Old 06-30-2005, 01:45 PM   #10096
PaZ
PaZ's Avatar
does anybody here have a problem with the ally under chassis screw heads stripping? i go through loads of blue ally screws in a season cause they strip and don't come out, but they are essential to go with me blue chassis si i cant go to the old ones. Anybody got any idea or is it just me overtightening them?
Xray T2 0079
Mardave V12 VRX
Team T.J Cells
CT Race Bodies
PaZ is offline   Reply With Quote
Old 06-30-2005, 01:49 PM   #10097
Big Rigg's Avatar
overtightening would cause that, as well as if your tool has a rounded tip (keep it clean sickos!) make sure your tools are not worn
[url=http://www.corallyusa.com/][color=Red]- Corraly USA -[/color][/url]
[url=http://www.corallyusa.com/specializedrc/index.htm/][color=Red]- Specialized R/C -[/color][/url]
[url=http://www.thunderrc.com/eshop/][color=DarkRed]- Team Thunder RC -[/color][/url]
[url=http://www.cfxpaintworks.com/][color=DarkOrange]- CFX Paintworks -[/color][/url]
[COLOR=DarkSlateGray]- Team Ertrachter Factor - [/COLOR]
If my last name were Oxlong, I would name my kid Mike... yup Mike Oxlong
-Heywood Jablome
I don't want to pay for my sig, so yawl figure it out...
Big Rigg is offline   Reply With Quote
Old 06-30-2005, 01:50 PM   #10098
Be sure to clean out the socket where the tool goes. If it has dirt in it then the tool won't go all the way in and will slip/strip.
JWATT is offline   Reply With Quote
Old 06-30-2005, 01:52 PM   #10099
trx1's Avatar
Send a message via Yahoo to trx1
Arrow
Also, where can i get the clear sedan wheels at they looked awsome and i would like to have a set in blue for my car. Would like to find a tuning guide for this car too..mabe it will help me stoip sliding
trx1 is offline   Reply With Quote
Old 06-30-2005, 04:14 PM   #10100
Aries326's Avatar
Trader Rating: 19 (100%+)
Default Screw Stripping
One of the gurus here before helped me about before on this issue.
I was doing some work on my TC3 and the screws on the bottom of the chassis stripped on me. I had to drill some out. The guys suggested that when I put the new tranny cases in to first use a tap or a steel screw then put in the aluminum team screws. Apparently, these strip quite easily and tend to heat up and expand as you screw them in, thus getting tighter and tighter to put in then stripping occurs. I did what they suggested and it worked like a charm. I also got away from using the L shaped hex wrenches and bought some decent duratrax ultimate drivers
Aries326 is offline   Reply With Quote
Old 06-30-2005, 11:18 PM   #10101
trx1's Avatar
Arrow
come on, lets type out there, SOMEONE's gotta know about these wheels??
Old 07-01-2005, 04:12 AM   #10102
Team Duratrax's Avatar
Send a message via MSN to Team Duratrax
Thats understandable about using a steel screw first but how does an aluminium screw expand from only screwing it in? I could understand if you held it up to a blow torch.
Sean
Team Duratrax is offline   Reply With Quote
Old 07-02-2005, 10:53 PM   #10103
Aries326's Avatar
Sean
Friction? I really don't know to tell you the truth. All I know is that the steel screw trick worked when I installed my new tranny gear box.
Old 07-03-2005, 04:39 AM   #10104
killingtime's Avatar
The transparent colored dishes you're looking for are made by OFNA. They have them in a couple colors too. Tower Hobbies carries them, just do a search for "clear wheels", it'll come right up.
Mike Webb
rD Squared-MW Designs-C and R racing
Final Thoughts RC club R.I.P.
killingtime is offline   Reply With Quote
Old 07-03-2005, 08:34 AM   #10105
protc3's Avatar
just to explain the binding aluminum screws for you guys.aluminum heats up very quickly and also disapates heat very quickly.the tranny housings are a graphite impregnated molded plastic which is extremely abrasive.from screwing the screw into the housing,the friction creates a ton of heat being that there is no lubrication.aluminum has a tendency to heat up and expand quicker than steel due to its properties therefore when it it expands it will more or less weld itself in place.(not really weld but you see where im going with this ).now what you can do to avoid this is to put a lubricant on the thread to minimize the friction causing the heat and expansion,use a tap that will cutt the threads into the hole instead of roll forming it with the screw,or use a steel screw which will not expand as fast as the aluminum.i,however,get lazy and just lube the screw so i only need to do it 1 time.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 07-03-2005, 08:46 AM   #10106
protc3's Avatar
a good place to get all colors in aluminum screws,nuts and washers is fastener-express.com
very good prices
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 07-03-2005, 08:22 PM   #10107
crACkeD ChaSsiS's Avatar
Send a message via AIM to crACkeD ChaSsiS Send a message via Yahoo to crACkeD ChaSsiS
Default tc3 victiry
Came in 1st today with my tc3 over a jrx-s/xray/pro4 and i had tq and i ran 23 laps and they ran 22 laps! just wanted to share my victory, bcuz the tc3 is still winning! and this was in the pro class not rookie!!
L8er
crACkeD ChaSsiS is offline   Reply With Quote
Old 07-03-2005, 10:13 PM   #10108
protc3's Avatar
thats great buddy.im putting my tc3 back together now.i missed it and it always handled so well
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 07-03-2005, 10:50 PM   #10109
L8er
Funny you should say that, i just did the same here in MD. I'm in the "pro" class versus jrx-s/x ray/ and pro-4's too. Of course having the BMI chassis didn't hurt
Mike Webb
Old 07-03-2005, 11:12 PM   #10110
Default tc3 factory
im not running the BMI chassis. just the factory tc3 with batts moved to centerline! ill get the bmi once i really start to get faster, and then ill see if i can improve even more with the bmi chassis!!
oh ya and in 1 race i was running a 3000 and i won that race! but in the
A-main i ran a 3600!!!
New to the forum mig rod Electric Off-Road 1 01-05-2008 05:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 02:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 08:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 09:26 PM
SEO by vBSEO 3.5.0
