Old 02-05-2005, 08:58 AM   #9646
crACkeD ChaSsiS's Avatar
Send a message via AIM to crACkeD ChaSsiS Send a message via Yahoo to crACkeD ChaSsiS
Default question
primusblowsgoat-hey man do u see any difference between the aluminum shaft and the stock shaft?as in performance?
crACkeD ChaSsiS is offline   Reply With Quote
Old 02-05-2005, 09:25 AM   #9647
primusblowsgoat's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to primusblowsgoat Send a message via Yahoo to primusblowsgoat
i dont really know, ive only driven the tc3 a few times recently, and only once with the alum shaft, but there were so many other things wrong i couldnt tell you
Schumacher Racing
Schumacher Cat SX2
Schumacher Cougar SV
primusblowsgoat is offline   Reply With Quote
Old 02-06-2005, 07:22 AM   #9648
Registered User
put my brushless motor in my FTTC3 yesterday and WOW amazing! the only thing i ran into was changing the spur gear.....u ahve to take out the whole rear end..but i guess its okay..the car is super fast though. i cant wait to run it at the track!
RC Buddah is offline   Reply With Quote
Old 02-06-2005, 07:26 AM   #9649
Default brushless motor
u guyz have a brushless class?
Old 02-06-2005, 06:33 PM   #9650
is this a one-way diff? http://www2.towerhobbies.com/cgi-bin...?&I=LXDGD6&P=7
kh15 is offline   Reply With Quote
Old 02-06-2005, 08:38 PM   #9651
no thats just a solid axle, like if you glued a diff together
Schumacher Racing
Schumacher Cat SX2
Old 02-06-2005, 08:58 PM   #9652
Registered User
Default Re: brushless motor
umm im not sure...ive been running offroad...and i just run for fun during practices..thats it..
Old 02-06-2005, 09:15 PM   #9653
Registered User
hey guyz....im trying to solve this problem...there are holes on top of my diff case that show the diff...waht im worried is that dust/tiny rocks will get into the diff...is it okay to put some silicone on top of it so it would be sealed?
Old 02-06-2005, 09:31 PM   #9654
Speedie's Avatar
I put a small screw in the hole but some silicone will work great.
www.victoryhobbies.com Greenbay, Wisconsin
Speedie is offline   Reply With Quote
Old 02-07-2005, 12:31 PM   #9655
yea whats that about, i have to clean mine out all the time, during the summer but i dont worry about it when i run on carpet in the winter, i will just shove a screw in it, but my tc3 is on the shelf now cause those stupid plastic diff cases are all stripped out so i have to get new ones
any one know of a site where i can get a one way for my tc3?
Old 02-07-2005, 12:37 PM   #9656
Originally posted by kh15
[B]yea whats that about, i have to clean mine out all the time, during the summer but i dont worry about it when i run on carpet in the winter, i will just shove a screw in it, but my tc3 is on the shelf now cause those stupid plastic diff cases are all stripped out so i have to get new ones
Just buy 5/40 screws, problem solved!
JWATT is offline   Reply With Quote
Old 02-07-2005, 03:24 PM   #9657
Default one-way
i dont know if this will work 4 the tc3 but it may!(one-way)
http://www2.towerhobbies.com/cgi-bin...ay&FVPROFIL=++
Old 02-07-2005, 03:33 PM   #9658
i found one thanks for your help
http://www.carttonic.com/catalog/ind...54,10280,14149
Old 02-08-2005, 04:01 PM   #9659
TimmyMontoya's Avatar
Can anyone direct me in the right direction for a setup with 28mm plaids and purple tires?I will be running on carpet also... I just got a used tc3 and need some help... Thanks in advance!!!
DiscountRCstore.com new distributor of Xray and Hudy
Xray, Hudy, Schumacher, Fantom, Orca
TimmyMontoya is offline   Reply With Quote
Old 02-10-2005, 02:53 AM   #9660
Default Mod to droop screws
Hi Guys,
Mod to droop screws?
I hv got a TC3 without droop screws, still using the shock limiters.
Can I convert the arms to use droop screws? Buy the Ver2 arms?
Any ggod ideas to go about it?
Thanks for any help
Cheers
marzin is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
