Old 04-04-2005, 03:17 PM   #9811
diskostew's Avatar
Send a message via Yahoo to diskostew
Default Re: bearings
Originally posted by tom235
when you spray out your bearings do you spray out the ones on
the wheels or do you just leave them alone
I clean all my bearings when i do it. I let them soak in my integy bearing blaster and then use a light bearing oil and them re assemble the car.
diskostew is offline   Reply With Quote
Old 04-04-2005, 05:11 PM   #9812
tom235's Avatar
thanks
do you think it makes that much of a diff. with the 8 bearings
not cleaned out?
tom235 is offline   Reply With Quote
Old 04-04-2005, 05:16 PM   #9813
fjm9898's Avatar
i know for a fact that it does, but it matters how bad they are. i know a guy that cleaned his well in the middle of a race day and accually consistantly ran 0.2-0.3 seconds quicker
Xray '007 US and a bunch of other outdated stuff
fjm9898 is offline   Reply With Quote
Old 04-05-2005, 09:26 AM   #9814
diskostew's Avatar
the wheel bearings get dirty faster so it is much more important to keep those clean!
Old 04-05-2005, 09:57 AM   #9815
tom235's Avatar
thanks guys i will have to try that.
does anyone have some more speed tips? i have all ready done the diff bearings and the housings and move the bat. to the center.
Old 04-05-2005, 11:31 AM   #9816
fjm9898's Avatar
what kit is it. is it a factory team? because if so there is not much you can do. unless you are running on carpet. then if you want to spend the money i would look into getting an IRS carbon chasis or a BMI to look into stiffining the car up. but if your not a team car then getting the graphite converson kit would be a great start. I am selling an IRS TC3 take a look >>>> TC3 Factory Team with IRS Carbon Chasis
Old 04-05-2005, 11:46 AM   #9817
Send a message via Yahoo to xxmerlynxx
Default Carbon Fiber Shock Towers for Elec TC3
Ok... so I searched the archives & the only carbon fiber shock towers that I can find are made by Square R/C and those only seem to be available at Speedtech R/C . Does anyone know of any other brands or places to pick these up? I'd appreciate any leads. Thanks in advance for you help.
Adam
xxmerlynxx is offline   Reply With Quote
Old 04-05-2005, 11:51 AM   #9818
Penguin R/C makes them as well. You can also get those through speedtechrc
DOTMAN is offline   Reply With Quote
Old 04-05-2005, 12:48 PM   #9819
I am new to touring car racing and I have a TC3. When setting the front droop do you set it to the flat part of the arm or the dimple in the middle near the outer edge?
Lougabe is offline   Reply With Quote
Old 04-05-2005, 12:54 PM   #9820
Go to AE's site, and look at the manual, it will show you how to do it. You can also print it if you want.
JWATT is offline   Reply With Quote
Old 04-05-2005, 01:09 PM   #9821
tom235's Avatar
it is the FT. i run on black top with rubber tires.
Old 04-05-2005, 01:15 PM   #9822
fjm9898's Avatar
then the Ft is great for out doors. really the only major things left to get speed are high voltage batteries, tuned motor, driving skills, and having the right set up for the track. those will make the most difference but there are still other little things such as ceramic bearings but only hard core racers use them because they dont do much, they are very expensive, and they break easily. the moral is driving skill and set up cuz they dont cost much (if anything) and they make the most difference
Old 04-05-2005, 01:42 PM   #9823
thanks, DOTMAN... i appreciate that... i'm checking them out now... anybody else with any ideas?
Old 04-05-2005, 03:04 PM   #9824
tom235's Avatar
thanks fjm9898 for all your help
Old 04-05-2005, 04:45 PM   #9825
MadMikeB's Avatar
Default Diff Thrust Bolt Question
Hi People,
I'm building up a diff using the IRS lightweight alloy outdrives. It calls for a combination of AE parts from the lightweight kit ("D" rings) and the heavy duty kit ("T" Washer) and I have a question about tightening the thrust bolt.
Per the manual, you tighten until the spring is totally compressed then back off a half turn. However this is for the lightweight diff with the "captured" thrust retaining bolt.
When using the "T" bolt, this seems to me to give a pretty loose diff, and I'm wondering if this is correct? I know with the off road diffs, they use the same "T" bolt, and they call for the bolt to be nipped up and then backed off 1/8th of a turn.
Can anyone give me any ideas about an initial setting for my setup, using the "T" bolt?
MIKE
MadMikeB is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
