Old 03-22-2005, 08:11 AM   #9751
R/C Tech Charter Subscriber
Trader Rating: 24 (100%+)
I have a problem:
On my TC3 rear diff I have a horrible sound coming from the ring and pinion gear. Sounds like really poor mesh. I tried new gears, shimming until my fingers bled, new bearings, new parts, and I'm at my wits end. It is still there! Suggestions?
[B]RC Tech Subscriber #[COLOR="Red"]79[/COLOR]
[URL="http://www.rctech.net/forum/showthread.php?t=83030&highlight=Red"]My RC Tech Feedback Thread[/URL][/B]
Red Z is offline   Reply With Quote
Old 03-22-2005, 08:55 AM   #9752
I assume the other diff is fine. Swap pinions, then diff assemblys, to see if you can isolate the problem.
JWATT is offline   Reply With Quote
Old 03-22-2005, 10:51 AM   #9753
revzalot's Avatar
When I hit throttle from standing, the car tends to veer left. I've already checked toes and camber but it still veers left. You think it's loose diff?
revzalot is offline   Reply With Quote
Old 03-22-2005, 11:14 AM   #9754
Nova F1 Racer's Avatar
Check your tweak.....
This is DICK!!! And you're NOT!
RC Tech member #11
Aussie Rules Footy, Brisbane LIONS!!
[url]http://www.pitter-pat.com/[/url] for pet care needs in Northern Virginia
Nova F1 Racer is offline   Reply With Quote
Old 03-22-2005, 11:43 AM   #9755
revzalot's Avatar
How do you check tweak? I just bought a tweak board. Do you add weigth first and then adjust shocks collars? Anyone have a systematic way. This is my first ep car.
Old 03-22-2005, 12:21 PM   #9756
First, take shock off arm and verify that the arm will drop by it's own weight. If not then you probably have a bent hinge pin. Remove springs and check "pack" on the shocks. Make sure the rebound is the same. Verify that the shocks are the same length, need only compare fronts to themselves and rears the same. Re-install shocks, set ride height. Shock collars should be at approximate same setting. Put on tweak board, car should be neutral. If not, car is tweaked. Put chassis on a flat surface (glass is best) and see if chassis is flat. Adjust shocks to get car flat. If collars are not close to same, be sure springs are same length. Be sure shocks are mounted the same when comparing side to side (for ex. outer hole on one are, and inner hole on the other, same with top mounting). Another way to check tweak is to put car on flat surface, find exact center of car, and lift car at that point. Tires should leave the surface at approximately the same time. Check droop too.
Hope this helps.
Old 03-22-2005, 06:54 PM   #9757
Registered User
RC Noob's Avatar
Send a message via AIM to RC Noob Send a message via MSN to RC Noob
whats the cheapest place to get carbon fibre hop-ups, and some other aluminum hop-ups for my tc3?
thanks in advance
RC Noob is offline   Reply With Quote
Old 03-22-2005, 08:12 PM   #9758
thanks in advance
ebay
RC Tech member #11
Old 03-22-2005, 09:29 PM   #9759
Registered User
RC Noob's Avatar
BESIDES EBAY! lol i dont like bidding..lol if its cheap..there always someone using proxy
Old 03-22-2005, 11:02 PM   #9760
Secret_weapon's Avatar
Post
Anybody with a good TC3 setup for asphalt.
I run factory team, Quantom Compotition2, 12x1 Surikarn.
Any good gear ratio?
Secret_weapon is offline   Reply With Quote
Old 03-23-2005, 01:31 AM   #9761
I think that Calandra makes cool aluminum parts for the TC3. Different colors too if I recall...
Old 03-23-2005, 08:36 AM   #9762
Registered User
RC Noob's Avatar
website?
Old 03-23-2005, 08:43 AM   #9763
revzalot's Avatar
You can try teamirsrc.com
Old 03-24-2005, 02:53 PM   #9764
Aries326's Avatar
Trader Rating: 19 (100%+)
thanks in advance
GPM makes some cheap aluminum parts for the TC3. Check this link out:
http://www.asiatees.com/model.php?br...odel=TC3&pid=1
Aries326 is offline   Reply With Quote
Old 03-24-2005, 02:58 PM   #9765
Aries326's Avatar
Default Just got a TC3
I just picked up a TC3 Team Touring on eBay. I'm not sure how well this was taken care of or if the gears are as smooth as they are supposed to be. Should I take the whole thing apart, relube the diffs and clean out the bearings?
New to the forum mig rod Electric Off-Road 1 01-05-2008 05:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 02:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 08:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 09:26 PM
SEO by vBSEO 3.5.0
