Old 04-14-2005, 10:44 AM   #9916
R/C Tech Charter Subscriber
Trader Rating: 24 (100%+)
I wanna run one of my TC3's w/foam tires. My question is what camber link mounting spots should I use? How much camber? How much droop? Ride height?
[B]RC Tech Subscriber #[COLOR="Red"]79[/COLOR]
[URL="http://www.rctech.net/forum/showthread.php?t=83030&highlight=Red"]My RC Tech Feedback Thread[/URL][/B]
Red Z is offline   Reply With Quote
Old 04-14-2005, 04:33 PM   #9917
Aries326's Avatar
Trader Rating: 19 (100%+)
Check out Associated's website. They have a bunch of setup sheets posted for different tracks/surfaces and foams/rubber wheels...
Aries326 is offline   Reply With Quote
Old 04-14-2005, 05:18 PM   #9918
Toma2525's Avatar
Default TC3 Team Kit vs Graphite Upgrade
Is it worth it to upgrade to the full graphite conversion? Is graphite lighter? Stronger?
Toma2525 is offline   Reply With Quote
Old 04-14-2005, 05:29 PM   #9919
Jiveslug's Avatar
Hey guys. So I saw on another thread that people need to "massage" the diff cases to get the TC# drivetrain to run smoothly. What does this mean? How do you do it? My TC3 has 1 race on it, so Im wondering if this drivetrain thing is sapping any speed. Please let me know. Thanks!!
Jive
Jiveslug is offline   Reply With Quote
Old 04-14-2005, 05:40 PM   #9920
I'm not exactly sure what "massage" means, but I can say that the diff cases on the TC4 are very free right out of the box. There are too things you need to do to make sure your drivetrain is free. First, make sure you remove any burrs from the back of the bevel gear before installing it and second, you'll need to take a little time to make sure it's shimmed properly. Shimming is the key to a free drivetrain.
DOTMAN is offline   Reply With Quote
Old 04-14-2005, 05:46 PM   #9921
Jiveslug's Avatar
Er.... Jiveslug=Noobie. Please speak Noobish.....
Old 04-14-2005, 06:15 PM   #9922
okay - bevel gear is small gear in diff case. Remove any extra material from back of gear. Shims - thin spacers behind small gear in diff case. Thin spacer adj contact with big gear. Add/remove spacer until drivetrain spin free. Make change and test one spacer at a time. There also thin spacer between diff outdrive and outdrive bearing (big bearing in kit). May need adjust too. This take time but make big difference.
Old 04-15-2005, 09:52 AM   #9923
Jiveslug's Avatar
Smartass.
Old 04-15-2005, 10:20 AM   #9924
Charles Leto's Avatar
the Graphite conversion or carbon or either one (they are the same thing just by a different name) the graphite will make it stiffer, and more responsive feel to the car however it might be a little less durable since its so much more rigid
the composite/plastic is stronger in a way but a lot more flex
Charles Leto is offline   Reply With Quote
Old 04-15-2005, 10:27 AM   #9925
Originally posted by Jiveslug
Smartass.
Old 04-16-2005, 10:45 PM   #9926
Where is the best place to remove weight on a TC3?
Old 04-17-2005, 10:58 AM   #9927
you could go the Carbon kit route or probly the most important would be drivetrain but that is its good and bad side
lighter drivetrain-good side-more acceleration and less rotating mss -bad side---less rotating mass less momentum to keep the car moving
Old 04-18-2005, 11:13 AM   #9928
tom235's Avatar
i put the light weight input shafts and a carbon drive shaft in and cut my spur. it is a rocket out of the hole
tom235 is offline   Reply With Quote
Old 04-18-2005, 12:02 PM   #9929
SammyXp's Avatar
I have to disagree - the momentum is pretty much just a bad thing. Even on wide open, flowing tracks where you like to carry speed continually, it's easy enough to use partial throttle to keep your speed up through a turn.
Technically, the best weight to remove is firstly rotating mass, then static mass at the highest point (greatest effect on CG). So a lightweight body would make a bigger difference to your CG than a lightweight chassis. Actually, decreasing the weight of your chassis *increases* your center of gravity (all other things being equal).
SammyXp is offline   Reply With Quote
Old 04-19-2005, 01:25 PM   #9930
mutley001's Avatar
Default Just Bought A TC3
Hi Guys
New to this forum and just bought a FTTC3 as a car to race outdoors (i have a Mi2 to run inside). Like to know if there are any major modifications for it to be competitive, any tips or pointers on setups, tyres for tarmac etc? I only run stock at the mo on quite a fast, long track. What pitch gears come as std? 48? I have no instructions, is it possible to download them from anywhere?
Thanks for any help in advance
Paul
mutley001 is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 05:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 02:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 08:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 09:26 PM
SEO by vBSEO 3.5.0
