Old 12-28-2004, 06:58 PM   #9436
Default CVD's RUbbing
Does anyone have a problem with the rear CVD's rubbing the springs? I have the car length at the middle position (spacer on either side). I know they're rubbing cause the CVD's got a shiny spot on them. Is something amiss with the way I put the car together? Thanks for any help in advance.
scotwithonly1t is offline   Reply With Quote
Old 12-29-2004, 08:04 AM   #9437
Nova F1 Racer's Avatar
R/C Tech Charter Subscriber
Default Re: CVD's RUbbing
I used a longer screw and washers on the top to move it away from the CVDs.
This is DICK!!! And you're NOT!
RC Tech member #11
Aussie Rules Footy, Brisbane LIONS!!
[url]http://www.pitter-pat.com/[/url] for pet care needs in Northern Virginia
Nova F1 Racer is offline   Reply With Quote
Old 12-29-2004, 08:50 AM   #9438
calstarjig90j's Avatar
You can do two things here that I have done. Put another nut(ON TOP) on screw to make the top part of the shock move more to the rear or you can cut the wider servo spacers that came with the tc3 kits and place them in the same place as an alternative. As with the front if you use 2 or 4 degree castor I shave the c hub so that the spring cup and spring have free movement. I also do the nut or spacer thingee to the front shocks for clearance. When racing every little thing makes a difference.
calstarjig90j is offline   Reply With Quote
Old 12-29-2004, 08:53 AM   #9439
Default Re: how long to soak bearings?
Originally posted by crACkeD ChaSsiS
how long do u guyz soak yur bearings in motor cleaner are watever u use to clean them in? and wat do u do afterwards?ny help well appreciated
Steven Alexander
however long it takes to get the gunk out. Break the seals and they'll really run free. Lots of maintenance though.
Old 12-30-2004, 06:09 AM   #9440
Originally posted by SPZA
i was just wondering if anyone out there has any links to site of some set up tips for the TC3. i was looking for things like, battery mod, steering rack mod, and any others you guys have.
thanks
tc3 mod site
envious8420 is offline   Reply With Quote
Old 12-30-2004, 01:59 PM   #9441
HK Racing Joe's Avatar
Send a message via AIM to HK Racing Joe
wat upgrades u guys running ( driver shaft, chassis ect.) jw
HK Racing Joe is offline   Reply With Quote
Old 12-30-2004, 03:24 PM   #9442
Default ? Steering rack tc3
Hi guys just wondering does the nitro steering rack or tc4 rack fit the bmi graphite chassis
rs911 is offline   Reply With Quote
Old 12-30-2004, 03:33 PM   #9443
Speedie's Avatar
The nitro rack will fit into the BMI TC3. Here is a link that explains how.
http://tpjexelby.tripod.com/NitroRackPics.htm
www.victoryhobbies.com Greenbay, Wisconsin
Speedie is offline   Reply With Quote
Old 12-30-2004, 10:41 PM   #9444
Trader Rating: 24 (100%+)
I soak my bearings in STP Fuel injection cleaner overnight.
As to bodies, I find that the Alfa Romeo 2 from Proline is darn good. It's better than the C-5 for sure!
[B]RC Tech Subscriber #[COLOR="Red"]79[/COLOR]
[URL="http://www.rctech.net/forum/showthread.php?t=83030&highlight=Red"]My RC Tech Feedback Thread[/URL][/B]
Red Z is offline   Reply With Quote
Old 12-30-2004, 11:05 PM   #9445
crACkeD ChaSsiS's Avatar
Send a message via AIM to crACkeD ChaSsiS Send a message via Yahoo to crACkeD ChaSsiS
Default top bumper brace
has ny1 tried the tc3 top bumper brace?if so does it help handling or?
Steven Alexander
crACkeD ChaSsiS is offline   Reply With Quote
Old 12-31-2004, 03:46 AM   #9446
PaZ
PaZ's Avatar
HKlosi---------- scroll down the page thats the upgrades i got until i get more money
Xray T2 0079
Mardave V12 VRX
Team T.J Cells
CT Race Bodies
PaZ is offline   Reply With Quote
Old 12-31-2004, 12:33 PM   #9447
Little off the bearing discusion but has anyone tried the Light Speed motors. I put one in the TC3 and it's a rocket anyone else use one , RED
redheat8 is offline   Reply With Quote
Old 12-31-2004, 12:43 PM   #9448
with the regular composite tc3 kit and high end electronics.do u think a tc3 is overweight or undeweight?ny help well appreiciated
Steven Alexander
Old 12-31-2004, 02:51 PM   #9449
vtl1180ny's Avatar
My TC3 weight 100 grams less than my Yok CGM... Both chassis's unmodifieds....
I still lurk....
vtl1180ny is offline   Reply With Quote
Old 12-31-2004, 05:23 PM   #9450
My TC3 w/upper end electronics, batt., body is a shade over legal racing weight min. My chassis is unmodified.
New to the forum mig rod Electric Off-Road 1 01-05-2008 04:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 01:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 07:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 08:26 PM
