Old 02-01-2005, 10:07 AM   #9601
primusblowsgoat's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to primusblowsgoat Send a message via Yahoo to primusblowsgoat
so one shim on the long side, no shim on the short side?
and i assume use a dremel or something on the diff cases to widen them just enough so a bearing wont stick in there?
Schumacher Racing
Schumacher Cat SX2
Schumacher Cougar SV
primusblowsgoat is offline   Reply With Quote
Old 02-01-2005, 10:10 AM   #9602
Originally posted by primusblowsgoat
so one shim on the long side, no shim on the short side? YES
Be careful with a Dremel, if you remove too much, it is hard to put back! Xacto will take longer, but can do it.
Hope this helps!
JWATT is offline   Reply With Quote
Old 02-01-2005, 10:20 AM   #9603
diskostew's Avatar
Send a message via Yahoo to diskostew
Hope this helps!
or just go buy the tc4 diff cases. you don't have to dremel out anything
diskostew is offline   Reply With Quote
Old 02-01-2005, 10:33 AM   #9604
Default tc3 trasmission cases
the tc4 cases are the same as the tc3 ive been advised, the tc3 cases were revised about 2 years ago, unless im mistaken
alan orton is offline   Reply With Quote
Old 02-01-2005, 10:36 AM   #9605
diskostew's Avatar
the last set of TC3 cases I had still needed to be dremeled out. but when i got my tc4 the cases were perfect...
Old 02-01-2005, 10:40 AM   #9606
thats probably what ill do, ive already got tc4 toweres and chassis braces, why not get the cases too
Schumacher Racing
Schumacher Cat SX2
Old 02-01-2005, 10:44 AM   #9607
Default tc3 transmission cases
in england the cases are the same part number for the tc3 and the tc4, perhaps we get all the old stock from associated sent to the uk?
Old 02-01-2005, 11:06 AM   #9608
ive just ordered a set of "boca" ceramic bearings, has anyone who is useing "boca" bearings have any tips for the tranny cases.
Old 02-01-2005, 02:11 PM   #9609
it should take you about 5 passes with a xacto blade on the diff case to make the bearing free, i dont know where you guys are useing a dremel, but i did mine with an exacto and it took my like 5 minutes to do both cases. and a rc mag i have recomends xacto
kh15 is offline   Reply With Quote
Old 02-01-2005, 03:01 PM   #9610
PaZ
PaZ's Avatar
I ordered the the TC3 cases before i knew about the TC4 cases the guy who i buy off said that Associated are now doing one one case for the TC3 and the NTC3 under one number the only difference being that there is an extra bit on the case to do with the NTC3 but its not in the way. Then when i heard about the TC4 cases i ordered the diff cases and they were exactly the same as my old cases, do the TC4 cases look like this? ( on this piccy its old and the rear case is the only fitted one the front is STD) But to be honest im not bothered if there not cause they dont need any work on em they are perfect tooooooo
Xray T2 0079
Mardave V12 VRX
Team T.J Cells
CT Race Bodies
PaZ is offline   Reply With Quote
Old 02-01-2005, 03:05 PM   #9611
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
The new tc3/tc4 diff cases are fine. They have fixed the bearing tightness problem, they still squeeze, but they are suppose to, otherwise there will be bearing slop which=premature failure
You can tell by the little stubs sticking up to lock the case together, they are now shorter.
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
Old 02-01-2005, 03:34 PM   #9612
PaZ
PaZ's Avatar
Stubs, is that the little bit on the front a back of the diff case?
Xray T2 0079
Mardave V12 VRX
Team T.J Cells
CT Race Bodies
Old 02-01-2005, 04:16 PM   #9613
Moderator
the 6 stubs where the cases get held together
SMC Racing
Old 02-01-2005, 04:27 PM   #9614
PaZ
PaZ's Avatar
ah yes cheers
Xray T2 0079
Mardave V12 VRX
Team T.J Cells
CT Race Bodies
Old 02-01-2005, 08:59 PM   #9615
crACkeD ChaSsiS's Avatar
Send a message via AIM to crACkeD ChaSsiS Send a message via Yahoo to crACkeD ChaSsiS
Default tc3 weight issues
does ny1 know how much heavier the tc3 racer kit is over the factory graphite kit or vice versa? thank you in advance
crACkeD ChaSsiS is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 05:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 02:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 08:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 09:26 PM
SEO by vBSEO 3.5.0
