Old 04-02-2005, 07:49 AM   #9796
Aries326's Avatar
Trader Rating: 19 (100%+)
Originally posted by speedracer008
is the carbon fiber chassis really worth getting?
I read a post somewhere that a guy compared the weight of an all carbon chassis with all the aluminum parts to a factory tc3. They weighed just about the same. Personally, I think carbon fiber is just for the bling effect.
Aries326 is offline   Reply With Quote
Old 04-02-2005, 08:00 AM   #9797
Aries326's Avatar
Originally posted by Charles Leto
i'm going to get a FT TC3 kit here soon and was wondering if all carbon is better than all composite i will be running on carpet more than asphalt
Carbon is lighter and stiffer but composite is more durable. I'm not sure though which one warps more because of the heat from the motor. Anyone else know?
Old 04-02-2005, 08:37 AM   #9798
Charles Leto's Avatar
from what i read the carbon is of course lighter however more fragile
Carbon--lighter, more responzive, fragile
Composite--little heavier, less responsive(more flex), but alittle more durable
Charles Leto is offline   Reply With Quote
Old 04-02-2005, 10:06 AM   #9799
Jmccormick's Avatar
One thing you also might want to do is also compare tire circumfrance with the guys you are getting your gear ratios from.
A couple of MM makes a difference if you run a bigger circumfrance tire then you would want a slightly lower gear ratio.or vise versa........
Jmccormick is offline   Reply With Quote
Old 04-02-2005, 11:55 AM   #9800
Aries326's Avatar
Default Roll Pin Pain in the Butt
Any other alternative to using the Associated Universal Roll Pin in the axle? Don't they make a stainless steel polished roll pin like in my Tamiya? I had a hard time getting them out when I wanted to clean out the bearings in my TC3 and I'm having a pain putting in the new ones that I bought.
Will the Associated Stub Axle Pins & Spacers RC18T work? I'd really hate to shell out $20 for the clamping hex drives.
Old 04-02-2005, 08:43 PM   #9801
NOZ69's Avatar
Originally posted by revzalot
Got pix?
Well my camera`s fixed .. so here`s a pic
Cheers
FT TC4, LRP TC Sphere, LRP X-11 13.5
SC10 4x4
M03M Suzuki Swift
Power by Feral
Sanwa MX-3 FHSS
NOZ69 is offline   Reply With Quote
Old 04-02-2005, 08:53 PM   #9802
NOZ69's Avatar
Default Try Again !
Bugger.... the first try to get the pic up , didn`t work
Cheers
SC10 4x4
M03M Suzuki Swift
Power by Feral
Sanwa MX-3 FHSS
Old 04-03-2005, 04:52 AM   #9803
Trixter's Avatar
Default Pix of the Honda
Here is a shot of my new body that I will run this season. It needs a little more detail and then it will be ready to hit the track.
I'm looking froward to a lot of fun this summer.
Slash 4X4, Bone stock and trying to keep it that way.
PRO MATCH BATTERIES.....THANKS JEFF !!
Trixter is offline   Reply With Quote
Old 04-03-2005, 07:02 AM   #9804
roll pin issues-------AE does make a factory team full steel polished roll pin its part# 1654 although they can fall out sometimes if ur not payin attention
Old 04-03-2005, 05:44 PM   #9805
Aries326's Avatar
Thanks!!! I'll have to pick up a set. I don't want to go through the same old stuff everytime I wanna get in and clean the bearings.
Old 04-04-2005, 10:08 AM   #9806
Jiveslug's Avatar
Default TC3 Life Span?
Hey guys. I just got my TC3 on the track and I was wondering how long you guys think it will be a viable car capable of winning. I know a lot of winning has to do with the driver (and believe me, this driver needs a LOT of work), but is the TC3 close to becoming obsolete? I have the base TC3 (not the Factory Team kit) and am wondering that, as my racing skills grow, would it be better to spend the money on hopping up my TC3 or just investing in a TC4, XRay, Yokomo, etc? Opinions would be most appreciated. Thanks!
Jive.
Jiveslug is offline   Reply With Quote
Old 04-04-2005, 10:14 AM   #9807
The TC3 is still a great car and capable of winning at any race. There's only one guy that I race with that's still running a TC3 and he's very hard to beat. The difference I see in the newer cars is that they appear to be a little easier to drive. So average drivers do better because they make less mistakes.
My 2 cents
DOTMAN is offline   Reply With Quote
Old 04-04-2005, 11:25 AM   #9808
fjm9898's Avatar
i know xrays are very popular and that the tc3 is very old compared to some cars out there. one of the top guys at our tack drove a tc3 for many years but now he has switched to a pro4 and he says its a little easier to drive.
but a tc3 still wins in major events, it all matters on who is driving the car. for a starter a tc3 is a great car. eray are much more difficult to work on and if you pratice enough you can get quite fast with a tc3.
however if you want to get competitive, you might want to look into getting a few hop ups. but what you get depends on the track. if your running indoor on carpet i would get a graphite conversion or if you wanna spend the big bucks, a BMI or IRS Chasis. in fact i am selling an IRS now on here take a look >>> TC3 Factory Team with IRS Carbon Chasis
by getting a graphite or bmi.irs carbon chasis it will stiffen the car up wich is great for carpet. out door a normal chasis is fine by by getting the graphite conversion it makes the car lighter as well a stiff but dont get a bmi/irs its no worth it, in fact is my make the car worse outdoor but it matters on your set up.
lastly setting up a tc3 correctly alone makes it much better and for that i would ask around your local track and see if you cant find another guy with a tc3 to help you set up yours.
i hope i helped you out a bit, Frank
Xray '007 US and a bunch of other outdated stuff
fjm9898 is offline   Reply With Quote
Old 04-04-2005, 02:55 PM   #9809
Aries326's Avatar
Default Re: TC3 Life Span?
Jive.
I just bought a used Factory TC3 online and the buy who owned the car previously went with a spool in the front and replaced the stock 72T spur with a 100T 64P spur which he says is more efficient. He also added a swaybar to the front only. He also ran a 8T motor in it. Hope this helps.
Old 04-04-2005, 03:13 PM   #9810
tom235's Avatar
Default bearings
when you spray out your bearings do you spray out the ones on
the wheels or do you just leave them alone
tom235 is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
