Old 02-02-2005, 07:19 PM   #9631
Super Moderator
Funkymojo's Avatar
Location: Singapore ̡͌ ̴̡ı̴̴̡ ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡V
Trader Rating: 75 (100%+)
There's not much difference in weight between stock plastic parts and graphite parts,but the graphite parts are more durable....
Funkymojo is offline   Reply With Quote
Old 02-02-2005, 07:35 PM   #9632
S.Stew's Avatar
I disagree.
Its my understanding that the graphite composite parts are indeed lighter and more stiff than their plastic counterparts. Because of the increased rigidity they flex less are less "durable" per say but do offer a more solid part for us racers.
- Steven Stewart - Kawada USA
www.Kawada-USA.com
S.Stew is offline   Reply With Quote
Old 02-02-2005, 07:57 PM   #9633
crACkeD ChaSsiS's Avatar
Send a message via AIM to crACkeD ChaSsiS Send a message via Yahoo to crACkeD ChaSsiS
Default weight issues
and plus if your'e trying to make it into a pro race and they have a certain race weight.a stock composite tc3 will not make it.now a factory graphite tc3 on the other hands will have a better chance of making weight bcuz of your high end small electronics that dont weigh Sh*t, and there are some places you can take some weight off. im thinking about getting the Bmi chassis or Irs chassis there sweet and lighter. Ive heard with one of those chasssis improves your lap times the second u get it on the track and set it up right. plz correct me if im wrong some1. my 2cents
crACkeD ChaSsiS is offline   Reply With Quote
Old 02-02-2005, 08:39 PM   #9634
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
A BMI chassis is a good upgrade for the TC3. It usually gives better laptimes, but if nothing else, it will make your current laptimes much more consistent. It also is not susceptable to warp like the tub chassis is. Plus, it looks much cooler
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 02-02-2005, 08:46 PM   #9635
Super Moderator
Funkymojo's Avatar
Hi guys,i've got a question to ask...besides IRS spur gear adapter,what other brands are there available?My friend told me that IRS makes one of the best hop up spur gear adapter,but i wanna know what other brands are there,and are they as good as the IRS adapter?Whats the most durable or best in the market?Replies will be greatly appreciated.Thanks guys
Old 02-02-2005, 08:59 PM   #9636
Trader Rating: 24 (100%+)
Is there any difference between an Alfa Romeo 2.0 and any Stratus body handling wise?
RC Tech Subscriber # 79
Red Z is offline   Reply With Quote
Old 02-02-2005, 09:17 PM   #9637
Super Moderator
Funkymojo's Avatar
Are the Square racing aluminium spur gear adapter as good as the IRS one?Thanks
Old 02-03-2005, 12:17 AM   #9638
I was always told graphite was less impact resistant than plastic. If that wasn't true wouldn't RPM make their stuff out of graphite?!?
Old 02-03-2005, 02:19 AM   #9639
PaZ
PaZ's Avatar
im my experience graphite breaks easier than plastic.
As for all me ally parts it has put on a small amount of weight but some should be shead with me warpspeed demon, i have never bent any ally parts and im not exactly a careful racer but i try my best not to crash. I do check all the parts after every meet just to make sure but none bent yet.
Xray T2 0079
Mardave V12 VRX
Team T.J Cells
CT Race Bodies
PaZ is offline   Reply With Quote
Old 02-04-2005, 06:54 AM   #9640
Registered User
are the stock FTTC3 plastic outdrives durable? they look kinda cheesy..if they are kinda cheasy..which i doubt...because its a Factory Team car from associated..which I've heard is a great car....whats the average price of the ally outdrives? thanks in advance.
RC Buddah is offline   Reply With Quote
Old 02-04-2005, 06:58 AM   #9641
primusblowsgoat's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to primusblowsgoat Send a message via Yahoo to primusblowsgoat
i put the tc4 towers and chassis braces on my car, and when i ran it for the first time without changing anything else, the car had a ton of turn it but the back end was quite loose
im running cs 27s, copper spring in the front, blue in the rear, shock in the outside hole on the arm, second hole in on the tower in the front , same in the rear.
what should i do to get some more rear traction
Schumacher Racing
Schumacher Cat SX2
Schumacher Cougar SV
primusblowsgoat is offline   Reply With Quote
Old 02-04-2005, 10:24 AM   #9642
PaZ
PaZ's Avatar
err im running yellow 70wt inner most front with anti roll bar and red 50wt inner most. Nice turning loads of grip no slide. Very nice might help.
Xray T2 0079
Mardave V12 VRX
Team T.J Cells
CT Race Bodies
Old 02-04-2005, 10:40 AM   #9643
g12314's Avatar
Send a message via AIM to g12314 Send a message via Yahoo to g12314
primusblowsgoat:
Hey Jimmy here (the slow 1/12th guy )
Next time we are at RSJ together, I'll help ya get that car setup. Something is not right if your having to run the setup you posted.
Jimmy.
"PREPARE TO QUALIFY"
g12314 is offline   Reply With Quote
Old 02-04-2005, 11:24 AM   #9644
LOL i dont have to run the setup i posted, i just had money to burn and figured id try it out.
with the stock tc3 towers and chassis braces, and the same spring and monting combos, it car handled alright, just not good enough.
i also changed some other stuff too, alum center shaft, alum cvds, i took some material off the diff cases to free it up, smaller spur with a new motor, and i believe the tires may be starting to go out, so it may not just be the tc4 parts change.
i only ran it through one pack on wed.
Schumacher Racing
Schumacher Cat SX2
Old 02-05-2005, 08:50 AM   #9645
g12314,
You going to the MWTCS race at RSJ?
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
