Old 03-04-2005, 04:27 AM   #9721
SA_Racer's Avatar
Originally posted by RC Guru
is there like a hop up diff that comes already built or something like that?
for $50 Ill build one for you
SA_Racer is offline   Reply With Quote
Old 03-05-2005, 11:38 AM   #9722
Default New gearing suggestions?
I am new to RC, so I am still learning things. I am running my TC3 with stock gearing, 72T spur with a 25T pinion for 19T motors. I am wanting to start experimenting with new gearing to help learn more about the car.
Can anyone recommend some gearing or links to guides on gearing? Anything would be greatly appreciated.
Thanx.
Galactik is offline   Reply With Quote
Old 03-05-2005, 02:27 PM   #9723
I'm not sure what 19T motor you're running, but if you're running a Reedy or C2, you're final ratio is way too high. I run my Reedy between 5.8 and 6.0. The C2 I run between 5.9 and 6.3. I should say that I do run on open tracks.
DOTMAN is offline   Reply With Quote
Old 03-07-2005, 10:29 PM   #9724
R/C Tech Charter Subscriber
Trader Rating: 24 (100%+)
What r u guys using for bearings?
RC Tech Subscriber # 79
Red Z is offline   Reply With Quote
Old 03-07-2005, 10:30 PM   #9725
tc3stocker's Avatar
Send a message via AIM to tc3stocker Send a message via Yahoo to tc3stocker
ACER Ceramics
tc3stocker is offline   Reply With Quote
Old 03-08-2005, 11:19 PM   #9726
Hi Guys,
Any suggestion to remedy a few stripped diff case screws (top)?
Cos if I hit something, the screws would pop/open case as a result.....
marzin is offline   Reply With Quote
Old 03-09-2005, 05:22 AM   #9727
ThePrfctGetaway's Avatar
Location: If I told you, I'd have to shoot you in the face.
Send a message via AIM to ThePrfctGetaway
I have some of those, but the screws don't come out, at least, last time I checked.. What happened? Tightened them too much? Mine were already stripped when I got it.. I wonder if putting CA Glue in it would work... it could bond to the plastic and create the threads out of glue, as a temporary fix it COULD work... don't know if it WILL.....
ThePrfctGetaway is offline   Reply With Quote
Old 03-09-2005, 05:53 AM   #9728
Buy 5/40 screws. They are a little larger, and use the same 3/32" driver. You will have to drill out the top holes of the diff case so the screw will be loose in it.
JWATT is offline   Reply With Quote
Old 03-09-2005, 06:04 AM   #9729
Originally posted by MikeDeadly
The composite CVD's are lighter but would really only hold up if you are only running stock. The lighter material would help you get up to speed a tad bit quicker due to the less rotating mass, but again this would only be for stock. The composite cvd's would not be able to take the stress of mod racing.
--Mike
Am running composite CVD's in the rear both on my TC3 and TC4 in mod without any problem. I have not broken any so far.
Nella-Nobrob is offline   Reply With Quote
Old 03-09-2005, 07:50 AM   #9730
Manfredo's Avatar
How many of you guys are using the direct bolt-on parts of the TC 4 on your TC 3. Im talking about shock towers, main shaft, and the chassis stiffeners with the upper link mounts ?
Manfredo is offline   Reply With Quote
Old 03-09-2005, 07:59 AM   #9731
rayhuang's Avatar
The only TC4 item on my tc3 is the rear camber link/side posts. I am running the stock rear shock tower in conjunction because the TC4 rear shock tower (graphite) deflects all over the place when you compress the suspension.
Old 03-11-2005, 01:43 AM   #9732
NOZ69's Avatar
G`day ppl`s,
Looking at buying a 2nd hand TC3.... is there any particular area that i should look at closely.
FT TC4, LRP TC Sphere, LRP X-11 13.5
SC10 4x4
M03M Suzuki Swift
Power by Feral
Sanwa MX-3 FHSS
NOZ69 is offline   Reply With Quote
Old 03-11-2005, 09:05 PM   #9733
Hi
The CA worked temporary as for now, holding the diff case nice and tight....... another issue to solve though..car is too loud!
Do you put any lube to your gears ?
Thanks !
Old 03-11-2005, 09:11 PM   #9734
S.Stew's Avatar
I run the Chassis braces and shock towers. I had the tc3 shock towers on there but then i just bought the TC4 peices for the heck of it. It works pretty good. Mainly i like it cuz it allows for a little higher roll center in the front.
- Steven Stewart - Kawada USA
www.Kawada-USA.com
S.Stew is offline   Reply With Quote
Old 03-12-2005, 10:11 AM   #9735
Registered User
RC Noob's Avatar
Send a message via AIM to RC Noob Send a message via MSN to RC Noob
hey guyz, i used to be RC GURU changed my name, well, umm i was wondering, if you guyz know where i can get aftermarket diffs (pre-built would be nice), hop-ups basically, for a cheap decent price.
RC Noob is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
