Old 07-17-2005, 02:40 PM   #10141
PaZ
PaZ's Avatar
blue you name it i got/had it i dont care about the weight cause now i converted the chassis its fully blue'd but almost dead on the weight limit
Xray T2 0079
Mardave V12 VRX
Team T.J Cells
CT Race Bodies
PaZ is offline   Reply With Quote
Old 07-19-2005, 12:26 AM   #10142
can someone list the sites that support TC3 so i can read on it?? Any sites with mods for tc3 or homemade mods?
and.. my wheel wobbles a little... should i get a aluminum hex drives?
AZNracerx1989 is offline   Reply With Quote
Old 07-19-2005, 07:18 AM   #10143
Aries326's Avatar
Trader Rating: 19 (100%+)
Here's the most important one:
http://ca.geocities.com/jleblao093@rogers.com/index.htm
You can go to Team Associated's website and get setup sheets for the TC3.
Also just go through the forum from post #1 to get good setup and mod info...
Aries326 is offline   Reply With Quote
Old 07-20-2005, 09:04 PM   #10144
trx1's Avatar
Send a message via Yahoo to trx1
Arrow
Took my tc3 out today for a bit of sliding fun, had a few ask about it. none wanted to drive it....guess it was more fun watching.
trx1 is offline   Reply With Quote
Old 07-21-2005, 08:50 AM   #10145
Dane's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to Dane Send a message via Skype™ to Dane
Originally Posted by Big Rigg
Are you running a spool, diff or oneway up front? I've had problems with my spool chattering, but the AE guys at the Reedy clued me in to glue some spacers onto the Chubs and turn the steering endpoints down a bit (~15-20%)... also I lube the pins of the dogbone with black grease, bam no more chatter! Only times I've ever had chattering with a oneway was when the axles were too worn out and would bind up (the barrel and pin where it meets with the cvd)
Hope this helps,
-T
I'm running a front spool so I'll take your suggestions - thanks for the info.
"the big secret is to keep practicing and never get discouraged when taking a good beating on the track" - Paul L
Dane is offline   Reply With Quote
Old 07-21-2005, 04:13 PM   #10146
Aries326's Avatar
You were drifting it? Cool! I drift mine too. How'd it go? go to http://www.driftrcentral.com for more info on drifting, check out the bodies that people have and to download some rc drift videos.
Old 07-21-2005, 04:38 PM   #10147
big rigg - what brand spool do you run?
DLM2005 is offline   Reply With Quote
Old 07-21-2005, 04:53 PM   #10148
anyone got good set up for rubber tires cs-27, the track surface is medium and the traction is medium-->high
thanks
Alex
brooklynrc is offline   Reply With Quote
Old 07-21-2005, 05:17 PM   #10149
Dane's Avatar
thanks
What powerplant do you plan to run? Here is a baseline setup that will get the ball rolling...
Front
Blue Assoc. Spring
40 wt
#2 pistons
1.5 deg neg. camber
middle hole on shock tower
Spool diff
Rear
Silver Assoc. spring
40 wt
#2 pistons
1.5 deg. neg camber
normal diff
Old 07-21-2005, 05:24 PM   #10150
thanks, will try that out. i was racing nitro for good # of years, just getting into electric. getting my nitro car ready for Great Lakes Challenge, so i decided to play with TC3 for a while. i just put in trinity 27t motor with some fusion matched packs
Alex
Old 07-21-2005, 05:31 PM   #10151
Dane's Avatar
Awesome. Just FYI, here is my setup for stock:
Front:
Blue Assoc. Spring
40 wt
#2 pistons
1.5 deg neg. camber
Spool diff
Shocks on outside on arm
#6 droop
stock swaybar (.055)
camber links on upper inside
2 deg. kickup
2 deg caster blocks
4.5 mm ride height
Rear
40 wt
#2 pistons
1.5 deg. neg camber
normal diff
2 deg toe in
2 deg anti-squat
shocks on outside hole on arm
#4 droop
camber link on outside on upright and upper inner on tower
short wheel base
4.5 mm ride height
Also, I moved the batteries closer to the center.
Hope this helps and have fun
-Dane
Old 07-21-2005, 07:39 PM   #10152
graphiteman's Avatar
Default TC3
Does anyone know if there are other options available for the rear toe-in for the TC3. I am looking for .5, 1.0 or 1.5 degrees.... similar to the Tamiya 415.
The car works great.... I just want to play around a bit with different settings.
graphiteman is offline   Reply With Quote
Old 07-21-2005, 09:07 PM   #10153
Big Rigg's Avatar
Just the normal ae one...
[url=http://www.corallyusa.com/][color=Red]- Corraly USA -[/color][/url]
[url=http://www.corallyusa.com/specializedrc/index.htm/][color=Red]- Specialized R/C -[/color][/url]
[url=http://www.thunderrc.com/eshop/][color=DarkRed]- Team Thunder RC -[/color][/url]
[url=http://www.cfxpaintworks.com/][color=DarkOrange]- CFX Paintworks -[/color][/url]
[COLOR=DarkSlateGray]- Team Ertrachter Factor - [/COLOR]
If my last name were Oxlong, I would name my kid Mike... yup Mike Oxlong
-Heywood Jablome
I don't want to pay for my sig, so yawl figure it out...
Big Rigg is offline   Reply With Quote
Old 07-21-2005, 09:37 PM   #10154
Default TC3
The AE one in the kit does not allow for anything less than 2 degrees. The rear arm mounts are 2 and 3 degrees. Can you explain how I get less than 2 degrees of rear toe-in Big Rigg?
Old 07-21-2005, 09:41 PM   #10155
TigeRyan's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to TigeRyan
You can use the front inner hinge pin block in the rear to get zero degree toe, and I think if you use one of the optional fronts you can get either 1 or 1.5 degrees....not 100% of that, but I know you can get 0 degree....
SixFootTiger Cell Phone R/C Calculator - http://cell.sixfoottiger.com -
Android Marketing Place - R/C Calculator (https://market.android.com/details?id=com.sixfoottiger.andoid.rccalc&feature=search_result)
TigeRyan is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 05:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 02:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 08:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 09:26 PM
SEO by vBSEO 3.5.0
