Old 06-11-2005, 11:16 PM   #10051
Aries326's Avatar
Trader Rating: 19 (100%+)
Originally Posted by Team Duratrax
The whole new steering assembly in the TC4 would be a nice change in the TC3 if there is a way to convert it.
Sean
Here's the link to convert it:
http://ca.geocities.com/jleblao093@r...eering_tc3.htm
Aries326 is offline   Reply With Quote
Old 06-11-2005, 11:22 PM   #10052
Team Duratrax's Avatar
Send a message via MSN to Team Duratrax
Well there you go I suppose anything can be done when thought.
Sean
Team Duratrax is offline   Reply With Quote
Old 06-12-2005, 01:53 PM   #10053
protc3's Avatar
if you wanted to go with a carbon fiber chassis kit,my BMI TC3 kit offers the option of running the nitro and tc4 steering racks in 2 positions for more ackerman adjustment.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 06-12-2005, 02:34 PM   #10054
NOZ69's Avatar
Speaking of Carbon Fibre Chassis`s....
I was thinking of getting a TC4 CF Chassis kit & retro fitting the TC3 driveline to it..WOULD this be possible without to much hassle. "TC3/4 Hybrid"
My thinking is that by doing this I`ll bring my TC3 up to today`s chassis standards & get some "BLING BLING" too. Also cheaper than buying a new car,if i can use most of the TC3 parts (i`ll change to TC4 steering too).As i can get a TC4 CF chassis kit for around $100-110 USD
Cheers
FT TC4, LRP TC Sphere, LRP X-11 13.5
SC10 4x4
M03M Suzuki Swift
Power by Feral
Sanwa MX-3 FHSS
NOZ69 is offline   Reply With Quote
Old 06-12-2005, 05:16 PM   #10055
Charles Leto's Avatar
the CVD's, diffs, trannys, drivline and diff cases are the same between them all
Charles Leto is offline   Reply With Quote
Old 06-12-2005, 05:59 PM   #10056
loopedeloop's Avatar
What about bulkheads/shock mount uppers,
ie.
will tc4 SSG silver c/f parts fit the tc3 ?link :
http://www.speedtechrc.com/store/ebp...id=451&id=5159
single peice gear input shafts
http://www.speedtechrc.com/store/ebp...id=445&id=5018
loopedeloop is offline   Reply With Quote
Old 06-12-2005, 06:06 PM   #10057
to much weight to the drivetrain, the shock tower mounts for the FT TC4 and TC4 team are the same as the TC3 only the mounts were changed
if by bulkheads you mean chassis braces where the camber links are on the 4 Team are interchangable with the 3, when it comes to the FT 4 they are diff
to run TC4 towers u need to run TC4 chassis braces
Old 06-12-2005, 06:14 PM   #10058
trx1's Avatar
Send a message via Yahoo to trx1
Arrow
Couldnt you get a peice of CF,or graphite and make your own chassis for the tc3 and what about plexiglass
trx1 is offline   Reply With Quote
Old 06-12-2005, 06:42 PM   #10059
plexi glass is to weak, and to flexible it takes a lot of work to make your own CF chassis, unless your an engineering genious. it takes a lot of measuring and you have to be very precise, Cf is also expensive, if you want a CF chassis BMI is the best way to go
Old 06-12-2005, 07:17 PM   #10060
Aries326's Avatar
Technically, you could. There's a guy at my brother's job who is really into racing and he also builds custom chassis for customers. He also charges an arm and a leg... I'm sure most of his designs are copied from existing ones.
Old 06-12-2005, 08:10 PM   #10061
trx1's Avatar
Arrow
well, since i aint rich... there goes that idea
Old 06-12-2005, 08:12 PM   #10062
trx1-have u ever raced at planet R/C????
Old 06-12-2005, 08:21 PM   #10063
trx1's Avatar
Arrow
no i havent the last place i ran was new castle when i ran the legend class 2 yrs ago. since my friends hubby died, i havent had a ride to go racing Would LOVE to race again, but with no ride except my scooter......
Old 06-12-2005, 11:11 PM   #10064
NOZ69's Avatar
Thanks for the replies..
I`ve already looked into this...have sourced some CF sheet for a "slab" of beer, BUT it`s not the best (from a boat builder) in finish so i gave the idea a miss.
Cheers
SC10 4x4
M03M Suzuki Swift
Power by Feral
Sanwa MX-3 FHSS
Old 06-17-2005, 07:43 AM   #10065
trx1's Avatar
Arrow probs arise....
I found a great place to run, blacktopped lot. close to home tooo. now heres the prob:
Car wants to slide everywhere. no grip with the stock tires/wheels. this is NOT fun at all. would a set of green dot foam tires help at all??
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
