Like Tree4Likes
Old 05-02-2005, 12:58 AM   #10006
oreo's Avatar
Default ....one problem [w/ quite a few solutions]
....so, the steerin' prob./solution.....that's a good point with the ill-functioning dif. - sorry for the long-winded attempt @ explainin' .....& the rock in the steering rack....I would have over-looked also:Ya' learn somthin' new everyday.....
oreo is offline   Reply With Quote
Old 05-02-2005, 06:14 AM   #10007
Wallstreet- Check the servo saver, make sure it is tight. If loose it can cause loss of control. Also, try to isolate the problem as to the front or back of the car by removing the shaft, diffs, or dog bones. Test the car in 2wd rear, 2 wd front, and see if you can isolate it to one end of the car.
Hope this helps.
JWATT is offline   Reply With Quote
Old 05-02-2005, 06:37 AM   #10008
wallstreet's Avatar
Trader Rating: 20 (92%+)
Send a message via AIM to wallstreet
alright i will check that out and see what i come up with
wallstreet is offline   Reply With Quote
Old 05-02-2005, 04:38 PM   #10009
mistercrash's Avatar
R/C Tech Charter Subscriber
Originally posted by PaZ
mistercrash- yea all the numbers were the right ones.
Now how do i buld it so i know before i order it a link to a site would do
http://ca.geocities.com/[email protected]/index.htm
It can also be found on the Team Associated site. Go to their R/C Links page, then look for "TC3 Mods"
No brain, no headaches.
mistercrash is offline   Reply With Quote
Old 05-05-2005, 11:01 PM   #10010
Trader Rating: 24 (100%+)
What's the best way to set tweak?
RC Tech Subscriber # 79
Red Z is offline   Reply With Quote
Old 05-06-2005, 04:09 AM   #10011
PaZ
PaZ's Avatar
cheers MisterCrash, i just got the whole lot of ebay for 7 quid!
Xray T2 0079
Mardave V12 VRX
Team T.J Cells
CT Race Bodies
PaZ is offline   Reply With Quote
Old 05-06-2005, 04:09 PM   #10012
Hp1RaCeR's Avatar
Send a message via AIM to Hp1RaCeR
hey does anyone have a goood setup for a BMI tc3 on carpet. Not a very open track small and all inside turns. please PM me with a setup i would greatly appreachate it
Hp1RaCeR is offline   Reply With Quote
Old 05-06-2005, 04:11 PM   #10013
Hp1RaCeR's Avatar
is your car tweaked?
Originally posted by wallstreet
I have a question for an tc3 guy to please pm me or post answers to help me out. I just started driving my tc3 and the car is always pulling to the right or the left on full throttle. I have tried to get it close with my radio, but i just cant seem to get it going pretty straight.
ALL TIPS AND ANSWERS ARE WELCOMED
PLEASE HELP
Old 05-07-2005, 02:37 AM   #10014
MadMikeB's Avatar
Can anyone answer this for me - on a stock TC3 setup, if you push the front of the car down, should you be able to make the chassis touch the track?
MIKE
MadMikeB is offline   Reply With Quote
Old 05-07-2005, 05:58 PM   #10015
Nova F1 Racer's Avatar
MIKE
Not that I'm aware of... It depends if you are pushing with littleor no force. If it takes a lot of pressure ( and the none of the wheels are off the ground ) then it should be al right. If not then that means the car is bottoming out and control of the car is now in the hands of the car parts owner and the local hobby shop..
This is DICK!!! And you're NOT!
RC Tech member #11
Aussie Rules Footy, Brisbane LIONS!!
[url]http://www.pitter-pat.com/[/url] for pet care needs in Northern Virginia
Nova F1 Racer is offline   Reply With Quote
Old 05-08-2005, 03:47 AM   #10016
MadMikeB's Avatar
Thanks for the reply. It takes quite a lot of pressure, so I'm guessing that its normal. I actually have two TC3's but the other one has Tamiya TRF shocks fitted and it feels completely different, so I don't have much to go on. The TC3 I'm asking about was set up by the previous owner for carpet, and was super stiff. I just put some softer springs in it, and was surprised that I could push (firmly) on the front and the chassis would bottom out.
MIKE
Old 05-08-2005, 07:34 AM   #10017
wallstreet's Avatar
does anyone have a chart that i can print out that shows roll out for a tc3?
Old 05-08-2005, 03:18 PM   #10018
PaZ
PaZ's Avatar
Will the TC4 top bumper brace number AS2225 fit to the TC3? If so how?
Thanks PaZ
Xray T2 0079
Mardave V12 VRX
Team T.J Cells
CT Race Bodies
Old 05-09-2005, 10:23 AM   #10019
tom235's Avatar
go to gearchart.com
tom235 is offline   Reply With Quote
Old 05-10-2005, 09:18 AM   #10020
gibbous's Avatar
Hi all, I'm just getting back into racing after a 2 year hiatus. I used to run stock and mod with my TC3s.
I had lots of trouble running composite or aluminum bones with a oneway in mod, so I had to upgrade to steel. Does anyone know if *19-turn power* will require the same "beefyness" with a oneway?
gibbous is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
