Old 04-12-2005, 08:58 PM   #9901
BlackKat's Avatar
Will TC4 parts (arms, shock towers, chassis braces & hingepin mounts) even fit on the TC3?
BlackKat is offline   Reply With Quote
Old 04-13-2005, 01:28 AM   #9902
Send a message via Yahoo to xxmerlynxx
that's my question exactly!... just b/c i plan on using a diff chass shouldn't matter as it's still drilled for the fact. ntc3/etc3 setup, so if it works on a normal etc3/ntc3 chassis, it should [in theory, of course] work on my SSG chassis.
.... but from what i understand [which admittedly isn't much] the shock towers swap w/o the need for any modification whatsoever, so i'm hoping that the arm mounts are in the same boat.
xxmerlynxx is offline   Reply With Quote
Old 04-13-2005, 01:56 AM   #9903
What do you think of the Hobbico hex driver set? Have any of you guys used these?
My advise is don't bother with them, I had a set they don't last very long. They rounded of the corners of the balls (on the drivers not the screws!) and a couple even snapped the balls off of the end. The more expensive sets are more expensive for a good reason!
I have a bit of a mixture of Associated, Hudy and Trinity drivers, they are all good quality items.
colinradford is offline   Reply With Quote
Old 04-13-2005, 05:58 AM   #9904
Aries326's Avatar
Trader Rating: 19 (100%+)
Thanks for the reply. I'm putting in my order now for some quality stuff. Working with worn out L-shaped hex wrenches is starting to strip out my screws.
Aries326 is offline   Reply With Quote
Old 04-13-2005, 08:13 AM   #9905
BlackKat's Avatar
But if TC4 shocktowers go on, you gotta put the chassis braces on too
Will TC4 chassis braces work on a TC3?
Old 04-13-2005, 09:03 AM   #9906
i'm gonna go pull the tc4 manual off associated's website & look at the mounts, but the Xtreme chassis i'm using already has upper chassis braces, so i won't be using the factory ones.
Old 04-13-2005, 09:22 AM   #9907
so, i didn't actually have to go to the manual, but according to the TC4's FAQ on their website...
"14 Can I use the TC4 shock towers on my TC3?
Yes."
so i guess they should work just fine... & i don't see any need for different chassis braces, the ones i have should work just fine. thanks for the help though guys.
Old 04-13-2005, 09:24 AM   #9908
Charles Leto's Avatar
the NTC3 rack seems to be smoother, a little more durable
i dont think you can easily mate the NTC3 rack to the TC3
the towers are more durable since they are a little thicker and more tuning ability
Charles Leto is offline   Reply With Quote
Old 04-13-2005, 12:23 PM   #9909
BlackKat's Avatar
Then where would you mount your camber links?
Old 04-13-2005, 12:27 PM   #9910
the TC4 towers are a direct bolt on the only thing changed is body mount positions the TC4's are wider (farther apart) than the TC3's
Old 04-13-2005, 06:43 PM   #9911
BlackKat's Avatar
...and the camber links are vertical and bolt on the chassis brace....
Can someone with both cars just try puting the TC4 chassis brace on the TC3 LOL
Old 04-13-2005, 06:55 PM   #9912
Nova F1 Racer's Avatar
R/C Tech Charter Subscriber
Been there, installed that....
This is DICK!!! And you're NOT!
RC Tech member #11
Aussie Rules Footy, Brisbane LIONS!!
[url]http://www.pitter-pat.com/[/url] for pet care needs in Northern Virginia
Nova F1 Racer is offline   Reply With Quote
Old 04-13-2005, 06:57 PM   #9913
blackkat is right, the tc4 shock towers don't have holes for camber links, because on the tc4 they are mounted on the chassis braces. so if you want the tc4 shock towers for your tc3 you will need the chassis braces as well
Rory is offline   Reply With Quote
Old 04-13-2005, 08:15 PM   #9914
BlackKat's Avatar
And it works? Coo....
Back to Metallica at high volumes....
Old 04-14-2005, 09:34 AM   #9915
i see what you guys are saying.... thanks for pointing that out cause I had missed it. i guess i'll just stick with the penguin ones... again, thanks for the help guys
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
