Old 04-30-2005, 08:31 PM   #9991
crACkeD ChaSsiS's Avatar
Send a message via AIM to crACkeD ChaSsiS Send a message via Yahoo to crACkeD ChaSsiS
Default tc3 problem
hello all im having a problem with my tc3. everytime i spin the wheels without the pinion on the motor and i turn the wheels left or right it seems to bind/stop and slows down really hard and quick. like a jerky stop motion, and i just cleaned the bearings today and its alot freer but still the problem exist. could it be bad bearings or need a diff rebuild or? this does not happen when the wheels are pointed forward! plz any info well appreciated ty
Steven Alexander
crACkeD ChaSsiS is offline   Reply With Quote
Old 04-30-2005, 08:43 PM   #9992
wallstreet's Avatar
Trader Rating: 20 (92%+)
Send a message via AIM to wallstreet
I have a question for an tc3 guy to please pm me or post answers to help me out. I just started driving my tc3 and the car is always pulling to the right or the left on full throttle. I have tried to get it close with my radio, but i just cant seem to get it going pretty straight.
ALL TIPS AND ANSWERS ARE WELCOMED
PLEASE HELP
wallstreet is offline   Reply With Quote
Old 04-30-2005, 08:58 PM   #9993
Send a message via AIM to greencactus3
are you unsure of if it pulls to the right or left as in dont remember which side? or does it pull in one way sumtimes and the other way other times? if it was consistently pulling in one direction it would be either one side has more friction ie bad bearings or binding, or a bad setup. bad weight balance. spring preload etc. if it drifts in random directions can be a bad setup or a bad diff.
greencactus3 is offline   Reply With Quote
Old 04-30-2005, 09:03 PM   #9994
wallstreet's Avatar
it pulls differently depending on how i try and correct it with my radio. I just cant seem to get it to run straight . And at the track today i had a guy helping me and we kinda got it somewhat, but it still goes in one direction when i give it full throttle
Old 04-30-2005, 10:45 PM   #9995
oreo's Avatar
Default .....i'm hope this is of some help to ya'....
....are ya' using the stock plastic/graphite tc-3 chassis or carbon fiber plate (ie. I.R.S.,warpspeed,Balistic)type of chassis; The reason I asked is cos' the C.F. types may cause alittle interference problems (kinda like what you're experiencing)....see if the servo wires aren't crossed up near the receiver antenna/ motorwires....inspect the wires themselves, too-another reason (to your probs)torque-steer....rubber tires on hard wood / slick surface flooring can amplify torque-steer....
oreo is offline   Reply With Quote
Old 04-30-2005, 10:58 PM   #9996
Registered User
RC Noob's Avatar
Send a message via AIM to RC Noob Send a message via MSN to RC Noob
lol thanks for the help guys..but i found out wta was the problem..LMAO there was a huge rock stuck in one of the little triangle places and it was rubbing on the steering rack..lol
RC Noob is offline   Reply With Quote
Old 04-30-2005, 10:59 PM   #9997
wallstreet's Avatar
so your saying a carbon chassis might keep it from doing what it is i am getting?
Its just not driving anywhere near straight is basically what it comes down to
Old 04-30-2005, 11:20 PM   #9998
oreo's Avatar
Default .....oops, let me see if I can clarify....
.....I was assuming that the steering being pulled left/right was related to the wiring set up-a C.F. chassis may tend to act like a big antenna, & thus possibly picking up [unwanted] inputs/frequencies-basically, like interference....A fellow driver experienced gliching w/ an M8 controlling a TC-3 (w/ the I.R.S. chassis): A nearby low power line induced a terrible glich sending it into the barriers.... a great car/chassis but may be keeping wires (including ant.) insulated from the C.F. chassismay improve on the steering problem.....
Old 05-01-2005, 09:38 AM   #9999
wallstreet's Avatar
nah its not that. It just has something to do with the car and it not wanting to run straight
Old 05-01-2005, 11:26 AM   #10000
wallstreet's Avatar
also if someone can recommend a place to get a tc3 onroad outdoor setup that would be awesome
Old 05-01-2005, 11:57 AM   #10001
PaZ
PaZ's Avatar
check out associated website theres alot of differnt types of set ups there there good starting points
Xray T2 0079
Mardave V12 VRX
Team T.J Cells
CT Race Bodies
PaZ is offline   Reply With Quote
Old 05-01-2005, 11:59 AM   #10002
tc3stocker's Avatar
Send a message via AIM to tc3stocker Send a message via Yahoo to tc3stocker
Default Re: tc3 problem
Steven Alexander
Check the diff gears, this happened to me and it was just a brokem diff gear.
tc3stocker is offline   Reply With Quote
Old 05-01-2005, 11:59 AM   #10003
tc3stocker's Avatar
PLEASE HELP
torque steer-the car was born with it and most likely will never let it go
Old 05-01-2005, 12:05 PM   #10004
tc3stocker's Avatar
get online and I will give you one (AIM)
Old 05-01-2005, 12:27 PM   #10005
PaZ
PaZ's Avatar
mistercrash- yea all the numbers were the right ones.
Now how do i buld it so i know before i order it a link to a site would do * i dont need to dremel the chassis as im running a flat one already*
Xray T2 0079
Mardave V12 VRX
Team T.J Cells
CT Race Bodies
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
