Old 07-21-2005, 08:54 PM   #10156
graphiteman's Avatar
Default TC3
Thanks for the info TigeRyan. 0-toe in might be slippery, but at least I can try it. Does anyone make an after-market aluminum part for this car?
graphiteman is offline   Reply With Quote
Old 07-21-2005, 09:13 PM   #10157
Rick Worth's Avatar
Be careful when switching the hinge pin blocks from the front because it can change the hinge pin heights & roll centers. Just use the Losi XXX rear hubs. They are available in 0, 1/2, & 1 degree. You can use them on opposite sides to remove toe also. Just remember to use the low profile balls on the Losi hubs so the ball ends don't rub on the wheel.
Rick Worth is offline   Reply With Quote
Old 07-21-2005, 09:19 PM   #10158
Default TC3
Rick, are the Losi hubs that similar? Will it make the car wide/narrow with the changes? Same bearings etc?
Thanks for the info!
Old 07-21-2005, 09:38 PM   #10159
Rick Worth's Avatar
We've used them for years indoor carpet racing. Stock bearings & spacers work fine. This also gives you two holes for ball stud. Since the ball comes out the top it makes the link closer to the wheel. A-9847 0 degrees, A9852 1/2 degree, A9853 1 degree.
Old 07-21-2005, 09:42 PM   #10160
Dane's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to Dane Send a message via Skype™ to Dane
Originally Posted by Big Rigg
Are you running a spool, diff or oneway up front? I've had problems with my spool chattering, but the AE guys at the Reedy clued me in to glue some spacers onto the Chubs and turn the steering endpoints down a bit (~15-20%)... also I lube the pins of the dogbone with black grease, bam no more chatter! Only times I've ever had chattering with a oneway was when the axles were too worn out and would bind up (the barrel and pin where it meets with the cvd)
Hope this helps,
-T
I lowered the endpoints and squirted some grease and it seemed to help.
Which spacers did they recommend?
"the big secret is to keep practicing and never get discouraged when taking a good beating on the track" - Paul L
Dane is offline   Reply With Quote
Old 07-21-2005, 10:29 PM   #10161
Dane's Avatar
On that note, I've heard of people using Losi sterring knuckles for additional throw. Is this true? Does it make a difference?
Old 07-22-2005, 07:28 AM   #10162
Default TC3
Eexcellent information for TC3 owners Rick.... thanks!
Old 07-22-2005, 07:41 AM   #10163
trackdesigner71's Avatar
Send a message via AIM to trackdesigner71 Send a message via Yahoo to trackdesigner71
Im assuming you mean XXXS the sedan and not XXX the buggy right?
trackdesigner71 is offline   Reply With Quote
Old 07-22-2005, 08:23 AM   #10164
killingtime's Avatar
Yes the XXX-S. I've been using the Losi hub carriers for awhile now. VERY durable!! Also I get more steering from them as well.
Mike Webb
rD Squared-MW Designs-C and R racing
Final Thoughts RC club R.I.P.
killingtime is offline   Reply With Quote
Old 07-22-2005, 09:04 AM   #10165
Rick Worth's Avatar
Yes we have always been using the front hub carriers too. The steering geometry works out better & I believe the upper ball stud threads don't loosen up like the stock ones.
Old 07-22-2005, 11:00 AM   #10166
Big Rigg's Avatar
I just eyeballed the space between the chub and the steering knuckle, then cut off some little pieces from the end of a ziptie... glued one on the right side and doubled up on the left... I was worried that it would chip off in a crash, but it's held up for awhile now. Just find something that'll fit into the space you need and glue the heck out of it, I think the full on ae guys were using the white spacers, cut in half. Also heard of ppl shaving off a bunch of the steering knuckle and tapping little holes for a set screw (this seems like the most work, but best solution... I'm going to try that next weekend...)
[url=http://www.corallyusa.com/][color=Red]- Corraly USA -[/color][/url]
[url=http://www.corallyusa.com/specializedrc/index.htm/][color=Red]- Specialized R/C -[/color][/url]
[url=http://www.thunderrc.com/eshop/][color=DarkRed]- Team Thunder RC -[/color][/url]
[url=http://www.cfxpaintworks.com/][color=DarkOrange]- CFX Paintworks -[/color][/url]
[COLOR=DarkSlateGray]- Team Ertrachter Factor - [/COLOR]
If my last name were Oxlong, I would name my kid Mike... yup Mike Oxlong
-Heywood Jablome
I don't want to pay for my sig, so yawl figure it out...
Big Rigg is offline   Reply With Quote
Old 07-24-2005, 07:55 PM   #10167
Thai3g_Eclipse's Avatar
I'm trying to get my FT TC3 to race on carpet, and can anyone of you TC3 gurus recommend me any components/settings for these cars?
HPI Savage Flux HP | Tamiya TB-03
Thai3g_Eclipse is offline   Reply With Quote
Old 07-24-2005, 08:01 PM   #10168
Id PM StephenSobottka. He still runs his TC3 sometimes and he can get that thing on rails (heck he is the defending TC Stock Champ at the US Indoor Champs with a TC3)
Old 07-24-2005, 08:04 PM   #10169
Will do. Thanks for the quick response.
Old 08-08-2005, 03:14 PM   #10170
I have just bought a Racer TC3!!! is dis car still able 2 compete wid the new cars?
losi-sw is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
