Old 01-17-2005, 11:50 AM   #9481
Default Ratio
Need to gear the motor so that you hear it peak just before the end of the longest straightaway. Asking people what their ratio is won't really help, unless they run the same track. My son & I both run a 100/27 with our Monsters, very different from the above post, because you must tune to the track YOU run on, not what we run on.
Hope this helps!
JWATT is offline   Reply With Quote
Old 01-17-2005, 06:03 PM   #9482
RCNitroDude999's Avatar
Trader Rating: 26 (100%+)
anyone know where i can find servo mounts for the tc3?
RCNitroDude999 is offline   Reply With Quote
Old 01-17-2005, 09:22 PM   #9483
t4driver88's Avatar
Send a message via AIM to t4driver88
Default foam
any good stock foam set ups
TRACKSIDE
associated sc10,t4,b4
B&B racing
t4driver88 is offline   Reply With Quote
Old 01-17-2005, 10:02 PM   #9484
Nova F1 Racer's Avatar
R/C Tech Charter Subscriber
Yeah, Speed teck, Tower.....
This is DICK!!! And you're NOT!
RC Tech member #11
Aussie Rules Footy, Brisbane LIONS!!
[url]http://www.pitter-pat.com/[/url] for pet care needs in Northern Virginia
Nova F1 Racer is offline   Reply With Quote
Old 01-17-2005, 10:03 PM   #9485
Default Re: foam
Tar? Carpet? Look at Team Assoc website and they have a couple of good basic set-ups there..
RC Tech member #11
Old 01-18-2005, 04:33 AM   #9486
PaZ
PaZ's Avatar
i got a sweet set up for foams on carpet on a tight track. Fastest TC3 at me club at the mo
Xray T2 0079
Mardave V12 VRX
Team T.J Cells
CT Race Bodies
PaZ is offline   Reply With Quote
Old 01-18-2005, 07:35 AM   #9487
primusblowsgoat's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to primusblowsgoat Send a message via Yahoo to primusblowsgoat
Baught a tc3 off a buddy last night.
took it apart rebuilt the diffs, changed the ball studs and cups. get rid of must of the slop in it.
put all my electronics in it, and the thing is loud. My gear mesh is fine i think, what else would cause that?
Theres also still some slop in the steering rack, i woulda changed the bushings but i didnt have any that size, i know theres a way to put the ntc3/tc4 steering set up in there anyone have a link showing how?
How bout a link showing how to do the battery mod?
or any other fun mods i can do
thanks
Schumacher Racing
Schumacher Cat SX2
Schumacher Cougar SV
primusblowsgoat is offline   Reply With Quote
Old 01-18-2005, 08:46 AM   #9488
thanks
What thing is loud?
Try running 1 diff at a time to pin-point which one is making noise... Check you pinion/spur.. THere are different types of 49 pitch gearing... Some have rounded teeth and other are more square shaped...
RC Tech member #11
Old 01-18-2005, 08:51 AM   #9489
its just all around loud, i was gonna run it in the hallway of my apartment but it was 11pm it it woke my gf up.
the spur and pinion are fine i looked those over, no problems there, i believe the noise is coming from the bearings on the input shafts, does that sound right?
Schumacher Racing
Schumacher Cat SX2
Old 01-18-2005, 10:40 AM   #9490
PaZ
PaZ's Avatar
For 2 weeks my TC3 was loud as anything and i stripped the car 3 times trackside to find the problem i changed everything on it diffs, bearings, etc and it was coming from the rear by the spur i changed the spur and that stopped it even though the spur was almost new 3 runs no meshing it was still perfect try changing the spur and see what that does.
Xray T2 0079
Mardave V12 VRX
Team T.J Cells
CT Race Bodies
Old 01-18-2005, 10:57 AM   #9491
well ill give it a shot
Schumacher Racing
Schumacher Cat SX2
Old 01-18-2005, 11:20 AM   #9492
PaZ
PaZ's Avatar
i hope thats the problem, also when you screw the spur on dont over tighten it or the screws rub against the chassis a do some damage like i did
Xray T2 0079
Mardave V12 VRX
Team T.J Cells
CT Race Bodies
Old 01-18-2005, 03:02 PM   #9493
i want to get those yok shock caps and bladders for my ae shocks to make bleeding and rebuilding them a hell of alot easier!
is this what i need?
http://www.speedtechrc.com/store/ebp...nid=236&id=963
kh15 is offline   Reply With Quote
Old 01-18-2005, 07:14 PM   #9494
Trader Rating: 24 (100%+)
As for bleeding shocks: a guy at my track drilled and tapped holes in his shock caps for bleeder screws. They work pretty slick.
Did the TC 3 only have 1 "strength" of sway bar?
[B]RC Tech Subscriber #[COLOR="Red"]79[/COLOR]
[URL="http://www.rctech.net/forum/showthread.php?t=83030&highlight=Red"]My RC Tech Feedback Thread[/URL][/B]
Red Z is offline   Reply With Quote
Old 01-18-2005, 09:08 PM   #9495
yea red i might try that also
but how does it work, do i fill the body and cap full of oil and then screw them together, loosen the bleed screw and pump the air out?
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
