Old 01-15-2005, 09:39 AM   #9466
primusblowsgoat's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to primusblowsgoat Send a message via Yahoo to primusblowsgoat
Well since that site is gone, is there another one somewhere, im about to pick up a tc3, the last one i had i got rid of two yrs ago, so im outa the loop, and would like to get back in.
id prefer not to have to read through all the pages of this thread but i suppose if theres no other place to get info, thats what ill do
Schumacher Racing
Schumacher Cat SX2
Schumacher Cougar SV
primusblowsgoat is offline   Reply With Quote
Old 01-15-2005, 10:57 AM   #9467
R/C Tech Charter Subscriber
Trader Rating: 24 (100%+)
Primus-
Just pick up the XXX Main (I think) Touring Car tuning book at your LHS. That is like the Bible for tuning these 4wd beasts, IMO.
[B]RC Tech Subscriber #[COLOR="Red"]79[/COLOR]
[URL="http://www.rctech.net/forum/showthread.php?t=83030&highlight=Red"]My RC Tech Feedback Thread[/URL][/B]
Red Z is offline   Reply With Quote
Old 01-15-2005, 11:16 AM   #9468
ive seen that thing b4, does it have stuff like how to put the ntc3 steering in a tc3 or how to move the batterys inward with some dremel work? or whatever it is that people are doing to the gear boxes to make em smooth?
Schumacher Racing
Schumacher Cat SX2
Old 01-15-2005, 01:59 PM   #9469
diskostew's Avatar
Send a message via Yahoo to diskostew
the easy way to make the drive train smooth is just to go buy the TC4 diff cases. they are ultra smooth from the factory without any dremel work at all...
diskostew is offline   Reply With Quote
Old 01-15-2005, 10:24 PM   #9470
I know that that book explains how to tune your car, tells you what different terms mean, explains what happens when you adjust different components, and generally why your car is doing what it is doing. As to "kitbashing" I don't know but don't think so.
Old 01-16-2005, 10:56 AM   #9471
mistercrash's Avatar
Originally posted by vtl1180ny
How come you got rid of it???
No more web server to host the site.
mistercrash is offline   Reply With Quote
Old 01-16-2005, 06:47 PM   #9472
If you're still interested in hosting Freeservers isn't too bad. They use templates which kinda limits you but if you can write HTML you can get around it. I use it for my website and a friends that I built.
Old 01-16-2005, 06:55 PM   #9473
i need some new diff cases for my tc3 what makes the tc4 cases diffrent? i keep striping the screw holes out of the bottom half on both my diff cases is thier anyway to fix it? so the screw tightens down, i heard you can put i tiny strand of wire for like a strand of speaker wire in the striped out hole and then when you put the screw in and tighter because of this wire in their?
kh15 is offline   Reply With Quote
Old 01-16-2005, 11:57 PM   #9474
diskostew's Avatar
The tc4 diff cases are just much better. They have less material where the bearing goes so you don't have to dremel anything to make your drive train spin free. As far as stripping the diff cases, I heard you can helicoil the screw holes. But that is way too much work for me.
Old 01-17-2005, 06:58 AM   #9475
what the heehaw is helicoiling
Schumacher Racing
Schumacher Cat SX2
Old 01-17-2005, 07:30 AM   #9476
Default Stripped out threads
Anytime you are re-inserting a screw into plastic always first turn it counter clockwise (unscrewing it) with a little downforce, you will feel the screw "drop" into place, stop there and tighten the screw. You can also try 5-40 screws. Same 3/32" ball driver, just a bit larger, seem to not strip as much. You will need to drill out the top half of the diff case so the screw is not tight.
Hope this helps.
JWATT is offline   Reply With Quote
Old 01-17-2005, 08:45 AM   #9477
Default IRS Pin Cushions
I put these on my dog bones, and I can't seem to keep them from coming out! Anybody else had this and solved it? Super Glue?
Old 01-17-2005, 10:07 AM   #9478
diskostew's Avatar
it is a metal screw sleave you can tap in to the plastic. I have seen people do it to their diffcases but it is way to much work for me.
Old 01-17-2005, 10:44 AM   #9479
Thanks I'll look into it.
Old 01-17-2005, 11:42 AM   #9480
ravenos's Avatar
Post tc3
Originally posted by gacjr0
go for a 96-98-100 spur and 26-33 pinions in general, figure out the gear ratio range your using now and buy the same ratio range in 64p
im running 64 pitch as well
100\37 with a monster
ravenos is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 05:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 02:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 08:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 09:26 PM
SEO by vBSEO 3.5.0
