Old 03-24-2005, 02:01 PM   #9766
Yes, then your odds go way up on finishing a race.
JWATT is offline   Reply With Quote
Old 03-24-2005, 02:04 PM   #9767
Aries326's Avatar
Trader Rating: 19 (100%+)
Unfortunately the LHS only races stadium trucks, dirt modifieds and whatever else is raced on a dirt oval. The only person I have to worry about beating is my brother who just picked up his car on eBay also. lol... We'll be racing at a cul-de-sac when we get these things up and running...
Aries326 is offline   Reply With Quote
Old 03-24-2005, 02:09 PM   #9768
Get a late model body, some rallye tires, and join them!!!!
Old 03-25-2005, 12:01 PM   #9769
Aries326's Avatar
Ok, I'm gonna open up the thing and clean out the diffs and the bearings. I just got a bunch of parts in from RCBOYZ.
Has anyone ever gone through the arduous task of reading all the messages in the TC3 forum and compiling a TC3 FAQ? It would be cool if we had a FAQ that addressed common questions regarding diffs, maintenance, springs, links to mods, etc... That would make it easier for noobs like me to get info and make life easier for the experts so they don't have to address the same questions over and over again.
Also, can you tell just by the color of the part if it is a team factory graphite part or a regular composite? The TC3 I bought is a team touring but from all the pics I've seen of the team factory, it seems to have the same color chassis. Thanks for the help...
Old 03-25-2005, 07:42 PM   #9770
NOZ69's Avatar
YEAH that would be a TOP idea
As i`ve only just brought a TC3 too & when using "Dial-up" going through 326 + pages looking for info is NOT an option.
Cheers
FT TC4, LRP TC Sphere, LRP X-11 13.5
SC10 4x4
M03M Suzuki Swift
Power by Feral
Sanwa MX-3 FHSS
NOZ69 is offline   Reply With Quote
Old 03-25-2005, 07:46 PM   #9771
NOZ69's Avatar
Default Steering Rack Cover
G`day ppl`s,
Has anyone used this "Steering Rack Cover" [part # 3857], is it worth while getting one over doing the NTC3 mod.
Cheers
SC10 4x4
M03M Suzuki Swift
Power by Feral
Sanwa MX-3 FHSS
Old 03-25-2005, 10:31 PM   #9772
Aries326's Avatar
Default Re: Steering Rack Cover
Originally posted by NOZ69
G`day ppl`s,
Cheers
I tried looking up that part and something else popped up. Anyway, somewhere along my bordom and search for TC3 knowledge, I came across a link here in this forum that leads you to pdf file from the team associated website that shows you how to make a cover for the steering rack out of lexan. Sorry, I don't have the link.
Getting back to my point before, we should get together and make a FAQ that has useful links and info...
Old 03-26-2005, 01:00 AM   #9773
NOZ69's Avatar
Default Re: Re: Steering Rack Cover
Yeah i thought of that too... but the original part is only a few dollars.[ $8.00 aus & $ 2.50 us]
I`ll sus out Associateds website.
Thanks for the tipoff.
Cheers
SC10 4x4
M03M Suzuki Swift
Power by Feral
Sanwa MX-3 FHSS
Old 03-26-2005, 02:14 AM   #9774
NOZ69's Avatar
Default Rack Cover
Took some tracking down but I found it...
Link to the D.I.Y. Rack Cover
http://download.teamassociated.com/p...rack_cover.PDF
I`ll give it a go, i`ve got some scrap lexan lying around
Cheers
SC10 4x4
M03M Suzuki Swift
Power by Feral
Sanwa MX-3 FHSS
Old 03-26-2005, 05:55 AM   #9775
Aries326's Avatar
Default TC3 Maintenance
Ok, the TC3 I just picked up from eBay is totally apart. The bearings and gears are soaking in WD-40. Before I put it all together again, are there any special changes I should do other than what is shown in the manual? Extra shims I should put on to improve performace or prevent gear stripping? How much diff grease should I put on? When I opened up the tranny case, it was absolutely filthy. The guy I bought it from must have put a ton of grease on the gears.
As far as bearing cleaning goes, I've read that people here go as far as opening up the bearings. Is this necessary or can I just buy the "bearing blaster" and use that to clean out the bearings? Or can I just spray the cleaner directly onto the bearings without spending $9 for the bearing blaster? Thanks for the tips...
Old 03-26-2005, 03:10 PM   #9776
Hp1RaCeR's Avatar
Send a message via AIM to Hp1RaCeR
I race a BMI tc3 on carpet that is a very small lots of turning track. I need a nice setup the rear of my car is all over the playce.
Rite now im runing 5 droop all around 5 ride hite. 60 weight in the front 50 in the rear. Purple springs in the front and copper in the rear. and a front sway bar.
I need a new setup my car is handeling very poorly anyone got some suggestions?
Hp1RaCeR is offline   Reply With Quote
Old 03-26-2005, 04:07 PM   #9777
Aries326's Avatar
I just noticed that both ends of the top half of my diff cases have holes in them right under where the middle screw for the shock tower goes into. Is this normal?
Also, if I buy a new TC3 tranny case, will this solve the binding problems I keep reading about or has the problem not been fixed by Associated yet? Will I need to buy a TC4 tranny case or one of those RDL Aluminum Tranny cases?
Definitely I think there is binding. Before I took this TC3 apart, the tranny wasn't that smooth. It would maybe keep turning for 1-2 seconds. Thanks for the help...
Old 03-26-2005, 05:21 PM   #9778
lazyboy's Avatar
Send a message via AIM to lazyboy
goto 1.5uptravel or 6 on the ae droop gauge, 4.5 ride hieght and number 2 pistons with 70/50 oil(ae), purple copper,4* caster blocks, stk front ae swaybar.2* rear toe,f-0 front block,no kickup or anti squat. double pink orange/double pink(cyan/magenta) tires..idk i cant remember anything else right now, let me know what you think
Random Guy
FT B4
Sponsored by Axiom Motors
Trackside hobbies
lazyboy is offline   Reply With Quote
Old 03-26-2005, 06:45 PM   #9779
killingtime's Avatar
Originally posted by RC Noob
website?
www.teamcrc.com
Mike Webb
rD Squared-MW Designs-C and R racing
Final Thoughts RC club R.I.P.
killingtime is offline   Reply With Quote
Old 03-26-2005, 06:48 PM   #9780
GPM makes some cheap aluminum parts for the TC3. Check this link out:
http://www.asiatees.com/model.php?br...odel=TC3&pid=1
FYI - I've had some of GPM parts overdue two months from asiatees.com. For awhile they would return my emails about why they haven't shipped, now they're starting to ignore me.
Mike Webb
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
