Old 02-05-2002, 03:01 PM   #931
I use pressure diaphrams in my TC3 shocks and they make building them even easier than with Yokomo shock caps.
patcollins is offline   Reply With Quote
Old 02-05-2002, 03:18 PM   #932
Not going to Florida Tony???
OUTofCONTROL is offline   Reply With Quote
Old 02-05-2002, 04:27 PM   #933
TPhalen's Avatar
R/C Tech Charter Subscriber
Nope...have some traveling to do with my job....
I'll be heading up to Ripon for the Carpet Nats....ewww...Carpet....I don't do well on carpet!!!! That race will be a learning experience for me....going up there not to do well, but to learn how to set-up for MY driving on carpet!!!!
Tony Phalen
UF1 Team Lotus/Renault
RCDriver.com
CompetitionX.com
R Sector / F1 Paint Labs
TPhalen is offline   Reply With Quote
Old 02-05-2002, 04:34 PM   #934
Buda's Avatar
Tony when is your next planned update on that great site you run/own?
and also
Is ther a big differance in the handling/tweak between the composite/graphite chassis and how durable is the graphite I know it is a bit more fragile but how much?
Any tips/parts to help keep tweak to a minimum? I seem to have a problem in straight line tracking but it also may be my cheapo servo (new one on order by end of month hopefully)
Buda is offline   Reply With Quote
Old 02-06-2002, 02:02 AM   #935
johnbull's Avatar
Corse R,
You seem to have missed my bit about F1 earlier.
Have a look and comment.
Regards
Joe from sunny Malta.
johnbull is offline   Reply With Quote
Old 02-06-2002, 03:45 AM   #936
Corse-R's Avatar
Yep! I missed quoting them... Some weeks ago I was at Barcelona and went to Montmelo circuit (it's really closer to Barcelona), but, we can't enter, cos some F1 team was doing tyre tests on wet conditions (I don't know if it was Ferrari or Jordan).
Regarding motorcycles... Naaah! I prefeer Superbikes and Superstock (1000cc) clases. This year I enjoy seeing the 4T bikes battling with the 500cc class. If someone seemed that the Superbikes were poweful (>160HP) wait to see some real 4 stroke racing motors on real racing frames.
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 02-06-2002, 03:53 AM   #937
Corse-R's Avatar
The first time I changed from a composite to a graphite chassis I can't believe that a swap of chassis can change your setup radically. The composite is a little less rigid and makes the car more docile. I use on bumpy or low grip conditions. The graphite is far rigid and I use it on large tracks with smooth surfaces and/or on high grip conditions.
Regarding the chassis tweak, this can be due to a incorrect tightening of the motor clamp (too tightened). I suffered from this until I removed the blue anodize of the clamp and the cam with a nails file. It doesn't need to be tightened to the full to support the motor. If you have the screw with the spring on the motor clamp you need to compress it up to 5 milimeters or a little less.
Cheers,
Corse-R
Old 02-06-2002, 08:35 AM   #938
TPhalen's Avatar
and also
Soon, I hope. It's just taking alot more time than I expected. Digi-pix are done, I'm just making a flashy intro... I know, I know, just get the damn info up, right??? Sorry, working on it!
As Corse-R said, graphite chassis is much more rigid and should be used on hi-traction surfaces. Tweak shouldn't be a problem unless the chassis isn't straight...
Tweak: A good servo is always a must-have, in any vehicle. Another tip, make sure you don't have any toe-out on your car. Toe-out helps the car turn in, but makes it wandery (is that a word?) on the straights....
Tony Phalen
RCDriver.com
CompetitionX.com
Old 02-06-2002, 09:04 AM   #939
Jack Smash's Avatar
Trader Rating: 28 (100%+)
Thanks for all the tips, Tony. Ive been thinking about going back to the composite track for our local parking lot races. Ive even been thinking of milling down the molded bracing in the chassis to get a little more flex. We'll see what happens when I use the stock composite first though.
Jack Smash is offline   Reply With Quote
Old 02-06-2002, 09:19 AM   #940
What is the difference between the D shaped diff rings and the regular diff rings? Any performance advantages? I just got my IRS outdrives in and they are sloted to use the D rings. Just wanted to know if the D rings are worth getting.
Modena AL is offline   Reply With Quote
Old 02-06-2002, 10:16 AM   #941
dcracer's Avatar
The d shape rings prevent the rings from slipping against the out drives under acceleration.
dcracer is offline   Reply With Quote
Old 02-06-2002, 11:31 AM   #942
That sounds like its a good thing. I'm going to order me some. Thanks!
Old 02-06-2002, 12:44 PM   #943
Regional Moderator
Send a message via AIM to Mike F
What was the cost on those outdrive Alan?
Mike F is offline   Reply With Quote
Old 02-06-2002, 12:52 PM   #944
TPhalen's Avatar
Ya, the D ring prevents slipping.
Or, you can just super glue your regular rings (use only a SPOT of glue or you might not make the ring sit flat) to the outdrives. Does the same thing.
Tony Phalen
RCDriver.com
CompetitionX.com
Old 02-06-2002, 01:12 PM   #945
They will be about $25
New to the forum mig rod Electric Off-Road 1 01-05-2008 05:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 02:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 08:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 09:26 PM
SEO by vBSEO 3.5.0
