Like Tree4Likes
Old 02-20-2005, 12:31 PM   #9691
Bad Boys Racing's Avatar
Send a message via AIM to Bad Boys Racing
do i have to remove it to use a TC4 steering system?
Bad Boys Racing is offline   Reply With Quote
Old 02-20-2005, 12:45 PM   #9692
crACkeD ChaSsiS's Avatar
Send a message via AIM to crACkeD ChaSsiS Send a message via Yahoo to crACkeD ChaSsiS
Default site
yes look here
http://ca.geocities.com/[email protected]/index.htm
crACkeD ChaSsiS is offline   Reply With Quote
Old 02-20-2005, 04:01 PM   #9693
Whoops! We can't find your page!
The web page you are trying to access doesn't exist on Yahoo! GeoCities.
If you continue to have trouble, visit our help area for information and assistance.
Old 02-20-2005, 04:28 PM   #9694
Default TC3 MODIFICATIONS
hmmmmm i dont know WHATS GOING ON. that was the site,where the guy exactly shows you how to convert to tc4 steering and wat tools to use.sorry i cant help you beyond that, i havent did it ive only did the battery modification/made the motor hole WIDER. i dont want to risk messing my chassis up with the tc4 steering. good luck some1 may have some pics. do a search on here an look for it!
Old 02-20-2005, 04:36 PM   #9695
Trader Rating: 112 (100%+)
Send a message via AIM to Valentin.H
have you guyz tried drifting with ur tc3? i have, its mega fun, slide to da left, slide to da right, slipe up and down all fricken nighT!!! LOL
-valentin
www.csjunkies.com
Valentin.H is offline   Reply With Quote
Old 02-20-2005, 05:40 PM   #9696
mistercrash's Avatar
R/C Tech Charter Subscriber
Here's the correct URL
And it doesn't show how to install the TC4 rack on the TC3. It shows how to install the NTC3 rack on the TC3.
mistercrash is offline   Reply With Quote
Old 02-22-2005, 07:37 PM   #9697
EDWARD2003's Avatar
Default XXX-S Front Carriers on a TC3
Ok i keep breaking TC3 Front Hub Carriers, i heard you can switch to XXX-S Front Hub Carriers. Now do I use the supplied 4 deg caster blocks from losi or just use the TC3 4 deg caster blocks? I have seen people break steering racks left right and center when they use the losi hub carriers and losi caster blocks on a TC3. Is it safe to use only the losi hub carriers and Associated caster blocks.
Whats the safe COMBO?
Pickering
up in Canada
EDWARD2003 is offline   Reply With Quote
Old 02-23-2005, 08:29 AM   #9698
Shumacher 99's Avatar
Lightbulb Oneway
Is the NTC3 oneway the same as the e TC3. Basicly is it the same part.? I should know this but I don't.
Shumacher 99 is offline   Reply With Quote
Old 02-23-2005, 10:18 AM   #9699
diskostew's Avatar
Send a message via Yahoo to diskostew
the one way is the same but the outdrives are differnt. the NTC3 out drives are bigger than the TC3's
diskostew is offline   Reply With Quote
Old 02-23-2005, 12:56 PM   #9700
So will it work with those outdrives ?I called the local guy and he said that is a stronger version of the E tc3 and the one to put it anyways???
Old 02-23-2005, 01:01 PM   #9701
The one-way housings are the same (they fit in the same diff case), but the removable outdrives are shorter for the electric when compared to the nitro. If you have a nitro 1-way and want to put in an electric, the outdrives must be replaced for it to work, and the reverse is true if going from an electric to a nitro car.
Hope this helps.
JWATT is offline   Reply With Quote
Old 02-23-2005, 01:05 PM   #9702
Yes it'll work. I've got one.
The outdrives on the old one way weren't very strong. I've never broke one with the new heavy duty one way.
urbanfox is offline   Reply With Quote
Old 02-24-2005, 08:11 AM   #9703
EDWARD2003's Avatar
Default anyone
Old 02-24-2005, 01:22 PM   #9704
PaZ
PaZ's Avatar
i did that i averaged 2 a night racing. So i went ally......no problems not even a bend and im not a good driver lol never run the losi ones or seen anybody i know with a TC3 run one
Xray T2 0079
Mardave V12 VRX
Team T.J Cells
CT Race Bodies
PaZ is offline   Reply With Quote
Old 02-24-2005, 08:16 PM   #9705
tornado
Guest
Posts: n/a
Default Re: anyone
Perhaps a wider bumper would help....by RPM. I've yet to break any "C" hubs since using that darn blue RPM bumper.
As for the steering rack.....I'm using NTC3 ones....no more problems with the racks getting jammed by stones and very reliable. Hope this helps.
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
