Old 05-10-2005, 10:57 AM   #10021
Trixter's Avatar
About 2 years ago I found some really neat parts from Schumacher (sp). I think they are called 'blades'. I regularly run a 9 turn double in my car and have had no mishaps as yet. also they cut the wear down to nothing and there is no slop in the composite shafts (bones) and the diff half.
http://www.racing-cars.com/usa/produ...ecnumber=57725
Try this web page. I guess now they come on the shafts already. Who knew?
Slash 4X4, Bone stock and trying to keep it that way.
PRO MATCH BATTERIES.....THANKS JEFF !!
Trixter is offline   Reply With Quote
Old 05-10-2005, 05:48 PM   #10022
thats cool i am going to use thous thanks
rcracer333 is offline   Reply With Quote
Old 05-11-2005, 09:55 AM   #10023
When i cut out the battery place am i ablke to ru it liek that? or do i need to stifdfin it out.
Old 05-17-2005, 07:05 PM   #10024
Csaari77's Avatar
Trader Rating: 34 (100%+)
What is the difference between a tc3 gear case and a ntc3 gear case? Can I use the Ntc3 gear case on an electric?
Half-A$$ Racing - Problem solved, problem staying solved!
Awesomatix - Serpent - Tekin - Futaba - Cooper Motorsports.
Csaari77 is offline   Reply With Quote
Old 05-17-2005, 07:09 PM   #10025
Paul_TC4's Avatar
Send a message via AIM to Paul_TC4
The Diff Cases are all the same. (NTC3/TC3/TC4).
Paul_TC4 is offline   Reply With Quote
Old 05-22-2005, 11:35 PM   #10026
R/C Tech Charter Subscriber
Trader Rating: 24 (100%+)
Anyone interested in a Warpspeed TC3? PM me with offers if you are, but be reasonable lol.
[B]RC Tech Subscriber #[COLOR="Red"]79[/COLOR]
[URL="http://www.rctech.net/forum/showthread.php?t=83030&highlight=Red"]My RC Tech Feedback Thread[/URL][/B]
Red Z is offline   Reply With Quote
Old 05-23-2005, 03:34 AM   #10027
PaZ
PaZ's Avatar
there sweet cars handle well when set up to
Xray T2 0079
Mardave V12 VRX
Team T.J Cells
CT Race Bodies
PaZ is offline   Reply With Quote
Old 05-28-2005, 03:43 AM   #10028
NOZ69's Avatar
G`day ppl`s,
Just after a gear ratio starting point for a 19 Turn double.
Taking the step up from a Tamiya Sport Tuned..
Does does an overall ratio of around 6.5:1 sound okay
I ran a 27 Turn Monster Stock last meet with a ratio of 6.0:1 (30/72) & the motor was just warm after a race
Cheers
FT TC4, LRP TC Sphere, LRP X-11 13.5
SC10 4x4
M03M Suzuki Swift
Power by Feral
Sanwa MX-3 FHSS
NOZ69 is offline   Reply With Quote
Old 06-05-2005, 12:47 AM   #10029
Aries326's Avatar
Trader Rating: 19 (100%+)
Default Stripping Screws
Anyone here strip their factory team screws on the bottom of the chassis that hold the tranny case? Despite using a hex driver (a cheap one from Tower), I still managed to strip a bunch of them. I had to drill them out. Unfortunately, while drilling out one of them, the bit slipped and damaged the graphite chassis a bit. Now it looks like two holes over lapping each other. Any tech tip out there to fix this? My brother says I should just throw some glue in there to patch it up after I put in the screw. Any other tips? Thanks for the help.
Aries326 is offline   Reply With Quote
Old 06-05-2005, 02:45 AM   #10030
A good way to prevent it in the first place is to use a tap, or even a steel screw(same exact size as the aluminum ones) and pre-thread each hole so that the aluminum screws will go in and out easier without putting too much stress on their allen hex that can easily strip.......you can just put some glue like your brother said but It might not look too good... and if the holes connect, the glue will probably break at some point.......I have a spare Factory Team chassis (that I have no use for) that has had the batteries moved twords the center just the right amount that your welcome to.......PM me if you want it .................Joe
1/8 Scale: Tekno EB-48.2... Tekin RX-8 GEN-2 W/2050kv... Airtronix M11-X Radio... HiTec HS-7954SH Servo...
1/10 Scale: Associated B-5(rear motor)...Tekin RSX Gen-2 W/8.5t... Savox SC-1258-TG Servo
Joe B is offline   Reply With Quote
Old 06-05-2005, 04:59 AM   #10031
protc3's Avatar
joe is right.you can tap the whole or if you dont have a tap handy i usually put black grease on the threads of the screw when using aluminum screws because the screw heats up when you screw them in due to friction.this expands the screw and causes binding due to expansion of the screw.the grease will keep the screw cool so it doesnt bind and also not allow it to bind due to the lubrication.hope this helps.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 06-05-2005, 08:36 AM   #10032
Aries326's Avatar
Wow, I had never even thought of doing those things you guys mentioned. I didn't know the aluminum screws expanded as you screwed them in. No wonder the binding would take place right towards the end. Thanks for the tips guys!!!
Henry
Old 06-05-2005, 05:31 PM   #10033
protc3's Avatar
no problem buddy.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 06-05-2005, 10:43 PM   #10034
Doesn't Lunsford make some kind of "thread lubricant" in a capsule form? I bought some like that from my LHS and they do the same thing.
What's the best way to lighten the TC3 chassis?
Warpspeed TC3 chassis for sale-make me an offer.
Old 06-06-2005, 10:16 PM   #10035
Charles Leto's Avatar
get a BMI chassis, its a little lighter and stiffer, if u try taking away material from the stock TC3 chassis you'll end up loosing stiffness
Charles Leto is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 05:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 02:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 08:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 09:26 PM
SEO by vBSEO 3.5.0
