Old 01-28-2005, 05:12 AM   #9556
PaZ
PaZ's Avatar
right, im running on a flowing carpet track that you dont really need to use the brakes on, maybe one or two corners would a front one way improve my handling at all. Cause theres only 5 TC3's at our club now and nobody has tried a one way, should i?
Xray T2 0079
Mardave V12 VRX
Team T.J Cells
CT Race Bodies
PaZ is offline   Reply With Quote
Old 01-28-2005, 05:24 AM   #9557
SteveM's Avatar
Trader Rating: 133 (100%+)
I have used a front one-way on our indoor carpet track to good effect. On a flowing track as you have described, I was able to lower my lap times over running dual diffs. If you can get your hands on a one-way for a reasonable price then it's at least worth a try. You might also want to sonsider a solid front spool. This will retain 4WD braking which is nice.
SteveM is offline   Reply With Quote
Old 01-28-2005, 05:34 AM   #9558
PaZ
PaZ's Avatar
cheers, a solid front spool ill have a look at one of those. Are they easy to maintain?
Xray T2 0079
Mardave V12 VRX
Team T.J Cells
CT Race Bodies
Old 01-28-2005, 06:53 AM   #9559
Hey Red Z i gotta roller for sale. All graphite, with graphite parts, Ive got one guy interested, if he passes, I'll PM u
runnin rc10 is offline   Reply With Quote
Old 01-28-2005, 07:16 AM   #9560
primusblowsgoat's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to primusblowsgoat Send a message via Yahoo to primusblowsgoat
last night someone told me tc4 shock towers and chassis braces fit on the tc3 is this true?
and ive read on here people are using tc4 diff casses, so what else bolts on and what doesnt?
Schumacher Racing
Schumacher Cat SX2
Schumacher Cougar SV
primusblowsgoat is offline   Reply With Quote
Old 01-28-2005, 07:18 AM   #9561
PaZ
PaZ's Avatar
sweet, i think 2 rolling TC3's ( hey what ya gonna do if one brakes) ( and yes its RTR just add cells and go) and 1 complete car taken appart for spares is enough
Xray T2 0079
Mardave V12 VRX
Team T.J Cells
CT Race Bodies
Old 01-28-2005, 07:19 AM   #9562
PaZ
PaZ's Avatar
yea they do, i was gonna fit the TC4 shock tower until i realised you need the chassis braces but i got ally chassis braces so i decided against it. But the TC4's give you more setting options
Xray T2 0079
Mardave V12 VRX
Team T.J Cells
CT Race Bodies
Old 01-28-2005, 07:49 AM   #9563
good, cause i baught them already lol
so if the diff cases shock towers and chassis braces fit, im sure the diffs do as well, so what else anything?
Schumacher Racing
Schumacher Cat SX2
Old 01-28-2005, 07:07 PM   #9564
Registered User
the tc3 doesnt have a sway bar that comes standard does it? no righT? if not..is there a KIT?
RC Buddah is offline   Reply With Quote
Old 01-28-2005, 10:12 PM   #9565
yea the tc4 diff cases fit and i heard thier great but i cant seem to find them for sale yet on the internet but i will give them i couple more months, im in not rush.
is it good to run swaybars? im not 100% sure on what purpose the serve but any thing to make my tc3 handle that much better im in for!
kh15 is offline   Reply With Quote
Old 01-28-2005, 10:16 PM   #9566
Registered User
yeh..sway bars are suppose to improve ANY cars handling almost drastically i've heard.
Old 01-28-2005, 11:05 PM   #9567
R/C Tech Charter Subscriber
Trader Rating: 24 (100%+)
Sway bars can and do help but only if your car is behaving in such a manner as to justify running one. It's not like bolting in a faster motor where more=better. I have run both front and rear bars at different times. I found that front gave me more rear traction at the cost of a bit of steering, and that rear took away a touch of traction but added a bit of steering. I'm not calling that Holy Writ, but that's how my car reacted.
RC Tech Subscriber # 79
Red Z is offline   Reply With Quote
Old 01-29-2005, 07:04 AM   #9568
Registered User
then it just makes it even if you put both front&back at the same time
Old 01-29-2005, 10:46 AM   #9569
PaZ
PaZ's Avatar
i started running one on the front only and the steering improved loads, a good idea to have em
Xray T2 0079
Mardave V12 VRX
Team T.J Cells
CT Race Bodies
Old 01-29-2005, 11:54 AM   #9570
Jack Smash's Avatar
Trader Rating: 29 (100%+)
Anti roll bars are used for high bite tracks where there is so much traction that it is hard to control chassis roll or that the bite slows the car down in the corners. If you are searching for traction then I would suggest against anti-roll bars.
TC4 parts that fit the TC3:
Steering blocks and Caster blocks
Chassis Braces
Shock Towers
All driveline components
Rear Uprights
Shocks
Wheel Hexes
Battery Strap
Motor Cam
Motor Clamp
Arms will fit if you drill out the mounts to accept the larger pin and maybe a little bit of dremel work. The tc4 anti-roll bars will work if you put TC4 arms on.
Kyosho / Orion / Amain.com / Protek
Jack Smash is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
