/url] for pet care needs in Northern Virginia
Nova F1 Racer is offline   Reply With Quote
Old 08-23-2005, 06:14 PM   #10210
MadMikeB's Avatar
Default Another One Way Question
Hi Guys,
I know this is a nitro tc3 part, but can anyone tell me if this one-way will fit the electric TC3?
AE Part Number 1728
http://www2.towerhobbies.com/cgi-bin...?&I=LXBMK1&P=7
MIKE
MadMikeB is offline   Reply With Quote
Old 08-23-2005, 06:41 PM   #10211
Big Rigg's Avatar
Originally Posted by ozdork
Hi Guys,
AE Part Number 1728
MIKE
Nope, the outdrives are too long... maybe with electric outdrives, but I've never heard/tried that... for that money you should just get the standard heavy duty electric TC3 one... (BTW TC4 dogbones rock!)
[url=http://www.corallyusa.com/][color=Red]- Corraly USA -[/color][/url]
[url=http://www.corallyusa.com/specializedrc/index.htm/][color=Red]- Specialized R/C -[/color][/url]
[url=http://www.thunderrc.com/eshop/][color=DarkRed]- Team Thunder RC -[/color][/url]
[url=http://www.cfxpaintworks.com/][color=DarkOrange]- CFX Paintworks -[/color][/url]
[COLOR=DarkSlateGray]- Team Ertrachter Factor - [/COLOR]
If my last name were Oxlong, I would name my kid Mike... yup Mike Oxlong
-Heywood Jablome
I don't want to pay for my sig, so yawl figure it out...
Big Rigg is offline   Reply With Quote
Old 08-25-2005, 03:01 PM   #10212
Just found out something weird and I have not seen/read about the diff assembly for the TC3.
I have a blueprint drawing of the TC3 from Team assoc website and just noticed that the steel diff assembly is different from the molded diff assembly.
The diff bolt goes into the long outdrive on the molded outdrive and the diff spring is on the diff bolt.
On the steel diff, the bolt goes into the short outdrive and the diff is on the lock nut side....
Comments? Should I change my diff around?
THX
RC Tech member #11
Old 08-25-2005, 08:16 PM   #10213
MadMikeB's Avatar
Nova,
This is the way that IRS (Irgang) recommend building the TC3 diffs. I've done it both ways with no discernable difference.
As a general comment, the TC3 diff seems to be grouped in lightweight and heavy duty specs. Apart from the different outdrives, the actual diff rings are different as well, one (I think the HD, but can't remember) uses the "D" shaped diff rings, the other uses totally round diff rings.
My personal preference is for the HD diff but using the IRS outdrives and construction method, but there is not much in it, particularly if you are running stock or 540. I can guarantee you that 19T or Mod will annihilate the lightweight diff (particularly the outdrives) in no time. Using the HD and IRS components, if you're running stock or 540, you can build the rear diff and it is fine for ages (months and months in my case). Can't say about the front cause I'm running a one-way.
As for whether you should change your diff around, if its working OK, I'd simply leave it until rebuild time.
MIKE
THX
Old 08-27-2005, 06:44 AM   #10214
Default Question
What is 7mm uptravel equal to on the AE droop gauge?
DLM2005 is offline   Reply With Quote
Old 08-29-2005, 12:38 PM   #10215
graphiteman's Avatar
Originally Posted by Rick Worth
Be careful when switching the hinge pin blocks from the front because it can change the hinge pin heights & roll centers. Just use the Losi XXX rear hubs. They are available in 0, 1/2, & 1 degree. You can use them on opposite sides to remove toe also. Just remember to use the low profile balls on the Losi hubs so the ball ends don't rub on the wheel.
I decided to try the Losi XXX- rear hubs, and the CVD driveshaft will not reach the drive cups unless I run an excessive amount of camber. Is there a differential drive cup that is a bit longer so I can give these hubs a try?
graphiteman is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
